Installing new guage.
05-10-2007, 06:44
I have recieved a new engine oil temp guage from the fellow I bought
my coach from. Now to install it. The guage is on the verticle part of the dash panel.Has anyone been into that panel? Any advise will be better than me going in there blind! Art Weatherly Riverside Ca. '85 PT36 |
05-10-2007, 07:07
Hi Art:
**CAUTION** **CAUTION** Remove the 4 bottom out side covers of the lower dash. If the lower dash has been out before then it should lift up from the front edge and slip forward a little. If it has not been out before then on the left side of the lower dash, under one of the blank covers, will be a screw that has to come out. Now, with the lower dash panel slid forward, remove the cb mic from the holder and take the long screw out that holds the cb mic holder. Now the upper lower dash should be free on that side and if it has been removed it will probably be free to tilt forward. If it has not been out before then you need a looooong phillips screwdriver, hold the right side of the upper lower dash out and reach in with the long phillips and un screw the far left L bracket. In the bottom center of the upper lower dash, after the lower panel is moved forward you should see a screw that needs to come out as well. Now your upper lower dash panel should be free to tilt forward. **CAUTION** Do NOT force it, if it won't come out enough to replace the gauge, find what is holding it. I cannot stress **CAUTION** enough on this. While your in there, remove the light sockets with the lamps from the other gauges and clean or replace them. Your going to find a "rats nest" of wiring under and behind both panels. Remember if you drill, spindle or pierce any of those panels, they are shot and cannot be brought back. Use only holes provided for screws and such. Good luck Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 06:44 PM 5/10/2007 +0000, you wrote: >I have recieved a new engine oil temp guage from the fellow I bought >my coach from. Now to install it. The guage is on the verticle part of >the dash panel.Has anyone been into that panel? Any advise will be >better than me going in there blind! > > >Art Weatherly >Riverside Ca. >'85 PT36 > > > |
05-11-2007, 08:43
I have just replace my oil temp guage. I got it from BB and it is indexed
differently from the original one. I needed to get a new temp sending switch also... Jim Riordan 88 WBWL XXV Stuart, Fl. "Ralph L. Fullenwider" Hi Art: **CAUTION** **CAUTION** Remove the 4 bottom out side covers of the lower dash. If the lower dash has been out before then it should lift up from the front edge and slip forward a little. If it has not been out before then on the left side of the lower dash, under one of the blank covers, will be a screw that has to come out. Now, with the lower dash panel slid forward, remove the cb mic from the holder and take the long screw out that holds the cb mic holder. Now the upper lower dash should be free on that side and if it has been removed it will probably be free to tilt forward. If it has not been out before then you need a looooong phillips screwdriver, hold the right side of the upper lower dash out and reach in with the long phillips and un screw the far left L bracket. In the bottom center of the upper lower dash, after the lower panel is moved forward you should see a screw that needs to come out as well. Now your upper lower dash panel should be free to tilt forward. **CAUTION** Do NOT force it, if it won't come out enough to replace the gauge, find what is holding it. I cannot stress **CAUTION** enough on this. While your in there, remove the light sockets with the lamps from the other gauges and clean or replace them. Your going to find a "rats nest" of wiring under and behind both panels. Remember if you drill, spindle or pierce any of those panels, they are shot and cannot be brought back. Use only holes provided for screws and such. Good luck Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 06:44 PM 5/10/2007 +0000, you wrote: >I have recieved a new engine oil temp guage from the fellow I bought >my coach from. Now to install it. The guage is on the verticle part of >the dash panel.Has anyone been into that panel? Any advise will be >better than me going in there blind! > > >Art Weatherly >Riverside Ca. >'85 PT36 > > > --------------------------------- Moody friends. Drama queens. Your life? Nope! - their life, your story. Play Sims Stories at Yahoo! Games. [Non-text portions of this message have been removed] |
05-11-2007, 11:37
Jim,
I replaced both oil temp gages on our 88 FC ( 3208 oil and rear axle temps) BB gage part number 54438, It is a Teleflex gage. If this is your gage the temp sensor is a Stewart-Warner, part number 280EEF . It is available at truck parts stores. It has several threaded bushings for all thread sizes, One will match the original threads. BB did not have the correct sensor. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, jim riordan wrote: > > I have just replace my oil temp guage. I got it from BB and it is indexed differently from the original one. I needed to get a new temp sending switch also... > > Jim Riordan > 88 WBWL XXV > Stuart, Fl. > > "Ralph L. Fullenwider" > Hi Art: > > **CAUTION** **CAUTION** > > Remove the 4 bottom out side covers of the lower dash. If the lower dash > has been out before then it should lift up from the front edge and slip > forward a little. If it has not been out before then on the left side of > the lower dash, under one of the blank covers, will be a screw that has to > come out. > > Now, with the lower dash panel slid forward, remove the cb mic from the > holder and take the long screw out that holds the cb mic holder. Now the > upper lower dash should be free on that side and if it has been removed it > will probably be free to tilt forward. If it has not been out before then > you need a looooong phillips screwdriver, hold the right side of the upper > lower dash out and reach in with the long phillips and un screw the far > left L bracket. In the bottom center of the upper lower dash, after the > lower panel is moved forward you should see a screw that needs to come out > as well. Now your upper lower dash panel should be free to tilt forward. > **CAUTION** Do NOT force it, if it won't come out enough to replace the > gauge, find what is holding it. I cannot stress **CAUTION** enough on this. > > While your in there, remove the light sockets with the lamps from the other > gauges and clean or replace them. > > Your going to find a "rats nest" of wiring under and behind both panels. > Remember if you drill, spindle or pierce any of those panels, they are shot > and cannot be brought back. Use only holes provided for screws and such. > > Good luck > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Ralph's RV Solutions, Duncan, Oklahoma > > At 06:44 PM 5/10/2007 +0000, you wrote: > >I have recieved a new engine oil temp guage from the fellow I bought > >my coach from. Now to install it. The guage is on the verticle part of > >the dash panel.Has anyone been into that panel? Any advise will be > >better than me going in there blind! > > > > > >Art Weatherly > >Riverside Ca. > >'85 PT36 > > > > > > > > > > > > > --------------------------------- > Moody friends. Drama queens. Your life? Nope! - their life, your story. > Play Sims Stories at Yahoo! Games. > > [Non-text portions of this message have been removed] > |
05-12-2007, 01:20
Thanks,
The new guage is not a 54438 Earl said the did not maske it anymore. He sent me a "superseded" one the index numbers were different. He sent me a new sensor it was for the old type guage it was reading 40% high. I called Teleflex spoke to Joe Federsal (great help) he sent me the correct sensor for the guage that I got from earl, everything seems to work now. This new guage 9153278 is improved in that it first register point is at 140 rather than 100, top is 320 like the old one. the end result is that the gauge will provide more accurate readings in the operational range than the old one. I hope! Jim RIordan 88 WBWL XXV Stuart, Fl. pattypape Jim, I replaced both oil temp gages on our 88 FC ( 3208 oil and rear axle temps) BB gage part number 54438, It is a Teleflex gage. If this is your gage the temp sensor is a Stewart-Warner, part number 280EEF . It is available at truck parts stores. It has several threaded bushings for all thread sizes, One will match the original threads. BB did not have the correct sensor. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, jim riordan wrote: > > I have just replace my oil temp guage. I got it from BB and it is indexed differently from the original one. I needed to get a new temp sending switch also... > > Jim Riordan > 88 WBWL XXV > Stuart, Fl. > > "Ralph L. Fullenwider" > Hi Art: > > **CAUTION** **CAUTION** > > Remove the 4 bottom out side covers of the lower dash. If the lower dash > has been out before then it should lift up from the front edge and slip > forward a little. If it has not been out before then on the left side of > the lower dash, under one of the blank covers, will be a screw that has to > come out. > > Now, with the lower dash panel slid forward, remove the cb mic from the > holder and take the long screw out that holds the cb mic holder. Now the > upper lower dash should be free on that side and if it has been removed it > will probably be free to tilt forward. If it has not been out before then > you need a looooong phillips screwdriver, hold the right side of the upper > lower dash out and reach in with the long phillips and un screw the far > left L bracket. In the bottom center of the upper lower dash, after the > lower panel is moved forward you should see a screw that needs to come out > as well. Now your upper lower dash panel should be free to tilt forward. > **CAUTION** Do NOT force it, if it won't come out enough to replace the > gauge, find what is holding it. I cannot stress **CAUTION** enough on this. > > While your in there, remove the light sockets with the lamps from the other > gauges and clean or replace them. > > Your going to find a "rats nest" of wiring under and behind both panels. > Remember if you drill, spindle or pierce any of those panels, they are shot > and cannot be brought back. Use only holes provided for screws and such. > > Good luck > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Ralph's RV Solutions, Duncan, Oklahoma > > At 06:44 PM 5/10/2007 +0000, you wrote: > >I have recieved a new engine oil temp guage from the fellow I bought > >my coach from. Now to install it. The guage is on the verticle part of > >the dash panel.Has anyone been into that panel? Any advise will be > >better than me going in there blind! > > > > > >Art Weatherly > >Riverside Ca. > >'85 PT36 > > > > > > > > > > > > > --------------------------------- > Moody friends. Drama queens. Your life? Nope! - their life, your story. > Play Sims Stories at Yahoo! Games. > > [Non-text portions of this message have been removed] > --------------------------------- Be a PS3 game guru. Get your game face on with the latest PS3 news and previews at Yahoo! Games. [Non-text portions of this message have been removed] |
05-12-2007, 02:36
Jim,
Yep, that is the correct gage, Teleflex # 9153278. The BB# 54438 was still a good number, But they shipped the updated 9153278 gage , Then the temp would read really high, That is why there is a lot of confusion , when replacing gages, the sensor must be replaced also. I like the new scale for the oil temp,200 to 230 Not so good for the rear axle because, it only heats up to about 140 to 170. lowest part of the gage. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, jim riordan wrote: > > Thanks, > > The new guage is not a 54438 Earl said the did not maske it anymore. He sent me a "superseded" one the index numbers were different. He sent me a new sensor it was for the old type guage it was reading 40% high. I called Teleflex spoke to Joe Federsal (great help) he sent me the correct sensor for the guage that I got from earl, everything seems to work now. This new guage 9153278 is improved in that it first register point is at 140 rather than 100, top is 320 like the old one. the end result is that the gauge will provide more accurate readings in the operational range than the old one. I hope! > > > Jim RIordan > 88 WBWL XXV > Stuart, Fl. > pattypape > > > Jim, > > I replaced both oil temp gages on our 88 FC ( 3208 oil and rear axle > temps) BB gage part number 54438, It is a Teleflex gage. > > If this is your gage the temp sensor is a Stewart-Warner, part > number 280EEF . It is available at truck parts stores. It has > several threaded bushings for all thread sizes, One will match the > original threads. BB did not have the correct sensor. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com, jim riordan > wrote: > > > > I have just replace my oil temp guage. I got it from BB and it is > indexed differently from the original one. I needed to get a new temp > sending switch also... > > > > Jim Riordan > > 88 WBWL XXV > > Stuart, Fl. > > > > "Ralph L. Fullenwider" > > Hi Art: > > > > **CAUTION** **CAUTION** > > > > Remove the 4 bottom out side covers of the lower dash. If the lower > dash > > has been out before then it should lift up from the front edge and > slip > > forward a little. If it has not been out before then on the left > side of > > the lower dash, under one of the blank covers, will be a screw that > has to > > come out. > > > > Now, with the lower dash panel slid forward, remove the cb mic from > the > > holder and take the long screw out that holds the cb mic holder. > Now the > > upper lower dash should be free on that side and if it has been > removed it > > will probably be free to tilt forward. If it has not been out > before then > > you need a looooong phillips screwdriver, hold the right side of > the upper > > lower dash out and reach in with the long phillips and un screw the > far > > left L bracket. In the bottom center of the upper lower dash, after > the > > lower panel is moved forward you should see a screw that needs to > come out > > as well. Now your upper lower dash panel should be free to tilt > forward. > > **CAUTION** Do NOT force it, if it won't come out enough to replace > the > > gauge, find what is holding it. I cannot stress **CAUTION** enough > on this. > > > > While your in there, remove the light sockets with the lamps from > the other > > gauges and clean or replace them. > > > > Your going to find a "rats nest" of wiring under and behind both > panels. > > Remember if you drill, spindle or pierce any of those panels, they > are shot > > and cannot be brought back. Use only holes provided for screws and > such. > > > > Good luck > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 > > Ralph's RV Solutions, Duncan, Oklahoma > > > > At 06:44 PM 5/10/2007 +0000, you wrote: > > >I have recieved a new engine oil temp guage from the fellow I > bought > > >my coach from. Now to install it. The guage is on the verticle > part of > > >the dash panel.Has anyone been into that panel? Any advise will be > > >better than me going in there blind! > > > > > > > > >Art Weatherly > > >Riverside Ca. > > >'85 PT36 > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > Moody friends. Drama queens. Your life? Nope! - their life, your > story. > > Play Sims Stories at Yahoo! Games. > > > > [Non-text portions of this message have been removed] > > > > > > > > > --------------------------------- > Be a PS3 game guru. > Get your game face on with the latest PS3 news and previews at Yahoo! Games. > > [Non-text portions of this message have been removed] > |
05-12-2007, 07:43
Jim could you post that phone number for Teleflex
On 12/05/07, jim riordan > > Thanks, > > The new guage is not a 54438 Earl said the did not maske it anymore. He > sent me a "superseded" one the index numbers were different. He sent me a > new sensor it was for the old type guage it was reading 40% high. I called > Teleflex spoke to Joe Federsal (great help) he sent me the correct sensor > for the guage that I got from earl, everything seems to work now. This new > guage 9153278 is improved in that it first register point is at 140 rather > than 100, top is 320 like the old one. the end result is that the gauge will > provide more accurate readings in the operational range than the old one. I > hope! > > Jim RIordan > 88 WBWL XXV > Stuart, Fl. > pattypape > > > Jim, > > I replaced both oil temp gages on our 88 FC ( 3208 oil and rear axle > temps) BB gage part number 54438, It is a Teleflex gage. > > If this is your gage the temp sensor is a Stewart-Warner, part > number 280EEF . It is available at truck parts stores. It has > several threaded bushings for all thread sizes, One will match the > original threads. BB did not have the correct sensor. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com > jim riordan > wrote: > > > > I have just replace my oil temp guage. I got it from BB and it is > indexed differently from the original one. I needed to get a new temp > sending switch also... > > > > Jim Riordan > > 88 WBWL XXV > > Stuart, Fl. > > > > "Ralph L. Fullenwider" > > Hi Art: > > > > **CAUTION** **CAUTION** > > > > Remove the 4 bottom out side covers of the lower dash. If the lower > dash > > has been out before then it should lift up from the front edge and > slip > > forward a little. If it has not been out before then on the left > side of > > the lower dash, under one of the blank covers, will be a screw that > has to > > come out. > > > > Now, with the lower dash panel slid forward, remove the cb mic from > the > > holder and take the long screw out that holds the cb mic holder. > Now the > > upper lower dash should be free on that side and if it has been > removed it > > will probably be free to tilt forward. If it has not been out > before then > > you need a looooong phillips screwdriver, hold the right side of > the upper > > lower dash out and reach in with the long phillips and un screw the > far > > left L bracket. In the bottom center of the upper lower dash, after > the > > lower panel is moved forward you should see a screw that needs to > come out > > as well. Now your upper lower dash panel should be free to tilt > forward. > > **CAUTION** Do NOT force it, if it won't come out enough to replace > the > > gauge, find what is holding it. I cannot stress **CAUTION** enough > on this. > > > > While your in there, remove the light sockets with the lamps from > the other > > gauges and clean or replace them. > > > > Your going to find a "rats nest" of wiring under and behind both > panels. > > Remember if you drill, spindle or pierce any of those panels, they > are shot > > and cannot be brought back. Use only holes provided for screws and > such. > > > > Good luck > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 > > Ralph's RV Solutions, Duncan, Oklahoma > > > > At 06:44 PM 5/10/2007 +0000, you wrote: > > >I have recieved a new engine oil temp guage from the fellow I > bought > > >my coach from. Now to install it. The guage is on the verticle > part of > > >the dash panel.Has anyone been into that panel? Any advise will be > > >better than me going in there blind! > > > > > > > > >Art Weatherly > > >Riverside Ca. > > >'85 PT36 > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > Moody friends. Drama queens. Your life? Nope! - their life, your > story. > > Play Sims Stories at Yahoo! Games. > > > > [Non-text portions of this message have been removed] > > > > --------------------------------- > Be a PS3 game guru. > Get your game face on with the latest PS3 news and previews at Yahoo! > Games. > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
05-12-2007, 08:38
From: Rob Robinson To: WanderlodgeForum@yahoogroups.com Sent: Saturday, May 12, 2007 2:43 PM Subject: Re: [WanderlodgeForum] Re: Installing new guage. # for Teleflex 941 907 1000 Bob Loomas 1985 PT 36 Jim could you post that phone number for Teleflex On 12/05/07, jim riordan > > Thanks, > > The new guage is not a 54438 Earl said the did not maske it anymore. He > sent me a "superseded" one the index numbers were different. He sent me a > new sensor it was for the old type guage it was reading 40% high. I called > Teleflex spoke to Joe Federsal (great help) he sent me the correct sensor > for the guage that I got from earl, everything seems to work now. This new > guage 9153278 is improved in that it first register point is at 140 rather > than 100, top is 320 like the old one. the end result is that the gauge will > provide more accurate readings in the operational range than the old one. I > hope! > > Jim RIordan > 88 WBWL XXV > Stuart, Fl. > pattypape > > > Jim, > > I replaced both oil temp gages on our 88 FC ( 3208 oil and rear axle > temps) BB gage part number 54438, It is a Teleflex gage. > > If this is your gage the temp sensor is a Stewart-Warner, part > number 280EEF . It is available at truck parts stores. It has > several threaded bushings for all thread sizes, One will match the > original threads. BB did not have the correct sensor. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com > jim riordan > wrote: > > > > I have just replace my oil temp guage. I got it from BB and it is > indexed differently from the original one. I needed to get a new temp > sending switch also... > > > > Jim Riordan > > 88 WBWL XXV > > Stuart, Fl. > > > > "Ralph L. Fullenwider" > > Hi Art: > > > > **CAUTION** **CAUTION** > > > > Remove the 4 bottom out side covers of the lower dash. If the lower > dash > > has been out before then it should lift up from the front edge and > slip > > forward a little. If it has not been out before then on the left > side of > > the lower dash, under one of the blank covers, will be a screw that > has to > > come out. > > > > Now, with the lower dash panel slid forward, remove the cb mic from > the > > holder and take the long screw out that holds the cb mic holder. > Now the > > upper lower dash should be free on that side and if it has been > removed it > > will probably be free to tilt forward. If it has not been out > before then > > you need a looooong phillips screwdriver, hold the right side of > the upper > > lower dash out and reach in with the long phillips and un screw the > far > > left L bracket. In the bottom center of the upper lower dash, after > the > > lower panel is moved forward you should see a screw that needs to > come out > > as well. Now your upper lower dash panel should be free to tilt > forward. > > **CAUTION** Do NOT force it, if it won't come out enough to replace > the > > gauge, find what is holding it. I cannot stress **CAUTION** enough > on this. > > > > While your in there, remove the light sockets with the lamps from > the other > > gauges and clean or replace them. > > > > Your going to find a "rats nest" of wiring under and behind both > panels. > > Remember if you drill, spindle or pierce any of those panels, they > are shot > > and cannot be brought back. Use only holes provided for screws and > such. > > > > Good luck > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 > > Ralph's RV Solutions, Duncan, Oklahoma > > > > At 06:44 PM 5/10/2007 +0000, you wrote: > > >I have recieved a new engine oil temp guage from the fellow I > bought > > >my coach from. Now to install it. The guage is on the verticle > part of > > >the dash panel.Has anyone been into that panel? Any advise will be > > >better than me going in there blind! > > > > > > > > >Art Weatherly > > >Riverside Ca. > > >'85 PT36 > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > Moody friends. Drama queens. Your life? Nope! - their life, your > story. > > Play Sims Stories at Yahoo! Games. > > > > [Non-text portions of this message have been removed] > > > > --------------------------------- > Be a PS3 game guru. > Get your game face on with the latest PS3 news and previews at Yahoo! > Games. > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
05-12-2007, 09:01
Rob , This is the web site
http://www.teleflexmarine.com/cgi-bin/frameset2.cgi? site=gauges&type=us&link2=1047 Teleflex Gage troubleshooting guide and the tech support phone number at the bottom of the page. Ask for Joe , he is very helpful. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Jim could you post that phone number for Teleflex > > On 12/05/07, jim riordan > > > > Thanks, > > > > The new guage is not a 54438 Earl said the did not maske it anymore. He > > sent me a "superseded" one the index numbers were different. He sent me a > > new sensor it was for the old type guage it was reading 40% high. I called > > Teleflex spoke to Joe Federsal (great help) he sent me the correct sensor > > for the guage that I got from earl, everything seems to work now. This new > > guage 9153278 is improved in that it first register point is at 140 rather > > than 100, top is 320 like the old one. the end result is that the gauge will > > provide more accurate readings in the operational range than the old one. I > > hope! > > > > Jim RIordan > > 88 WBWL XXV > > Stuart, Fl. > > pattypape > > > > > > Jim, > > > > I replaced both oil temp gages on our 88 FC ( 3208 oil and rear axle > > temps) BB gage part number 54438, It is a Teleflex gage. > > > > If this is your gage the temp sensor is a Stewart-Warner, part > > number 280EEF . It is available at truck parts stores. It has > > several threaded bushings for all thread sizes, One will match the > > original threads. BB did not have the correct sensor. > > > > Bill 88 FC Michigan > > > > --- In WanderlodgeForum@yahoogroups.com > > jim riordan > > wrote: > > > > > > I have just replace my oil temp guage. I got it from BB and it is > > indexed differently from the original one. I needed to get a new temp > > sending switch also... > > > > > > Jim Riordan > > > 88 WBWL XXV > > > Stuart, Fl. > > > > > > "Ralph L. Fullenwider" > > > Hi Art: > > > > > > **CAUTION** **CAUTION** > > > > > > Remove the 4 bottom out side covers of the lower dash. If the lower > > dash > > > has been out before then it should lift up from the front edge and > > slip > > > forward a little. If it has not been out before then on the left > > side of > > > the lower dash, under one of the blank covers, will be a screw that > > has to > > > come out. > > > > > > Now, with the lower dash panel slid forward, remove the cb mic from > > the > > > holder and take the long screw out that holds the cb mic holder. > > Now the > > > upper lower dash should be free on that side and if it has been > > removed it > > > will probably be free to tilt forward. If it has not been out > > before then > > > you need a looooong phillips screwdriver, hold the right side of > > the upper > > > lower dash out and reach in with the long phillips and un screw the > > far > > > left L bracket. In the bottom center of the upper lower dash, after > > the > > > lower panel is moved forward you should see a screw that needs to > > come out > > > as well. Now your upper lower dash panel should be free to tilt > > forward. > > > **CAUTION** Do NOT force it, if it won't come out enough to replace > > the > > > gauge, find what is holding it. I cannot stress **CAUTION** enough > > on this. > > > > > > While your in there, remove the light sockets with the lamps from > > the other > > > gauges and clean or replace them. > > > > > > Your going to find a "rats nest" of wiring under and behind both > > panels. > > > Remember if you drill, spindle or pierce any of those panels, they > > are shot > > > and cannot be brought back. Use only holes provided for screws and > > such. > > > > > > Good luck > > > > > > Safe travels, > > > > > > Ralph and Charolette Fullenwider > > > 84FC35 > > > Ralph's RV Solutions, Duncan, Oklahoma > > > > > > At 06:44 PM 5/10/2007 +0000, you wrote: > > > >I have recieved a new engine oil temp guage from the fellow I > > bought > > > >my coach from. Now to install it. The guage is on the verticle > > part of > > > >the dash panel.Has anyone been into that panel? Any advise will be > > > >better than me going in there blind! > > > > > > > > > > > >Art Weatherly > > > >Riverside Ca. > > > >'85 PT36 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > Moody friends. Drama queens. Your life? Nope! - their life, your > > story. > > > Play Sims Stories at Yahoo! Games. > > > > > > [Non-text portions of this message have been removed] > > > > > > > --------------------------------- > > Be a PS3 game guru. > > Get your game face on with the latest PS3 news and previews at Yahoo! > > Games. > > > > [Non-text portions of this message have been removed] > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > |
05-12-2007, 12:02
Thanks Bob. Much appreciated
On 12/05/07, bloomas > > > ----- Original Message ----- > From: Rob Robinson > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, May 12, 2007 2:43 PM > Subject: Re: [WanderlodgeForum] Re: Installing new > guage. > > # for Teleflex > > 941 907 1000 > Bob Loomas 1985 PT 36 > > Jim could you post that phone number for Teleflex > > On 12/05/07, jim riordan > > > > Thanks, > > > > The new guage is not a 54438 Earl said the did not maske it anymore. He > > sent me a "superseded" one the index numbers were different. He sent me > a > > new sensor it was for the old type guage it was reading 40% high. I > called > > Teleflex spoke to Joe Federsal (great help) he sent me the correct > sensor > > for the guage that I got from earl, everything seems to work now. This > new > > guage 9153278 is improved in that it first register point is at 140 > rather > > than 100, top is 320 like the old one. the end result is that the gauge > will > > provide more accurate readings in the operational range than the old > one. I > > hope! > > > > Jim RIordan > > 88 WBWL XXV > > Stuart, Fl. > > pattypape > > > > > > Jim, > > > > I replaced both oil temp gages on our 88 FC ( 3208 oil and rear axle > > temps) BB gage part number 54438, It is a Teleflex gage. > > > > If this is your gage the temp sensor is a Stewart-Warner, part > > number 280EEF . It is available at truck parts stores. It has > > several threaded bushings for all thread sizes, One will match the > > original threads. BB did not have the correct sensor. > > > > Bill 88 FC Michigan > > > > --- In WanderlodgeForum@yahoogroups.com > > > jim riordan > > wrote: > > > > > > I have just replace my oil temp guage. I got it from BB and it is > > indexed differently from the original one. I needed to get a new temp > > sending switch also... > > > > > > Jim Riordan > > > 88 WBWL XXV > > > Stuart, Fl. > > > > > > "Ralph L. Fullenwider" > > > Hi Art: > > > > > > **CAUTION** **CAUTION** > > > > > > Remove the 4 bottom out side covers of the lower dash. If the lower > > dash > > > has been out before then it should lift up from the front edge and > > slip > > > forward a little. If it has not been out before then on the left > > side of > > > the lower dash, under one of the blank covers, will be a screw that > > has to > > > come out. > > > > > > Now, with the lower dash panel slid forward, remove the cb mic from > > the > > > holder and take the long screw out that holds the cb mic holder. > > Now the > > > upper lower dash should be free on that side and if it has been > > removed it > > > will probably be free to tilt forward. If it has not been out > > before then > > > you need a looooong phillips screwdriver, hold the right side of > > the upper > > > lower dash out and reach in with the long phillips and un screw the > > far > > > left L bracket. In the bottom center of the upper lower dash, after > > the > > > lower panel is moved forward you should see a screw that needs to > > come out > > > as well. Now your upper lower dash panel should be free to tilt > > forward. > > > **CAUTION** Do NOT force it, if it won't come out enough to replace > > the > > > gauge, find what is holding it. I cannot stress **CAUTION** enough > > on this. > > > > > > While your in there, remove the light sockets with the lamps from > > the other > > > gauges and clean or replace them. > > > > > > Your going to find a "rats nest" of wiring under and behind both > > panels. > > > Remember if you drill, spindle or pierce any of those panels, they > > are shot > > > and cannot be brought back. Use only holes provided for screws and > > such. > > > > > > Good luck > > > > > > Safe travels, > > > > > > Ralph and Charolette Fullenwider > > > 84FC35 > > > Ralph's RV Solutions, Duncan, Oklahoma > > > > > > At 06:44 PM 5/10/2007 +0000, you wrote: > > > >I have recieved a new engine oil temp guage from the fellow I > > bought > > > >my coach from. Now to install it. The guage is on the verticle > > part of > > > >the dash panel.Has anyone been into that panel? Any advise will be > > > >better than me going in there blind! > > > > > > > > > > > >Art Weatherly > > > >Riverside Ca. > > > >'85 PT36 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > Moody friends. Drama queens. Your life? Nope! - their life, your > > story. > > > Play Sims Stories at Yahoo! Games. > > > > > > [Non-text portions of this message have been removed] > > > > > > > --------------------------------- > > Be a PS3 game guru. > > Get your game face on with the latest PS3 news and previews at Yahoo! > > Games. > > > > [Non-text portions of this message have been removed] > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
