wind noise
05-08-2007, 04:39
wind noise
I have what I consider excessive wind noise from both driver and passenger
windows at highway speed. Is this "normal" or common? Known fixes?
Don Bradner
90 PT40 "Blue Thunder"
Posting on the road by satellite from
Kelso, Washington
05-08-2007, 07:09
wind noise
You may need to renew the weather stripping in the window. I have a
pesky air leak in the driver's side window that goes away when I
press on the glass with my hand (making the seal tighter).
Pete Masterson
aeonix1@...
El Sobrante, CA
> passenger windows at highway speed. Is this "normal" or common?
> Known fixes?
> Don Bradner
> Kelso, Washington
05-08-2007, 07:36
wind noise
It may be coming from the door seal. I think at the factory they put a two by
four between the door and frame and push on the door. I have that problem and
I've considered putting another deadbolt up higher on the door to pull it in.
Dan
88PT38
Jackson, MS
To: wanderlodgeforum@yahoogroups.com
Sent: Tuesday, May 08, 2007 11:39 AM
Subject: [WanderlodgeForum] wind noise
Don Bradner
Kelso, Washington
Checked by AVG Free Edition.
Version: 7.5.467 / Virus Database: 269.6.5/793 - Release Date: 5/7/2007 2:55
PM
05-08-2007, 11:29
wind noise
a
> Pete Masterson
> aeonix1@...
> El Sobrante, CA
> > Known fixes?
> > Don Bradner
> > Kelso, Washington
> I had the same problem and built two stainless steel wind defletors
and mounted them ahead of the windows. No wind noise until 80 Mph
relative wind speed. If you are interested I will post a photo
Jim Hutchings
83 FCRB 250 HP cat
05-08-2007, 14:01
wind noise
Sure, always interested in what others have done.
On mine, and I don't know how common window designs are, the sliding windows
have a groove that has a pile-type weather strip that goes around a metal
"blade" above, below, and at the forward edge of the frame. I don't see any way
to renew that strip.
There is, in the channels to each side of the forward "blade," foam
weatherstripping. This looks like it was an add-on, presumably for the same
noise reason. It is old, dry, cracked, and not doing its job. I went to a large
hardware store today to buy some of the same stuff, and nearly did (1/8 thick,
1/4 wide foam), but then I spotted some 1/4-inch wide pile stripping, and
decided to go with that. The old foam came out fairly easily, and the pile went
in easily. It will be a couple of days before we move again, so I won't know
until then if the fix worked.
05-08-2007, 14:29
wind noise
You can replace the fur strip
Stephen 77fc35
windows have a groove that has a pile-type weather strip that goes
around a metal "blade" above, below, and at the forward edge of the
frame. I don't see any way to renew that strip.
same noise reason. It is old, dry, cracked, and not doing its job. I
went to a large hardware store today to buy some of the same stuff,
and nearly did (1/8 thick, 1/4 wide foam), but then I spotted some
1/4-inch wide pile stripping, and decided to go with that. The old
foam came out fairly easily, and the pile went in easily. It will be a
couple of days before we move again, so I won't know until then if the
fix worked.
05-08-2007, 14:37
wind noise
Sent: Tuesday, May 08, 2007 9:01 PM
Subject: Re: [WanderlodgeForum] Re: wind noise
I also have them plus one for the door.
Bob Loomas 1985 PT 36
05-08-2007, 14:58
wind noise
OK, I'll bite. Assuming the strip is easy to buy, how do you get the window out
of the track, and back in after replacing the strip?
05-09-2007, 02:22
wind noise
Yes, post a picture. Might save the job of disassembling the window
to renew the weather seals.
Pete Masterson
aeonix1@...
On the road at Lockhart Texas
> a
>> <snip>
> Jim Hutchings
> 83 FCRB 250 HP cat
05-09-2007, 06:00
wind noise
I'd like to see these, too, Jim.
-Ryan
'86 PT-40 8V92
Tri-Cities, WA
