Fun with the Rebel Bird
06-10-2007, 04:28
--- In WanderlodgeForum@yahoogroups.com, "Jon"
> > --- In WanderlodgeForum@yahoogroups.com, dwalks@ wrote: > > > > Why??? however, Great drawing > > Walker > > 84FC35 > > kcmo > > > > > > > > ************************************** See what's free at > http://www.aol.com. > > > > > > [Non-text portions of this message have been removed] > > > > > And here is the Circus Wagon! That's what the name is on the front! > Shows rear end with a plateform. > http://tinyurl.com/2nnten And here is my original motor home it a 1951 Metro Van and I bought it in 1967 for 125 dollars. I have some pictures of the insides but as you could expect from that generation that it had flowered wallpaper and of course a pot bellied stove. I even had a bus drivers seat that had air ride. That's my beautiful wife standing next to the door way and we are still together after 38 years. http://tinyurl.com/3dm56y Jon Rebel Bird Bremerton Washington > |
06-10-2007, 04:48
Use a long 2x4 or similar board. Place one end (from the rear)
against the bottom of your rearmost tire. Raise the board until it hits the lowest projection at the rear of the coach (the part that bottoms out first). Then note how much distance you have between the door and the board ... anything that remains above the board is less likely to increase your dip-dragging potential in most cases. Still, any extra rear overhang will have some chance of striking the ground in some circumstances. Perhaps you can create a hinge-connection so that if the porch bottoms out, it can swing up a bit. A 'skid' on the bottom of the porch might help. This may require a little more engineering with the railing, but should be doable. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA <snip> > > The porch itself should be at the same height as the door or close to > it as then I won't have a problem with it dragging in a dip. (I hope?) <snip> |
06-10-2007, 04:59
Good Luck with your project the rear door is unique.
There are still a few 50's vans around. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Jon" > > --- In WanderlodgeForum@yahoogroups.com, "Jon" > > > > --- In WanderlodgeForum@yahoogroups.com, dwalks@ wrote: > > > > > > Why??? however, Great drawing > > > Walker > > > 84FC35 > > > kcmo > > > > > > > > > > > > ************************************** See what's free at > > http://www.aol.com. > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > And here is the Circus Wagon! That's what the name is on the front! > > Shows rear end with a plateform. > > http://tinyurl.com/2nnten > > And here is my original motor home it a 1951 Metro Van and I bought > it in 1967 for 125 dollars. I have some pictures of the insides but > as you could expect from that generation that it had flowered > wallpaper and of course a pot bellied stove. I even had a bus > drivers seat that had air ride. That's my beautiful wife standing > next to the door way and we are still together after 38 years. > > http://tinyurl.com/3dm56y > > Jon > Rebel Bird > Bremerton Washington > > > > > > |
06-10-2007, 16:46
Hey Jon,
On 6/10/07, Jon > > I'm totally retired and I love to have challenges and since this will > take up a little of my spare time-why not? Well, I'll be the one to encourage you, then. I think you should do it. If nothing else, it will be unique. If I had a useless rear door hanging off the back of my coach, I'd do it. A back porch on an RV is just a cool idea. Then again, I was raised by hippies, so that gives you some perspective on why I like the idea too. ;-) If I were doing it, I'd try to make some sort of three layered electric slide-out deal, so when you're driving down the road it only sticks out two feet, but when parked you flip a switch and now it's 6 feet. Would be fun to engineer something like that and not too difficult a project I'd imagine. Your idea with the three receiver hitches is a good one, I think, and would make the project removable should things not work out as well as planned. ![]() Pete's ideas on a hinge-connection and/or skid are good ones. I'd try to implement those and you might also add some large steel "wheels" to the back - you know the type, long and skinny like they use on the big garbage bins. Should stop you from catching the ground with the rear most platform cross member and ripping the whole thing off your coach. Good luck with it. ![]() -Ryan '86 PT-40 8V92 Tri-Cities, WA |
06-10-2007, 17:35
Here Jon, like this:
http://www.ryanwright.com/tmp/jon-porch.jpg Get some heavy duty linear actuators off eBay, or build your own with electric motors & some thick all-thread & welded-to-the-frame nuts. The drawing doesn't show all dimensions perfectly (I threw it together in half an hour) and I didn't draw in all three floors because of that, but you get the idea. Each platform would need to slide underneath the previous. You'd then want some way to make all platforms level. I'd do it two ways: 1. On the front most floor (closest to the bus), have the main floor anchored to the deck frame and a secondary floor that sits on top of it and is hinged on the back. So when your center floor slides out, it will be 3/4" lower than your front floor. But the front floor would be made up of two 3/4" floor panels hinged together, so just flip the top part 180 degrees and it would settle right onto the center floor, making it level. 2. Then, for the back floor, have a 1.5" thick flooring on hinges, vertically connected to the rear railing. Flip that 90 degrees toward you and it would settle onto the rear deck, which would be 1.5" lower than the front, and now you have a level deck. To retract, just flip the floor pieces over and reverse the motor(s). 3. Stick a zip-dee awning on the roof, so when the deck extends or retracts, the awning follows to provide shade. There you go - you've solved your overhang problem, mostly, and you can make the deck big enough to enjoy. -Ryan '86 PT-40 8V92 Tri-Cities, WA On 6/10/07, Ryan Wright > Hey Jon, > > On 6/10/07, Jon > > > > I'm totally retired and I love to have challenges and since this will > > take up a little of my spare time-why not? > > Well, I'll be the one to encourage you, then. I think you should do > it. If nothing else, it will be unique. If I had a useless rear door > hanging off the back of my coach, I'd do it. A back porch on an RV is > just a cool idea. Then again, I was raised by hippies, so that gives > you some perspective on why I like the idea too. ;-) > > If I were doing it, I'd try to make some sort of three layered > electric slide-out deal, so when you're driving down the road it only > sticks out two feet, but when parked you flip a switch and now it's 6 > feet. Would be fun to engineer something like that and not too > difficult a project I'd imagine. Your idea with the three receiver > hitches is a good one, I think, and would make the project removable > should things not work out as well as planned. ![]() > > Pete's ideas on a hinge-connection and/or skid are good ones. I'd try > to implement those and you might also add some large steel "wheels" to > the back - you know the type, long and skinny like they use on the big > garbage bins. Should stop you from catching the ground with the rear > most platform cross member and ripping the whole thing off your coach. > > Good luck with it. ![]() > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > |
06-11-2007, 03:13
Nice, where do yuo put the toad?
Jim Riordan Jon I have been thinking allot lately of what would make my bird really stand out from my fellow bird owners and I decided to start my rear door platform. Yesterday I got for free a complete platform from a large truck that had been damage but the platform itself is not damage. I have done some sketching with my computer and this is what I came up with, what do you guys think?? Jon http://tinyurl.com/2j5pdz Rebelbird Bremerton washington --------------------------------- Be a better Globetrotter. Get better travel answers from someone who knows. Yahoo! Answers - Check it out. [Non-text portions of this message have been removed] |
06-12-2007, 06:28
What politician owns this rig. The only thing missing are the flag holders.
MSE ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
06-12-2007, 08:56
Here is a factory setup : http://tinyurl.com/ywaqxd
Troy Tikalsky Waconia, MN --- In WanderlodgeForum@yahoogroups.com, "Jon" > > I have been thinking allot lately of what would make my bird really > stand out from my fellow bird owners and I decided to start my rear > door platform. Yesterday I got for free a complete platform from a > large truck that had been damage but the platform itself is not > damage. I have done some sketching with my computer and this is what > I came up with, what do you guys think?? Jon > http://tinyurl.com/2j5pdz > > Rebelbird > Bremerton washington > |
06-12-2007, 09:18
I thought that was an interesting photo, so I rummaged around to find the page
of photos on which it appears: http://tompatterson.com/Streamline/Trave...mback.html Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 6/12/2007 at 8:56 PM ttikalsky wrote: >Here is a factory setup : http://tinyurl.com/ywaqxd > > >Troy Tikalsky >Waconia, MN |
06-12-2007, 09:30
Other Newell/Streamlines with rear porches:
http://tompatterson.com/Streamline/Motor...coach.html http://tompatterson.com/Streamline/Trave...urphy.html http://tompatterson.com/Streamline/TravelHomes/FMC.html http://tompatterson.com/Streamline/Trave...e/Lee.html http://tinyurl.com/2pbkxo http://tinyurl.com/2oxrn6 http://tinyurl.com/2sb2of Don Bradner 90 PT40 "Blue Thunder" Eureka, CA |
