Driver's overhead panel
06-04-2007, 12:21
Does the driver's overhead panel have a common ground or anything like
that? I have several little problems with things up there (safeline
buzzer will chirp on a good bump, left/right spotlight selector does
nothing, digital clock will re-set to 12:00 on a good bump, gen oil
press gauge reads high) and wondered if one thing might be causing all
of it.
Thanks
Scott Forman
86 PT38
06-04-2007, 12:41
I am going to guess and say yes simply because I know all of my gauge grounds
are strung together (green wires). I have never traced down the end of it all
but the nearest major ground to the overhead panel in my coach is the overhead
load center which is behind the cabinet above the drivers head. I have to remove
the back of the cabinet to access. Your coach is earlier than mine so that load
center may be somewhere else. Perhaps some else knows specifically.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Monday, June 04, 2007 7:21 PM
Subject: [WanderlodgeForum] Driver's overhead panel
of it.
Thanks
Scott Forman
86 PT38
