Atlanta, GA info
04-27-2007, 11:06
Atlanta, GA info
What is the best day and time to go through Atlanta GA.
Do you take by pass or go straight up 75. Want to travel in daylight hours. |
04-27-2007, 11:19
Atlanta, GA info
We travel this route frequently and always stay on 75 straight through
Atlanta. We also use the HOV lane which is legal if there are two in the coach. If you aren't familiar with the HOV lane, if traveling south, get in it just past the 285 split stay in the left lane to get in the HOV lane. You are not supposed to exit the HOV lane unless there are broken white lines. Usually we sail right through unless you happen to get in the work hour traffic from 4:30 to 6 or 6:30 PM. Of course, you should know the average speed limit in Atlanta on any Interstate is 80 MPH. Hope this helps. L & G ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
04-27-2007, 11:34
Atlanta, GA info
From: ejohna2000 To: WanderlodgeForum@yahoogroups.com Sent: Friday, April 27, 2007 6:06 PM Subject: [WanderlodgeForum] Atlanta, GA info .If you can avoid 6:00 AM to 9:00 AM and 3:00 PM to 7:00 PM. I like to go through at 2:00 AM straight up I-75 Bob Loomas 1985 PT 36 What is the best day and time to go through Atlanta GA. Do you take by pass or go straight up 75. Want to travel in daylight hours. [Non-text portions of this message have been removed] |
04-27-2007, 11:52
Atlanta, GA info
I was going to say 3 AM Monday morning but
then saw you wanted daylight hours, loads of luck! Stay on I-75, cut her in half would be my suggestion. The by-pass East is a mess, West is not quite as bad. Either side you'll be running into I-85 and I-20 traffic. Try 10:30 AM and 2:30 PM. that's my best guess. Traffic will let up some after the bypass then strengthen near the city center then stack up again till you hit the bypass. the bypass was the way to go when it opened now it is a mess. bob janes, greenville, sc --- In WanderlodgeForum@yahoogroups.com, "ejohna2000" wrote: > > What is the best day and time to go through Atlanta GA. > Do you take by pass or go straight up 75. > Want to travel in daylight hours. > |
04-27-2007, 12:23
Atlanta, GA info
No one else mentioned the day. Sunday is the day to go straight
through without any problems. Any other day is a zoo. R.E. (Ron) Marabito, Dallas, tX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "ejohna2000" > > What is the best day and time to go through Atlanta GA. > Do you take by pass or go straight up 75. > Want to travel in daylight hours. > |
04-27-2007, 15:22
Atlanta, GA info
I go through town, usually not a problem.
MH ----- Original Message ----- From: ejohna2000 To: WanderlodgeForum@yahoogroups.com Sent: Friday, April 27, 2007 5:06 PM Subject: [WanderlodgeForum] Atlanta, GA info What is the best day and time to go through Atlanta GA. Do you take by pass or go straight up 75. Want to travel in daylight hours. [Non-text portions of this message have been removed] |
04-28-2007, 13:35
Atlanta, GA info
Easier to take 75 through atlanta if arriving between 10am -3 pm
re in geogria > > From: "Mike Hohnstein" <MHOHNSTEIN@...> > Date: 2007/04/27 Fri PM 11:22:50 EDT > To: > Subject: Re: [WanderlodgeForum] Atlanta, GA info > > I go through town, usually not a problem. > MH > ----- Original Message ----- > From: ejohna2000 > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, April 27, 2007 5:06 PM > Subject: [WanderlodgeForum] Atlanta, GA info > > > What is the best day and time to go through Atlanta GA. > Do you take by pass or go straight up 75. > Want to travel in daylight hours. > > > > > > [Non-text portions of this message have been removed] > > > |
