Propane refrig.
05-28-2007, 04:57
Propane refrig.
Will the refrige, on propane, keep running during travel. If not, is
my main engine alternator w/inverter enough to power it on AC. I have
a Heart 2500 W inverter. Don't know how big the alternator is.
Art Weatherly
Riverside Ca
'85 PT36
05-28-2007, 05:06
Propane refrig.
Hi Art:
Yes, the refer should go to LP when the gen set is off and your not on
shore power. To run it off the inverter on ac you would have to re wire
some circuits, but there should be no need to do so.
Safe travels,
84FC35
Duncan, Oklahoma
>Art Weatherly
>Riverside Ca
>'85 PT36
05-28-2007, 12:48
Propane refrig.
Art, The one I have has a delay hooked up to bus ignition to keep the
pilot from striking a spark while fueling. The circuit board with the
defaults runs on 12v as does the interior light.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "amweath"
is
> Art Weatherly
> Riverside Ca
> '85 PT36
05-29-2007, 00:02
Propane refrig.
Yes.
SteveAnderson
79 FC 35
Poulsbo Wa
In a message dated 5/29/2007 8:52:50 AM Pacific Daylight Time,
amweatherly@... writes:
I wasn't clear enough with my question. Will the fridge keep working on
propane while driving down the road?
Art Weatherly
Riverside Ca.
'85 PT36
To: _WanderlodgeForum@WanderlodgeFWan_
(mailto:WanderlodgeForum@yahoogroups.com)
Sent: Monday, May 28, 2007 10:06 AM
Subject: [SPAM] Re: [WanderlodgeForum] Propane refrig.
Hi Art:
Safe travels,
84FC35
Duncan, Oklahoma
>Art Weatherly
>Riverside Ca
>'85 PT36
05-29-2007, 03:45
Propane refrig.
I wasn't clear enough with my question. Will the fridge keep working on propane
Art Weatherly
Riverside Ca.
'85 PT36
Hi Art:
Safe travels,
84FC35
Duncan, Oklahoma
>Art Weatherly
>Riverside Ca
>'85 PT36
05-29-2007, 03:59
Propane refrig.
Yes it will. I do it all the time.
Keith
84FC35
--- In WanderlodgeForum@yahoogroups.com, "Art Weatherly"
working on propane while driving down the road?
> Art Weatherly
> Riverside Ca.
> '85 PT36
> From: Ralph L. Fullenwider
> Hi Art:
not on
re wire
> Safe travels,
> 84FC35
> Duncan, Oklahoma
not, is
have
> >Art Weatherly
> >Riverside Ca
> >'85 PT36
05-29-2007, 04:10
Propane refrig.
Yes it will. You have to be sure that you have the setting on the eye brow
set to automatic. If it set to auto, it will seek 110 vac first then go to lp.
Safe travels,
84FC35
Duncan, Oklahoma
>Art Weatherly
>Riverside Ca.
>'85 PT36
> Hi Art:
> Safe travels,
> 84FC35
> Duncan, Oklahoma
> >Art Weatherly
> >Riverside Ca
> >'85 PT36
05-29-2007, 05:07
Propane refrig.
I guess you didn't get a straight answer, because that's what they're
designed to do. However, many years ago, I rented an RV where the
pilot light would blow out when on the road. I'd hope that newer
refrigerators would have electric spark for starting the burner
instead of a pilot light so that shouldn't be a problem. My coach has
a regular home-type refrigerator that runs off the inverter. Makes
boondocking a problem as it pulls down the batteries rather quickly.
Pete Masterson
aeonix1@...
El Sobrante, CA
<snip>
