tires
05-04-2007, 06:08
Post: #61
tires
Pete's Tire Service in Fullerton, on Orangethorpe, W/of State College. Call
their Corona store too....I got slightly cheaper prices at the Corona store for the same tires. They also do general maintenance stuff, like oil changes, coolant exchange, brakes and suspension stuff. Kevin McKeown Yorba Linda, CA 86 38 PT ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
05-04-2007, 09:32
Post: #62
tires
Not unexpectedly, I'm going to need 6 tires for my newly purchased
PT 36. Does anyone have suggestions on where to purchase them in the inland or Orange county area? Art Weatherly Riverside Ca '85 PT 36 |
05-04-2007, 09:50
Post: #63
tires
Art,
Try Pete's Road Service. http://www.petesrs.com/ Call the Fullerton, Corona, Fontana stores. Prices do vary. I had the Fullerton store install Toyo's on our 'Birds. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. amweath wrote: > Not unexpectedly, I'm going to need 6 tires for my newly purchased > PT 36. Does anyone have suggestions on where to purchase them in > the inland or Orange county area? > > Art Weatherly > Riverside Ca > '85 PT 36 > > |
05-04-2007, 11:19
Post: #64
tires
It may well be worthwhile to drive to the nearest Les Schwab tire
dealer. Good prices and excellent service. The previous owner of my coach purchased a set of tires at Les Schwab ... and I discovered a flat on my duals within a hundred yards of a Les Schwab dealer in Willits, CA. They spent some time unmounting and checking the tire -- turned out it was a bad valve. Reinstalled and got me going again. No charge. Right, no charge. Two employees spent most of 2 hours jacking up the coach and wrestling with the tire ... no charge. Just a "thank you" for buying the tires from us. Some years ago, I had a flat with my car and happened into a Les Schwab dealer in Oregon. (It didn't take nearly as long.) Still, no charge for fixing the flat ... and a "remember us" when you next need tires. I wish a Les Schwab dealer was closer to my home for my cars... -- but I'll surely go there for the coach when it needs tires. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Lockhart Texas On May 4, 2007, at 4:32 PM, amweath wrote: > Not unexpectedly, I'm going to need 6 tires for my newly purchased > PT 36. Does anyone have suggestions on where to purchase them in > the inland or Orange county area? > > Art Weatherly > Riverside Ca > '85 PT 36 |
05-04-2007, 15:25
Post: #65
tires
I went to Les Schwab..I'm sure they are in your area.
Got all new rubber (went with Oshei brand)for around 230 bucks a tire. We use these on the big rigs. Lasts over 50k miles, no problem. Half the price of the other brands. Bob Lawrence 84 PT36 Tacoma, Wa. > > Not unexpectedly, I'm going to need 6 tires for my newly purchased > PT 36. Does anyone have suggestions on where to purchase them in > the inland or Orange county area? > > Art Weatherly > Riverside Ca > '85 PT 36 > |
08-24-2007, 07:54
Post: #66
tires
I am looking at purchasing some Dunlop SP 160's 10.00 R x 20 for the
rear of my 77 FC. The date of manufacture on the tires i found is march of 2007. Is there anything else i should look at such as load rating, etc. I am new to the big truck world and would appreciate any good tire info... Is anyone familiar with these tires? Thanks, jim sears |
08-24-2007, 08:12
Post: #67
tires
Jim weigh your coach or at least go by the gross axel wt listed in the
coaches literature. With the weight or axel gvw then to to Dunlop site and look up the appropriate tire for your weight. If Dunlop does not have such a chart then I would go to Michelin's guide and check out tire rating under the size tire you are looking at. Are 20" the correct size for your bird? On 24/08/07, jimbojcs > > I am looking at purchasing some Dunlop SP 160's 10.00 R x 20 for the > rear of my 77 FC. The date of manufacture on the tires i found is > march of 2007. Is there anything else i should look at such as load > rating, etc. I am new to the big truck world and would appreciate any > good tire info... Is anyone familiar with these tires? Thanks, jim > sears > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
08-24-2007, 08:53
Post: #68
tires
The load rating should exceed the maximum weight allowed for the axle
(we assume you don't overload your coach). You should find the axle rating in your blue box (if you have it). Divide that by 4 (for the number of tires) to get the individual tire loads. Add some more for a safety factor. Since I'm not so familiar with early FCs, I thought all 'birds had 22.5 size wheels... but that might be more recent models. Most use an 11 or 12R x 22.5 depending on year. You might be able to find a weight rating chart on the tire manufacturer's web site. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Aug 24, 2007, at 12:54 PM, jimbojcs wrote: > I am looking at purchasing some Dunlop SP 160's 10.00 R x 20 for the > rear of my 77 FC. The date of manufacture on the tires i found is > march of 2007. Is there anything else i should look at such as load > rating, etc. I am new to the big truck world and would appreciate any > good tire info... Is anyone familiar with these tires? Thanks, jim > sears > [Non-text portions of this message have been removed] |
08-24-2007, 08:54
Post: #69
tires
I have 22.5 on front and 24.5 on rear. Weird.
Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
08-24-2007, 09:36
Post: #70
tires
> > The load rating should exceed the maximum weight allowed for the axle > (we assume you don't overload your coach). You should find the axle > rating in your blue box (if you have it). Divide that by 4 (for the > number of tires) to get the individual tire loads. Add some more for > a safety factor. Since I'm not so familiar with early FCs, I thought > all 'birds had 22.5 size wheels... but that might be more recent > models. Most use an 11 or 12R x 22.5 depending on year. > > You might be able to find a weight rating chart on the tire > manufacturer's web site. > I guess i have to do a little more research...My bus has alluminum wheels front and rear. The front wheels are 22.5 and the rear wheels are 20's. It doesn't look like a 22.5 would fit properly under the rear, but maybe someone put 20's on because that was all they had.....like i said, i'll have to do some more research on my particular model. > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Aug 24, 2007, at 12:54 PM, jimbojcs wrote: > > > I am looking at purchasing some Dunlop SP 160's 10.00 R x 20 for the > > rear of my 77 FC. The date of manufacture on the tires i found is > > march of 2007. Is there anything else i should look at such as load > > rating, etc. I am new to the big truck world and would appreciate any > > good tire info... Is anyone familiar with these tires? Thanks, jim > > sears > > > > > > [Non-text portions of this message have been removed] > |
