Yanmar generator fuel usage
06-30-2007, 06:10
Anyone know what to expect on an hourly fuem usage from the Yanmar (PT)
generator? Scott Forman 86 PT38 Memphis |
06-30-2007, 06:17
Scott:
Yammar and Perkins are very similar engines. both have aprox the same displacement and run at 1800 rpm's so the usage will be very close to what the Perkins is. At 06:10 PM 6/30/2007 +0000, you wrote: >Anyone know what to expect on an hourly fuem usage from the Yanmar (PT) >generator? > >Scott Forman >86 PT38 >Memphis > > |
06-30-2007, 09:58
From memory, I think the book says 1.2 GPH @ full load, .7 GPH at 50% load
(or something very close to that...). It's in your owners manual, if you have one. If you really have a "need to know", I'll go pull the manual for you.... Kevin McKeown\ Yorba Linda, CA 1986 38' PT ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
06-30-2007, 11:21
I have the numbers for the Power tech 10 KW in my coach -- which may
be close to your usage. 25% load - .256 gal hr 50% load - .412 gal hr 75% load - .912 gal hr 100% load - 1.00 gal hr Dan 94 BB BMC 37' NM --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Anyone know what to expect on an hourly fuem usage from the Yanmar (PT) > generator? > > Scott Forman > 86 PT38 > Memphis > |
06-30-2007, 11:38
Wow, that's pretty miserly, I hope mine is that efficient.
Scott --- In WanderlodgeForum@yahoogroups.com, "ac7880" wrote: > > I have the numbers for the Power tech 10 KW in my coach -- which may > be close to your usage. > 25% load - .256 gal hr > 50% load - .412 gal hr > 75% load - .912 gal hr > 100% load - 1.00 gal hr > > Dan > 94 BB BMC 37' NM > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > Anyone know what to expect on an hourly fuem usage from the Yanmar > (PT) > > generator? > > > > Scott Forman > > 86 PT38 > > Memphis > > > |
06-30-2007, 12:20
The 15 kw PowerTech generator in my coach uses about 1/2 to 3/4
gallon per hour depending on load (rated up to 1 gpm at 100% load). So, yes, they're mostly pretty efficient. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Jun 30, 2007, at 4:38 PM, Scott Forman wrote: > Wow, that's pretty miserly, I hope mine is that efficient. > > Scott > > --- In WanderlodgeForum@yahoogroups.com, "ac7880" > wrote: >> >> I have the numbers for the Power tech 10 KW in my coach -- which > may >> be close to your usage. >> 25% load - .256 gal hr >> 50% load - .412 gal hr >> 75% load - .912 gal hr >> 100% load - 1.00 gal hr >> >> Dan >> 94 BB BMC 37' NM >> >> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> >> wrote: >>> >>> Anyone know what to expect on an hourly fuem usage from the > Yanmar >> (PT) >>> generator? >>> >>> Scott Forman >>> 86 PT38 >>> Memphis >>> >> > > > > > > Yahoo! Groups Links > > > [Non-text portions of this message have been removed] |
