Side Camera
05-14-2007, 04:34
Side Camera
Leroy Let me know how your side camera works. Did you hook it up to
come on with the turn signal. I'm going to up grade mine.here soon. Did you
do the left & right or just the right?
Don
89 SP 36'
Butler, PA
05-14-2007, 08:59
Side Camera
I works very well. I did the right side only as I can see the left side ok. I
did not fool with the turn signal application because I want to see the right
hand dead spot constantly. A couple of weeks ago I installed a new rear view
camera, and two 3.5 high resoultion LCD screens, and fabricated a panel for the
dash. I used the existing on off switch from my old camera and removed the old
contrast brightess potentiometer.
I posted pictures in my 1990 upgrades photo section on the forum. I hope I have
them squared away. The first time I sent them sideways.
Leroy Eckert
1990 WB-40 "Smoke N Mirrors"
Niceville, FL
Sent: Monday, May 14, 2007 3:34 PM
Subject: [WanderlodgeForum] Side Camera
Don
89 SP 36'
Butler, PA
05-14-2007, 20:32
Side Camera
application because I want to see the right hand dead spot constantly. A
couple of weeks ago I installed a new rear view camera, and two 3.5 high
resoultion LCD screens, and fabricated a panel for the dash. I used the existing
on
off switch from my old camera and removed the old contrast brightess
potentiometer.
have them squared away. The first time I sent them sideways.
Leroy Eckert
Niceville, FL
05-14-2007, 20:40
Side Camera
Leroy How big is that panel that your cameras are in. I didn't know you
could put two in that space. You might have more room that mine. Is the
small screen easy to watch? What kind of camera did you get. The install looks
good Thanks
Don
89 SP 36'
Butler, PA
I did not fool with the turn signal application because I want to see the
right hand dead spot constantly. A couple of weeks ago I installed a new rear
view camera, and two 3.5 high resoultion LCD screens, and fabricated a panel
for the dash. I used the existing on off switch from my old camera and removed
the old contrast brightess potentiometer.
Leroy Eckert
Niceville, FL
05-15-2007, 06:21
Side Camera
Don: The opening is about 61/4x61/4 plus the angle is there which gives a little
more area. The LCD's have a clear well defined picture that is easy to see. When
I was having trouble with my old TV set/rear monitor I looked at several
different options. One, buy a prefabricated product, plug it in and go. Two,
buy the components and fabricate myself and have what I wanted. In either case
I had to modify the dash panel. The price was about the same. The parts I used
are as follows:
New technology Owls eye camera from http://www.owlseyecamera.com. A bit expensive but
outstanding quality.
Two 3.5 high resolution LCD from http://www.lcdshow.com.
One CC-45 sealed side camera from Steven Birtles http://www.capeinnovation.com I
already purchased all components before Steven began to inventory video parts.
Various connectors and adapters from Radio Shack. BNC, S-video, DVD power
adapters etc.
No matter what you ultimately decide to use, be certain that parts selected
operate in a voltage range or you will need a constant 12v power pack. In my
case, the old system was attached to a power pack, 13.5v in measured 11.9v out.
I hooked the cameras and LCD's to the constant voltage side and all is well.
You will also note that the LCD's I used can be inlaid in the panel because the
electronics are seperated and can be mounted on the back of the panel.
I hope to get lucky and mount the Tire monitor below the LCD's giving a nice
clean custom installation.
I now have an extra Owls eye camera that can be used inside on a system. Check
out that little camera, about as big as my thumb. I have not been able to drive
at night with the set up but have turned it on and the view is good.
If you want I send you the wiring diagram for what I did. It turned out to be a
pretty fun project.
Leroy Eckert
1990WB-40 "Smoke N Mirrors"
Niceville, FL
Sent: Tuesday, May 15, 2007 7:40 AM
Subject: Re: [WanderlodgeForum] Side Camera
good Thanks
Don
89 SP 36'
Butler, PA
Leroy Eckert
Niceville, FL
05-15-2007, 07:03
Side Camera
Don,
When I installed my voyager I removed the old crt and got a piece of Lexan for
the local plastic place, cut to fit the area covers the hole and then I velcroed
the monitor to the Lexan. works great. I also left room to mount Tom Tom go on
that piece of lexan. all close to see and read.
Jim Riordan
88 WBWL XXV
Stuart, Fl.
different options. One, buy a prefabricated product, plug it in and go. Two, buy
the components and fabricate myself and have what I wanted. In either case I had
to modify the dash panel. The price was about the same. The parts I used are as
follows:
adapters etc.
I hooked the cameras and LCD's to the constant voltage side and all is well. You
pretty fun project.
Leroy Eckert
Niceville, FL
good Thanks
Don
89 SP 36'
Butler, PA
Leroy Eckert
Niceville, FL
Building a website is a piece of cake.
Yahoo! Small Business gives you all the tools to get online.
05-15-2007, 10:47
Side Camera
Leroy I'm going to be doing carpet in the front of the coach & the sides
in the bed room this week. It just came in today. That will keep me busy for
a few days.
My opening is the same as yours so I guess I could do mine the same.
6-1/4" at the bottom. If I need some help on the wiring I'll give you a
shout. Thanks
Don
89 SP 36'
Butler, PA
little more area. The LCD's have a clear well defined picture that is easy to
see. When I was having trouble with my old TV set/rear monitor I looked at
several different options. One, buy a prefabricated product, plug it in and go.
Two, buy the components and fabricate myself and have what I wanted. In
either case I had to modify the dash panel. The price was about the same. The
parts I used are as follows:
New technology Owls eye camera from http://www.owlseyecamera.New technology Owls
Two 3.5 high resolution LCD from http://www.lcdshow.Two 3.5 h
One CC-45 sealed side camera from Steven Birtles http://www.capeinnovation.One
CC-45 sealed side camera from Steven Birtles [url]www.capeinnovation.com[/url] I
alrea
adapters etc.
out. I hooked the cameras and LCD's to the constant voltage side and all is
well. You will also note that the LCD's I used can be inlaid in the panel
because the electronics are seperated and can be mounted on the back of the
panel.
Check out that little camera, about as big as my thumb. I have not been able to
drive at night with the set up but have turned it on and the view is good.
be a pretty fun project.
Leroy Eckert
Niceville, FL
05-15-2007, 10:48
Side Camera
Good Idea Jim. If I get a surface mount that is way I will go.That would be
easy to work with.
Don
89 SP 36'
Butler, PA
Don,
for the local plastic place, cut to fit the area covers the hole and then I
velcroed the monitor to the Lexan. works great. I also left room to mount Tom
Tom go on that piece of lexan. all close to see and read.
Jim Riordan
88 WBWL XXV
Stuart, Fl.
05-15-2007, 15:08
Side Camera
Don, I do not envy you on that carpet deal. I just completed redoing mine Sunday
from the flood I had three weeks ago. My big body does not fit in small places
and it was not much fun. Next time I'm calling Ernie, no questions asked either
if you know what I mean.
Leroy Eckert
Niceville, FL
Sent: Tuesday, May 15, 2007 9:47 PM
a few days.
shout. Thanks
Don
89 SP 36'
Butler, PA
go.
alrea
adapters etc.
panel.
to
Leroy Eckert
Niceville, FL
