inverters
06-19-2005, 05:07
inverters
I am going to change out my 1500 redi line inverter. My question is
should pay the the extra for 3000w or go with the 2000. About 350.00 more. Will i use the extra 1000w. What do you use. Comments please. Thanks. Jack Jones 87 pt 40 East Tn sun -75 |
06-19-2005, 05:25
inverters
Common question.
If you have it you will likely use it. The change from a redi-line to a simple 1500watt inverter is largely a quick swap, the price of the inverter and a little installation. To go to an inverter/charger, or a larger inverter becomes much more involved and expensive if you want to be able to use the additional capacity. You can probably use the original location, but getting enough clean air for cooling is a problem for a larger inverter/charger. There is space, once chargers and redi-line are removed. To use the charging capacity of the inverter/charger, you will need to re-wire the compartment for the additional capacity of the inverter and charger, and you will need to make some wiring modifications to the service panel. Several options are available as far as how to wire the loads, my method has been to power half of the panel (line 1 or line 2) and re-arrange the loads so that inverter-powered loads are on one side of the panel, an isolated neutral is also necessary, and then the inverter/charger's internal transfer switch can be used (the 2 30a transfer switches in the Xantrex/Trace RV3012 for example can be paralleled to switch one 50a leg). Another option (better, but more complicated) is to add an external/additional load center for inverter- powered loads, ... etc. With a larger inverter, you will be able to run many things such as the microwave while running down the road, wonderful if your cook travels with you and you're driving through meals occasionally, you can power all outlets so that you can plug in anywhere for a cell-phone charger, laptop, etc., you can ever run hair-care appliances, toaster, coffeemaker, etc., all without starting the genset. A brief high- current useage such as making coffee or heating something in the microwave is also possible while dry-camping without waking the neighbors with your genset. The 4-stage charging capacity at 100-130a on these inverters will also give you more battery capacity and battery life than the original chargers. Add to this one of the remote panels or monitor/control panels available, or even a genset auto-start, and you have lots of data and control of your batteries and electrical system. I will install a large inverter in any coach I buy for personal use, hard to be without it once you've had one. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "birdboat44" wrote: > I am going to change out my 1500 redi line inverter. My question is > should pay the the extra for 3000w or go with the 2000. About 350.00 > more. Will i use the extra 1000w. What do you use. Comments please. > Thanks. > Jack Jones > 87 pt 40 > East Tn sun -75 |
06-19-2005, 06:00
inverters
-Jeff thanks for the info i will go with the larger unit probably. I
can rewire it but i wish you were closer. As i get older i get more lazy. Had a auto- boat repair shop 20 years that was enough wrenching. > Jack Jones > > --- In WanderlodgeForum@yahoogroups.com, "birdboat44" > wrote: > > I am going to change out my 1500 redi line inverter. My question is > > should pay the the extra for 3000w or go with the 2000. About 350.00 > > more. Will i use the extra 1000w. What do you use. Comments please. > > Thanks. > > Jack Jones > > 87 pt 40 > > East Tn sun -75 |
06-19-2005, 11:55
inverters
bigger is always better,, even if you don't use all the available
power, it will extend the life of the inverter, as it will not be running at full capacity,,, day jax fla 83 pt-40 In a message dated 6/19/2005 1:07:53 PM Eastern Standard Time, jjracing@... writes: > Subj: [WanderlodgeForum] inverters > Date:6/19/2005 1:07:53 PM Eastern Standard Time > From:jjracing@... > Reply-to:WanderlodgeForum@yahoogroups.com > To:WanderlodgeForum@yahoogroups.com > Received from Internet: > > > > I am going to change out my 1500 redi line inverter. My question is > should pay the the extra for 3000w or go with the 2000. About 350.00 > more. Will i use the extra 1000w. What do you use. Comments please. > Thanks. > Jack Jones > 87 pt 40 > East Tn sun -75 > > > > > Yahoo! Groups Links > > To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > [Non-text portions of this message have been removed] |
04-21-2006, 14:49
inverters
I do Ernie, and it is still vented as I read the inverter likes to
breathe. --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > >Ron, do you still havee that 90 degree steel protective cover that use >to go over the Rediline? >Ernie-83pt40 |
07-14-2007, 08:24
inverters
A couple of days ago, the subject of inverters was discussed at some
length on this Forum. I sent a request to Xantrex technical support asking their specific recommendation for a 2500-3000 watt model. They recommend the Freedom 458 series for my needs (PT40) in the 2,500 or 3,000 watt models & said it is serviceable nationwide. They also said the Freedom 458 Marine version was not necessary in an RV application as the only difference was echo charging & an aluminum case and it was more $$$s. They also said that the PROsine series is not serviced outside of their facilities & the 2000 watt model is the only one serviced in North America. Just a FYI for those who own or are considering a PROsine. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T [Non-text portions of this message have been removed] |
07-14-2007, 10:22
inverters
I'm wanting an inverter/charger also. Was thinking about the Prosine. If that
is true about the prosine maybe should think about the Magnumms 20 or 2812. Does anyone know if anyone can repair the Magnum MS?Marvin SkaggsBuffalo, Ky. 427161984 PT40--- On Sat 07/14, Terry Neal < bird@... > wrote:From: Terry Neal [mailto: bird@...]To: WanderlodgeForum@...: Sat, 14 Jul 2007 14:24:38 -0600Subject: [WanderlodgeForum] Inverters A couple of days ago, the subject of inverters was discussed at some length on this Forum. I sent a request to Xantrex technical support asking their specific recommendation for a 2500-3000 watt model. They recommend the Freedom 458 series for my needs (PT40) in the 2,500 or 3,000 watt models & said it is serviceable nationwide. They also said the Freedom 458 Marine version was not necessary in an RV application as the only difference was echo charging & an aluminum case and it was more $$$s.They also said that the PROsine series is not serviced outside of their facilities & the 2000 watt model is the only one serviced in North America. Just a FYI for those who own or are considering a PROsine.Terry NealBozeman, MT82PT40 6V92TA74FC34 6V53T[Non-text portions of this message have been removed] _______________________________________________ Join Excite! - http://www.excite.com The most personalized portal on the Web! [Non-text portions of this message have been removed] |
07-14-2007, 12:48
inverters
If you're looking for true sine wave, you might compare these with
the Outback inverters. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Jul 14, 2007, at 1:24 PM, Terry Neal wrote: > A couple of days ago, the subject of inverters was discussed at some > length on this Forum. I sent a request to Xantrex technical support > asking their specific recommendation for a 2500-3000 watt model. They > recommend the Freedom 458 series for my needs (PT40) in the 2,500 or > 3,000 watt models & said it is serviceable nationwide. They also said > the Freedom 458 Marine version was not necessary in an RV > application as > the only difference was echo charging & an aluminum case and it was > more > $$$s. > > They also said that the PROsine series is not serviced outside of > their > facilities & the 2000 watt model is the only one serviced in North > America. Just a FYI for those who own or are considering a PROsine. [Non-text portions of this message have been removed] |
