Perkins Fuel Injector Pump
07-14-2007, 05:04
In a message dated 7/14/2007 1:11:10 P.M. Mountain Standard Time,
bird@... writes: Now you & Bim should take a box wine break & plan a trip down the valley Bim went to do laundry- i took a nap. Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
07-14-2007, 07:42
After removing that pump last week, we drove to Billings to pick it up.
The company cleaned her up so good, I didn't recognize it. Today, we installed it. We have been told that it must be aligned exactly the way it came out. Well, after looking at the spline inside the engine and the receiving end inside the pump, there is only one way to install it because it has a key that the pump fits over. You can't install it any other way. Whew- I knew we were going to get it outta time. After priming and priming with both hands, Bim would spell me and prime with both of his hands. We cracked the injectors and finally after many attempts at starting we moved the actuator arm. Fired right up and we are back in business with NO LEAKS!!! What a feeling of relief! Ernie- 83PT40 in Montana, now I can take the coach somewhere and have a/c running |
07-14-2007, 08:09
Good news Ernie. Glad they did a good rebuild job for you. I had heard
good things about them from the shop I use for my Ford diesel stuff. Now you & Bim should take a box wine break & plan a trip down the valley. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Ernest Ekberg wrote: > After removing that pump last week, we drove to Billings to pick it up. > The company cleaned her up so good, I didn't recognize it. > Today, we installed it. We have been told that it must be aligned > exactly the way it came out. Well, after looking at the spline inside > the engine and the receiving end inside the pump, there is only one way > to install it because it has a key that the pump fits over. You can't > install it any other way. Whew- I knew we were going to get it outta > time. After priming and priming with both hands, Bim would spell me and > prime with both of his hands. We cracked the injectors and finally > after many attempts at starting we moved the actuator arm. Fired right > up and we are back in business with NO LEAKS!!! What a feeling of > relief! Ernie- 83PT40 in Montana, now I can take the coach somewhere > and have a/c running > > [Non-text portions of this message have been removed] |
07-14-2007, 08:19
From: Ernest Ekberg To: WanderlodgeForum@yahoogroups.com Sent: Saturday, July 14, 2007 2:42 PM Subject: [WanderlodgeForum] Perkins Fuel Injector Pump Hi Ernie Sometimes things to go right. Bob Loomas 1985 PT 36 Still in Grand Forks ND After removing that pump last week, we drove to Billings to pick it up. The company cleaned her up so good, I didn't recognize it. Today, we installed it. We have been told that it must be aligned exactly the way it came out. Well, after looking at the spline inside the engine and the receiving end inside the pump, there is only one way to install it because it has a key that the pump fits over. You can't install it any other way. Whew- I knew we were going to get it outta time. After priming and priming with both hands, Bim would spell me and prime with both of his hands. We cracked the injectors and finally after many attempts at starting we moved the actuator arm. Fired right up and we are back in business with NO LEAKS!!! What a feeling of relief! Ernie- 83PT40 in Montana, now I can take the coach somewhere and have a/c running [Non-text portions of this message have been removed] |
