Safe Combo
05-05-2005, 14:19
Safe Combo
I tried the message archieve but it wouldn't work for me, so I thought I
would try you guys.
My safe combo has been changed from the original factory setting as per 2
different locksmiths. They would have drilled it but since I assume it's
empty and there are no replacement parts, I didn't see the point in ruining
a great safe. I was going to hid a new one somewhere until I found these
#'s under the couch seats covering the safe (shhhh, don't tell anyone).
50 452
Not really having used dial safes in the past I don't know the proper order
of spins and what direction to start turning. Anyone have any advice?
Al S.
1981 31' FC
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of sfedeli3
Sent: Thursday, May 05, 2005 5:37 PM
Subject: [WanderlodgeForum] Re: Headlight switch
Hi Sid,
I just replaced mine with one from Blue Bird. Was around $100 or
so... like everything else. Brand was "ohmite". Was pretty easy to
get to. New one works beautifully. Could not find a match at any
auto parts stores, but did not try a "good" NAPA (the one here in
Hershey is pretty sad) I can walk you throught the removal and
installation if needed.
Shane Fedeli
85PT40
Hershey, PA
--- In WanderlodgeForum@yahoogroups.com, "Sidney Breese"
<ssbreese@a...> wrote:
> Well, I think my switch has bit the dust. Some time ago I wrote
that
> the switch did not work in the parking position, but the headlight
> came on, but the tail lights didn't. Someone suggested WD40 and
that
> worked for a while. Doesn't work this time. I have headlights,
but
> no marker or tailights. Does anyone know the brand or model of the
> switch. I went to a couple of parts stores and the said I needed
to
> bring the old one in and they would match it. Everything is
working
> fine and I am not thinking of night driving, so I hate to take the
> dash apart to get at the switch. Hoping someone has a model
number.
> thanks.
> Sid Breese
> 85PT40
> St. Joseph, MO
_____
Yahoo! Groups Links
* To visit your group on the web, go to:
* To unsubscribe from this group, send an email to:
05-05-2005, 14:35
Safe Combo
Don't drill the head/door, it is expensive. Drill the side of the
box, remove dinette booth to do so, box can easily be welded later.
Two bolts hold it down, from inside the box.
- Jeff Miller
http://www.wanderlodge.net
thought I
> would try you guys.
per 2
it's
ruining
these
anyone).
> 50 452
proper order
advice?
> Al S.
> 1981 31' FC
05-05-2005, 14:37
Safe Combo
Al,
The Dial - 4 or more turns to the left past the 1st number then stop on
the 1st number...2 turns to the right past the 2nd number then stop on
the 2nd number...1 turn to the left past the 3rd number then stop on the
3rd number...turn to right until dial clicks or stops...should open. I'm
working from memory. Will check in the morning for notes that I made and
can't find at the moment (CRS...again). Good luck.
> would try you guys.
05-05-2005, 15:35
Safe Combo
Thanks Curt. No luck yet but I keep trying the numbers in different
combinations hoping I'll hit the right combo.
Al S.
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Curt Sprenger
Sent: Thursday, May 05, 2005 7:38 PM
Subject: Re: [WanderlodgeForum] Safe Combo
Al,
Curt Sprenger '87PT38, Anaheim, Calif.
> would try you guys.
Yahoo! Groups Links
05-05-2005, 22:22
Safe Combo
Hi AL,
My Safe needs six numbers in the combination to open.
You may be missing a digit.
Example is; 25 35 45
Bill 88 FC
thought I
> would try you guys.
per 2
it's
ruining
these
anyone).
> 50 452
proper order
advice?
> Al S.
> 1981 31' FC
> _____
> Hi Sid,
> Shane Fedeli
> 85PT40
> Hershey, PA
> that
> that
> but
> to
> working
> number.
> > thanks.
> > Sid Breese
> > 85PT40
> > St. Joseph, MO
> _____
> Yahoo! Groups Links
> subject=Unsubscribe>
05-05-2005, 22:32
Safe Combo
I'M NOT AL. CHECK YOUR SEND ADDRESS. HATE TO SEE AL
MISS A MESSAAGE.
SINCERELY,
HANK HANNIGAN
90SP36
SYDNEY AUSTRALIA FOR NOW
--- pattypape wrote:
> Hi AL,
> open.
> Bill 88 FC
> for me, so I
> thought I
> > would try you guys.
> factory setting as
> per 2
> but since I assume
> it's
> see the point in
> ruining
> these
> (shhhh, don't tell
> anyone).
> > 50 452
> don't know the
> proper order
> Anyone have any
> advice?
> > Al S.
> > 1981 31' FC
> > _____
> Behalf Of sfedeli3
> > Hi Sid,
> Was around $100 or
> Was pretty easy to
> a match at any
> (the one here in
> removal and
> > Shane Fedeli
> > 85PT40
> > Hershey, PA
> Breese"
> time ago I wrote
> > that
> but the headlight
> suggested WD40 and
> > that
> have headlights,
> > but
> brand or model of
> the
> the said I needed
> > to
> Everything is
> > working
> I hate to take the
> has a model
> > number.
> > > thanks.
> > > Sid Breese
> > > 85PT40
> > > St. Joseph, MO
> > _____
> > Yahoo! Groups Links
> to:
> Yahoo!
> Service.
> removed]
__________________________________
Do you Yahoo!?
Read only the mail you want - Yahoo! Mail SpamGuard.
http://promotions.yahoo.com/new_mail
05-06-2005, 01:08
Safe Combo
>- Jeff Miller
Jeff,
I located where the bolts were, drilled a small hole in the side of
the wood frame and used an air chisel to cut through the bolts. Took about
ten minutes and I didn't have to do any welding.....
Took the box up to the local key man and he had it open pretty quick...
Blair in Oregon
05-06-2005, 01:51
Safe Combo
Blair, Do you think he could crack the safe without
removing it? How are things?
Bill "Blue Goose" 91pt40 norcal
Sent: Friday, May 06, 2005 6:08 AM
Subject: Re: [WanderlodgeForum] Re: Safe Combo
>- Jeff Miller
Jeff,
Blair in Oregon
Yahoo! Groups Links
05-06-2005, 02:02
Safe Combo
Hi Bill! Nice to see you're still around...how about setting up a meet
some day?
Had to take the safe out....the klutz who bolted it in did it in such a way
that you
could only see the numbers with a mirror..........locksmith said take it
out and
I'll open it.......previous owner was probably a dyslectic with mirror vision.
Blair in Oregon.....raining again, the grass is up to my mid thighs, so thick
it's going to be a real B______ to cut.
> From: Blair
> >- Jeff Miller
> Jeff,
> quick...
> Blair in Oregon
> Yahoo! Groups Links
><http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/\
WanderlodgeForum/
>Yahoo! Groups Links
anderlodgeForum/
Wanderl\
05-06-2005, 02:14
Safe Combo
Hello Al,
Just had my Safe serviced and reset.
The Combination is (usualy)
Left 4 turns to # ?
Right 3 turns to # ?
left 2 turns to # ?
Right 1 turn to STOP
Kurt
83FC35SB in NH
thought I
> would try you guys.
per 2
it's
ruining
these
anyone).
> 50 452
proper order
advice?
> Al S.
> 1981 31' FC
> _____
> Hi Sid,
> Shane Fedeli
> 85PT40
> Hershey, PA
> that
> that
> but
> to
> working
> number.
> > thanks.
> > Sid Breese
> > 85PT40
> > St. Joseph, MO
> _____
> Yahoo! Groups Links
