Flooring
07-01-2007, 04:57
Flooring
Pete- bring your coach up here. I have been installing since 1972. We can
glue your cork or let her float. Done it both ways. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
07-01-2007, 04:58
Flooring
Kerry- yes. Currently we- Bim Burt and I are installing floorcovering in his
91WLWB. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
07-01-2007, 05:42
Flooring
I'm considering replacing the flooring (at least in the forward area)
with cork flooring material. It comes in glue down and floating varieties. It strikes me that glued floor would be the proper choice for this application -- but does floating floor work? Also, (if there's any flooring experts on the list) if I like a floating-type floor, can it be glued in place. While the idea of the floating floor is to allow it to expand and contract with temperature changes, will the relatively small area (less than 200 square feet) of the coach have much need for expansion? Any comments will be appreciated. (Also, any recommendations for an installer?) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... [Non-text portions of this message have been removed] |
07-01-2007, 05:55
Flooring
Isn't Ernie a floor man?
Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > I'm considering replacing the flooring (at least in the forward area) > with cork flooring material. It comes in glue down and floating > varieties. It strikes me that glued floor would be the proper choice > for this application -- but does floating floor work? Also, (if > there's any flooring experts on the list) if I like a floating-type > floor, can it be glued in place. While the idea of the floating floor > is to allow it to expand and contract with temperature changes, will > the relatively small area (less than 200 square feet) of the coach > have much need for expansion? > > Any comments will be appreciated. > > (Also, any recommendations for an installer?) > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > > > [Non-text portions of this message have been removed] > |
07-01-2007, 09:45
Flooring
It can be installed both ways. Bluebird floors are rock solid and if the product
does not butt to the exterior walls expansion, contraction and deflection should not be a problem. My personal preference would be to glue it down. Leroy Eckert 1990WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Pete Masterson To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com Sent: Sunday, July 01, 2007 12:42 PM Subject: [WanderlodgeForum] Flooring I'm considering replacing the flooring (at least in the forward area) with cork flooring material. It comes in glue down and floating varieties. It strikes me that glued floor would be the proper choice for this application -- but does floating floor work? Also, (if there's any flooring experts on the list) if I like a floating-type floor, can it be glued in place. While the idea of the floating floor is to allow it to expand and contract with temperature changes, will the relatively small area (less than 200 square feet) of the coach have much need for expansion? Any comments will be appreciated. (Also, any recommendations for an installer?) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
07-01-2007, 10:08
Flooring
Hi Ginger- cork is great. Absorbs sound, and looks classy at the same time.
Wears well, also. Of course, with any material you install, the best preventative against dirt is a good throw rug, either on the ground, or just as you step in the coach. Don't forget- this is a natural material, and like wool, will have variations in color. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
07-01-2007, 10:40
Flooring
Ernie,
I really like the look of cork. How do you feel about it in an RV as compared with other hard materials? Ginger BB wannabee --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Pete- bring your coach up here. I have been installing since 1972. We can > glue your cork or let her float. Done it both ways. > > Ernie Ekberg > 83PT40 > Livingston, Mt > > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > |
07-01-2007, 13:07
Flooring
I floated the hardwood floors in our previous 'Bird, worked fine. The
wood was glued to a thin rubber sheeting. I don't recall the name of the rubber product, but if anyone is interested I'll stop by the store and ask. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Leroy Eckert wrote: > It can be installed both ways. Bluebird floors are rock solid and if > the product does not butt to the exterior walls expansion, contraction > and deflection should not be a problem. My personal preference would > be to glue it down. > > Leroy Eckert > 1990WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: Pete Masterson > To: wanderlodge@yahoogroups.com > ; WanderlodgeForum@yahoogroups.com > > Sent: Sunday, July 01, 2007 12:42 PM > Subject: [WanderlodgeForum] Flooring > > I'm considering replacing the flooring (at least in the forward area) > with cork flooring material. It comes in glue down and floating > varieties. It strikes me that glued floor would be the proper choice > for this application -- but does floating floor work? Also, (if > there's any flooring experts on the list) if I like a floating-type > floor, can it be glued in place. While the idea of the floating floor > is to allow it to expand and contract with temperature changes, will > the relatively small area (less than 200 square feet) of the coach > have much need for expansion? > > Any comments will be appreciated. > > (Also, any recommendations for an installer?) > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > |
07-01-2007, 14:34
Flooring
Cork is flexible material, great for a motorhome imo. It can also be resurfaced
if necessary. Sand is not your friend. That goes for carpet, wood, laminate, engineered wood, cork, marble and over a long period of time granite. Porcelain tile is pretty @#$% tough but difficult to deal with at installation. Texture and color variations in natural material are part of the beauty of the end result. If one wants a floor without character, Home Depot University carries it. Leroy Eckert 1990 WB-40 "Smoke N Mirrors' Niceville, FL Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Sunday, July 01, 2007 9:08 PM Subject: Re: [WanderlodgeForum] Re: Flooring Hi Ginger- cork is great. Absorbs sound, and looks classy at the same time. Wears well, also. Of course, with any material you install, the best preventative against dirt is a good throw rug, either on the ground, or just as you step in the coach. Don't forget- this is a natural material, and like wool, will have variations in color. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
07-01-2007, 20:12
Flooring
I had some granite cut to fit my entry steps. Too slick, my poodles would
not step on the stuff. It looked good- but removed it and installed black rubber treads. With the stainless risers, looks very stylish. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
