coolant sensor
05-02-2005, 19:02
coolant sensor
Bob, thanks for the input. I will try the same procedure. However, I would like
more information
as I have no experience with cannon plugs. Where are they located?? I have heard
that
you must have special pliers to remove some types of cannon plugs. How did you
remove yours? Also,
where did you purchase the tuner cleaner? Give me as much information
as you can as I have no idea where to begin. The ground straps are not a problem
as I previously installed
additional ones. Thanks for your help.
Gene Marshall, Dickinson, Texas 1988 PT40 WB
05-03-2005, 04:03
coolant sensor
I also have a 88 PT40 WB with the exact symtoms, must be a
manufactured problem.
Gene Shutt 88 PT40 WB
--- In WanderlodgeForum@yahoogroups.com, vmarshall@h... wrote:
> Andy, thanks for the reply. I forgot to mention in my post that my
engine light
> also comes on more often when I am climbing a long hill. Must be
something
> that is common with the 88 PT 40's. Hopefully between the two of us
we can find
> a solution to this problem and will not have to keep over filling
the coolant reservoir.
05-03-2005, 07:11
coolant sensor
would like more information
have heard that
How did you remove yours? Also,
not a problem as I previously installed
> Gene
Gene: The front of my 93 has a panel that come's off. under this
panel is the front electrical load center with all the cannon plugs
visable. Easy to get to and they just twist to seperate. I buy the
tuner spray cleaner at any radio shack store. Hope this help's..Bob
93pt illinois
05-03-2005, 08:48
coolant sensor
Thanks, I know the plugs you are talking about now. I did not realize that they
call them
cannon plugs. Thanks again.
05-03-2005, 09:54
coolant sensor
I also have a 1988 pt40 with the check engine light that comes on
when I pull a long hill,this has been constant for four years, The
code say low coolant when the tank is full. I have been into William
Detroit in Georgia and Phoenix, Detroit diesel shops in North
Dakota, Kansas, Missouri, Michigan, and more. The suggestions and
cures have ranged from poor ground, bad injectors, bad sender, to
duck tape over the lite. I now believe it must be a fault in the
computer or wiring or other magical places. But, if other 88 pt40
owners have the same problem it probably is a manufacuring flaw. If
anyone finds a cure please post it.
--- In WanderlodgeForum@yahoogroups.com, "gewans2"
my
> engine light
> something
us
> we can find
filling
05-03-2005, 12:50
coolant sensor
My 1988 PT40 does the same.
>when I pull a long hill,this has been constant for four years...
>my
> > engine light
> > something
>us
Dennis Nichols
'88 WB40 XXV
"Priscilla"
No virus found in this outgoing message.
Checked by AVG Anti-Virus.
Version: 7.0.308 / Virus Database: 266.11.2 - Release Date: 5/2/2005
07-05-2011, 08:45
coolant sensor
Does anyone know where to find a coolant sensor for a DDEC II 8V.
Mine has, I think, gone to it's great reward. You would think BB used better
parts than to only last 21 years.
90WBWL401/2 Jus Chillin
