30 amp VS 50 amp
07-07-2007, 03:25
30 amp VS 50 amp
My 1973 FC has a 30 amp service, or at least that's what is stamped on
the shore cord. This bus has two air conditioners front and back. The
previous owner never used the back one (mainly because it was
inoperable) I have ordered and intend to have both up and running. My
question? Am I going to be ok with 30 amp service? This bus was
delivered new with two air conditioners I am pretty certain but every
RV I have ever seen with two airs was always 50 amps. And I guess I
could be wrong but there are two there now anyways. What if anything
needs to be done?
The previous questions about the weather striping and the refrig worked
out. A trip to Lowe's took care of the air leaks and the refrig fixed
its self. I was about to dig into it and I tried one more time and the
gas took right off. Don't you just love it when something fixes
itself?
John Heckman
central Pa
1973 31ft FC
07-07-2007, 03:48
30 amp VS 50 amp
John,
In the compartment where the shore cord(s) plug in, is there also a 50
amp receptacle in there?
Curt Sprenger
Anaheim Hills, Calif.
> needs to be done?
> itself?
> John Heckman
> central Pa
> 1973 31ft FC
07-07-2007, 04:10
30 amp VS 50 amp
John, Hmmmmmmmmm, This is marginal, my opinion!!
Big difference 30 amp three prongs X 110 = 3300 Watts
50 amp four prongs X 220 = 11000 Watts,
Look for a 50 amp four prong plug at the hookup.
On 30 amps, 110V, an A/C will draw 10 to 15 amp each.
Do not start at the same time, 30 amps is about the
limit capacity for two A/C's nothing else will be able to be turned
on, (maybe a TV) , but no high wattage items such as refrig, HWT,
charger etc.
Also check the generator for its' capacity..????
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "bubblerboy64"
on
The
My
every
anything
> needs to be done?
worked
fixed
> itself?
> John Heckman
> central Pa
> 1973 31ft FC
07-07-2007, 04:10
30 amp VS 50 amp
> John,
50
> Curt Sprenger
stamped on
The
running. My
every
I
anything
> > needs to be done?
worked
fixed
and the
> > itself?
> > John Heckman
> > central Pa
> > 1973 31ft FC
I would check to see how much amps those a/c's pull. I know when I
run mine it really stretches the limits on what else is running in
the coach. You can always wire up the other on and put it on its own
fuse but of course this will take a little bit of work. What kind of
generator do you have? I have a 6500 KW after market on mine and it
does provide enough juice to run both A/C's and a few other
accessories.
07-07-2007, 06:59
30 amp VS 50 amp
30 amp service will be barely adequate for 2 ACs. If you're replacing
one, try to get one of the "high efficiency" models that draw 10 amps
instead of the more typical 14-15 amps.
The problem with 30 amp service is that the AC will spike to 25-30
amps when the compressor kicks in before it drops back to the normal
14-15 amp draw. The 10 amp models only spike to about 20 amps.
When I was plugged into a 30 amp service, I was successfully running
two ACs (both 10 amp high efficiency models) -- then the refrigerator
went on and then the lights went off....
So, load management is a serious issue when running dual ACs on 30 amps.
Some of the early 'birds had dual 30 amp cords, so it might be
possible to convert yours to 50 amp service.
The 30 amp cords have 3 pins on the plug and the 50 amp cords have 4
pins. In RV setups, the 50 amp service is split into two 50 amp/120
vac legs -- you'll need to do some internal rewiring of your
distribution panel... and you may want to install "mains" for the
inbound cord if you convert to 50 amp service -- but it's probably
doable if you're conversant with electrical matters or can get some
help from a competent electrician who's familiar with RV wiring
techniques.
Pete Masterson, Author of
Book Design and Production: A Guide for Authors and Publishers
Aeonix1@...
Aeonix Publishing Group http://www.aeonix.com
> <snip>
> needs to be done?
07-07-2007, 08:35
30 amp VS 50 amp
if your 73 is the same as the 77 mine has only one inbound rectale the
30 amp cord has a jumper in the plug to make act like a 50 amp
I have safely run 2 airs plus anything else I want to the third air
however is out of the question
Also if you are using a cheater or dog bone or some other device to
connect to power watch out you will probably cook it
With the jumper the 30 amp cord has the ability to draw way over its
intended rating
Stephen 77fc35
> charger etc.
> Bill 88 FC Michigan
> on
> The
> My
> every
> anything
> > needs to be done?
> worked
> fixed
> the
> > itself?
> > John Heckman
> > central Pa
> > 1973 31ft FC
07-07-2007, 10:20
30 amp VS 50 amp
This bus has a three prong connector so it is obviously 30 amp. The
generator is I am all but certain the original ONAN which I think
might be 8.5 kilowatts (?) I can check on that and get back. Sounds
to me like it might be a good idea to see about switching to 50 amp
some time. I am also not happy with the position of the circuit
braker panel which is in the one largest closet a long with the
switch to go from shore power to generator. If you have stuff in the
closet you are have to dig thru your stuff to get to that switch. I
guess that gets put on the list of things to do. I can likely live a
while running just the one air conditioner at a time until I get to
this. One thing that does seem good is the shore cable is a 10 gauge
heavy sucker. I'll have both airs up and running in a week. How do
you know when the generator is being "worked" too hard. I have used
Honda portables in the past and they have protectors which will shut
the generators down. With this ONAN how would a person know if it is
being pushed too hard?
John Heckman
central Pa
1973 FC
replacing
amps
normal
running
refrigerator
amps.
4
amp/120
some
> techniques.
> Aeonix1@...
stamped on
back.
> > <snip>
every
I
anything
> > needs to be done?
07-07-2007, 11:18
30 amp VS 50 amp
50 amp female plug are also 3 prong they use the outside case as the
ground
I would guess unless the coach was wired for strictly 30 amp that it
has a 30 amp plug on on end and a fifty amp female on the other with a
jumper in it to light both legs
you could call bluebird and ask them if there any records left on that
coach they will be able to tell you
Stephen 77fc35
> John Heckman
> central Pa
> 1973 FC
> replacing
> amps
> normal
> running
> refrigerator
> amps.
> 4
> amp/120
> some
> > techniques.
> > Aeonix1@
> stamped on
> back.
> > > <snip>
> every
> I
> anything
> > > needs to be done?
07-07-2007, 13:02
30 amp VS 50 amp
The newer coaches have an automatic switching system -- if you're
going to upgrade your shore power system, you may want to look into
the auto-switch. (I'm afraid I don't know what it's called, exactly.)
While I would expect a modern generator to have various safety
switches/overload protection, a vintage '73 Onan may not be so well
equipped. You'll need to study the owner's manual, if it is still
available to you to see what service you should expect from the
generator. Conservatively, I'd guess that keeping a maximum load to
80% or so of the rated capacity would probably be a wise practice.
10 gauge cable is appropriate for 30 amps at 120 vac. For 50 amp
service, you'll want 6 gauge, four conductor cable. (You may need to
buy a 50 amp "extension cord" to use as the primary service cord as I
found it very difficult to get 6 gauge, 4 conductor wire locally. Cut
off the female end, strip it back and wire it into your safeline
switch.)
Pete Masterson
El Sobrante CA
aeonix1@...
> John Heckman
> central Pa
> 1973 FC
07-08-2007, 01:47
30 amp VS 50 amp
Thanks for the information on this subject. The ONAN is rated at
6500 watts not 8500. I would think if all is well it should handle
the two air conditioners. I'll have to consider the conversion to 50
amp service. I was not aware that 6 gauge wire for shore power was
available. And here I thought 10 gaurge large. JOhn Heckman
Central Pa
'73 FC
into
exactly.)
well
to
to
I
Cut
> switch.)
> Pete Masterson
> El Sobrante CA
> aeonix1@...
The
Sounds
amp
switch. I
live a
to
gauge
do
used
shut
it is
> > John Heckman
> > central Pa
> > 1973 FC
