Rear view camera
06-03-2007, 02:56
Rear view camera
My rear camera didn't work when I bought my coach, but last week I was
able to get it working just by cleaning some connectors and tightening some wired. Worked great, or at least as great as these original units work. I took a trip yesterday, though, and discovered that turning on the generator causes the screen to go to static. Anyone know a solution for this? Perhaps a ground or something? Thanks Scott Forman 86 PT38 |
06-03-2007, 07:23
Rear view camera
Scott,
My monitor would flicker real bad so I took the monitor out removed the boards and with a magnifying glass checked the solder joints. I had several cracked solder joints resoldered reinstalled and it works fine now. The plexiglass covering the rear camera had crazing all through it replaced the plexiglass and now have a sharp picture. Good luck. Howard Truitt Camilla, Ga. 86 PT40 > > From: "Scott Forman" <sforman@...> > Date: 2007/06/03 Sun AM 10:56:39 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Rear view camera > > My rear camera didn't work when I bought my coach, but last week I was > able to get it working just by cleaning some connectors and tightening > some wired. Worked great, or at least as great as these original units > work. > > I took a trip yesterday, though, and discovered that turning on the > generator causes the screen to go to static. Anyone know a solution > for this? Perhaps a ground or something? > > Thanks > Scott Forman > 86 PT38 > > > |
06-03-2007, 07:30
Rear view camera
Hi Scott:
Might want to take a look at the connections on the electronic filter unit under the drivers side sofa. Just a thought. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 02:56 PM 6/3/2007 +0000, you wrote: >My rear camera didn't work when I bought my coach, but last week I was >able to get it working just by cleaning some connectors and tightening >some wired. Worked great, or at least as great as these original units >work. > >I took a trip yesterday, though, and discovered that turning on the >generator causes the screen to go to static. Anyone know a solution >for this? Perhaps a ground or something? > >Thanks >Scott Forman >86 PT38 > > |
