Hot Feet - More questions
07-12-2007, 08:05
I have been filling in any places that air can enter from the doghouse.
- I need to replace the rubber boot/bellows that is around the throttle rod. Blue Bird says they no longer have these. Has anyone found a source? - The throttle rod connects to a bell crank. This whole are is exposed to the engine compartment. It looks as if it could have a cover plate. Is this area normally open on a FC? - James, what was the "high heat tape" you used? Is lit like exhaust muffler tape? Any suggestions would be appreciated! I am slow to respond as I am playing "house husband" right now with Kathy laid up. (I haven't killed her with my cooking yet!) - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX [Non-text portions of this message have been removed] |
07-12-2007, 10:16
i found that shutting the gate valve in the heater hoses in the vicinity of the
passenger seat, reaching up thru from under the front of the coach reduced the hot feet issue. I think air was getting blown over a hot heater core. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > I have been filling in any places that air can enter from the doghouse. > > > > - I need to replace the rubber boot/bellows that is around the throttle rod. > Blue Bird says they no longer have these. Has anyone found a source? > > > > - The throttle rod connects to a bell crank. This whole are is exposed to > the engine compartment. It looks as if it could have a cover plate. Is > this area normally open on a FC? > > > > - James, what was the "high heat tape" you used? Is lit like exhaust > muffler tape? > > > > Any suggestions would be appreciated! I am slow to respond as I am playing > "house husband" right now with Kathy laid up. (I haven't killed her with my > cooking yet!) > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > > > [Non-text portions of this message have been removed] > |
07-12-2007, 10:36
The heater valves (4) have been closed since the weather warmed up.
- Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards Sent: Thursday, July 12, 2007 5:17 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Hot Feet - More questions i found that shutting the gate valve in the heater hoses in the vicinity of the passenger seat, reaching up thru from under the front of the coach reduced the hot feet issue. I think air was getting blown over a hot heater core. Kerry 82 FC 35 Denver --- In WanderlodgeForum@ yahoogroups.com, "Chuck Wheeler" > > I have been filling in any places that air can enter from the doghouse. > > > > - I need to replace the rubber boot/bellows that is around the throttle rod. > Blue Bird says they no longer have these. Has anyone found a source? > > > > - The throttle rod connects to a bell crank. This whole are is exposed to > the engine compartment. It looks as if it could have a cover plate. Is > this area normally open on a FC? > > > > - James, what was the "high heat tape" you used? Is lit like exhaust > muffler tape? > > > > Any suggestions would be appreciated! I am slow to respond as I am playing > "house husband" right now with Kathy laid up. (I haven't killed her with my > cooking yet!) > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
User(s) browsing this thread: 10 Guest(s)
