Engine Alternator overcharging
07-15-2007, 08:55
I am having a problem with my Leece-Neville alternator overcharging. I
had it rebuilt as preventive maint.,it woked ok for about 800-1000 miles then it started over charging 15-15.5 volts & 80-100amps. I took it back to the rebuilder and they said the regulator was bad so they replaced it. They told me to check the voltage to the small + post under the regulator. I was getting about .75 of a volt less than battery voltage as measured at the big + post. I could not find where the volt drop was so I ran a new wire from the ignition operated solinoid above the throttle pedal. The alternator is still overcharging. We are supposed to leave on Friday for a 4000 mile trip so this is a big problem. Did Bluebird use a special regulator since they have Batt. power to the alternator all of the time? The rebuilder may have installed the wrong regulator. Thanks Jim Matus 84FC35 Rescue CA |
07-15-2007, 09:36
Jim,
What is the voltage from the alternator frame to the + post on the alternator? - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of jim matus Sent: Sunday, July 15, 2007 3:55 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Engine Alternator overcharging I am having a problem with my Leece-Neville alternator overcharging. I had it rebuilt as preventive maint.,it woked ok for about 800-1000 miles then it started over charging 15-15.5 volts & 80-100amps. I took it back to the rebuilder and they said the regulator was bad so they replaced it. They told me to check the voltage to the small + post under the regulator. I was getting about .75 of a volt less than battery voltage as measured at the big + post. I could not find where the volt drop was so I ran a new wire from the ignition operated solinoid above the throttle pedal. The alternator is still overcharging. We are supposed to leave on Friday for a 4000 mile trip so this is a big problem. Did Bluebird use a special regulator since they have Batt. power to the alternator all of the time? The rebuilder may have installed the wrong regulator. Thanks Jim Matus 84FC35 Rescue CA [Non-text portions of this message have been removed] |
07-15-2007, 10:38
Try jumping the alternator's sense wire to the battery positive terminal.
Your sense wire might be disconnected or degraded resulting in high resistance. David Brady '02 LXi, Smokey NC jim matus wrote: > > I am having a problem with my Leece-Neville alternator overcharging. I > had it rebuilt as preventive maint.,it woked ok for about 800-1000 > miles then it started over charging 15-15.5 volts & 80-100amps. I took > it back to the rebuilder and they said the regulator was bad so they > replaced it. They told me to check the voltage to the small + post > under the regulator. I was getting about .75 of a volt less than > battery voltage as measured at the big + post. I could not find where > the volt drop was so I ran a new wire from the ignition operated > solinoid above the throttle pedal. The alternator is still > overcharging. We are supposed to leave on Friday for a 4000 mile trip > so this is a big problem. Did Bluebird use a special regulator since > they have Batt. power to the alternator all of the time? The rebuilder > may have installed the wrong regulator. Thanks Jim Matus 84FC35 Rescue > CA > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.10.6/900 - Release Date: 7/14/2007 3:36 PM > [Non-text portions of this message have been removed] |
07-15-2007, 13:52
I did that and it charged ok but after I hooked it up with the sense
wire it started overcharging and now it overcharges no matter how you connect it so I guess the regulator blew again. Jim Matus 84FC35 Rescue CA -- - In WanderlodgeForum@yahoogroups.com, David Brady > > Try jumping the alternator's sense wire to the battery positive terminal. > Your sense wire might be disconnected or degraded resulting in high > resistance. > > David Brady > '02 LXi, Smokey > NC > > jim matus wrote: > > > > I am having a problem with my Leece-Neville alternator overcharging. I > > had it rebuilt as preventive maint.,it woked ok for about 800-1000 > > miles then it started over charging 15-15.5 volts & 80-100amps. I took > > it back to the rebuilder and they said the regulator was bad so they > > replaced it. They told me to check the voltage to the small + post > > under the regulator. I was getting about .75 of a volt less than > > battery voltage as measured at the big + post. I could not find where > > the volt drop was so I ran a new wire from the ignition operated > > solinoid above the throttle pedal. The alternator is still > > overcharging. We are supposed to leave on Friday for a 4000 mile trip > > so this is a big problem. Did Bluebird use a special regulator since > > they have Batt. power to the alternator all of the time? The rebuilder > > may have installed the wrong regulator. Thanks Jim Matus 84FC35 Rescue > > CA > > > > > > ------------------------------------------------------------------ ------ > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.476 / Virus Database: 269.10.6/900 - Release Date: 7/14/2007 3:36 PM > > > > > > [Non-text portions of this message have been removed] > |
07-15-2007, 17:32
Chuck: The voltage is 12.32 volts same as battery voltage. Jim Matus
84FC35 Rescue CA - -- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Jim, > > > > What is the voltage from the alternator frame to the + post on the > alternator? > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of jim matus > Sent: Sunday, July 15, 2007 3:55 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Engine Alternator overcharging > > > > I am having a problem with my Leece-Neville alternator overcharging. I > had it rebuilt as preventive maint.,it woked ok for about 800-1000 > miles then it started over charging 15-15.5 volts & 80-100amps. I took > it back to the rebuilder and they said the regulator was bad so they > replaced it. They told me to check the voltage to the small + post > under the regulator. I was getting about .75 of a volt less than > battery voltage as measured at the big + post. I could not find where > the volt drop was so I ran a new wire from the ignition operated > solinoid above the throttle pedal. The alternator is still > overcharging. We are supposed to leave on Friday for a 4000 mile trip > so this is a big problem. Did Bluebird use a special regulator since > they have Batt. power to the alternator all of the time? The rebuilder > may have installed the wrong regulator. Thanks Jim Matus 84FC35 Rescue > CA > > > > > > [Non-text portions of this message have been removed] > |
07-16-2007, 00:29
Have you checked all grounds on the coach (battery, frame, etc?)
Insecure grounds can do strange things to apparently unrelated components. Dan 94 BMC 37' --- In WanderlodgeForum@yahoogroups.com, "jim matus" wrote: > > I did that and it charged ok but after I hooked it up with the sense > wire it started overcharging and now it overcharges no matter how you > connect it so I guess the regulator blew again. Jim Matus 84FC35 > Rescue CA -- > - In WanderlodgeForum@yahoogroups.com, David Brady > > > > Try jumping the alternator's sense wire to the battery positive > terminal. > > Your sense wire might be disconnected or degraded resulting in high > > resistance. > > > > David Brady > > '02 LXi, Smokey > > NC > > > > jim matus wrote: > > > > > > I am having a problem with my Leece-Neville alternator > overcharging. I > > > had it rebuilt as preventive maint.,it woked ok for about 800- 1000 > > > miles then it started over charging 15-15.5 volts & 80-100amps. I > took > > > it back to the rebuilder and they said the regulator was bad so > they > > > replaced it. They told me to check the voltage to the small + post > > > under the regulator. I was getting about .75 of a volt less than > > > battery voltage as measured at the big + post. I could not find > where > > > the volt drop was so I ran a new wire from the ignition operated > > > solinoid above the throttle pedal. The alternator is still > > > overcharging. We are supposed to leave on Friday for a 4000 mile > trip > > > so this is a big problem. Did Bluebird use a special regulator > since > > > they have Batt. power to the alternator all of the time? The > rebuilder > > > may have installed the wrong regulator. Thanks Jim Matus 84FC35 > Rescue > > > CA > > > > > > > > > ---------------------------------------------------------------- -- > ------ > > > > > > No virus found in this incoming message. > > > Checked by AVG Free Edition. > > > Version: 7.5.476 / Virus Database: 269.10.6/900 - Release Date: > 7/14/2007 3:36 PM > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
07-16-2007, 01:25
Then I confused! Where is the 15+ volts? Sounds like it's dead, not
overcharging. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of jim matus Sent: Monday, July 16, 2007 12:33 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Engine Alternator overcharging Chuck: The voltage is 12.32 volts same as battery voltage. Jim Matus 84FC35 Rescue CA - -- In WanderlodgeForum@ yahoogroups.com, "Chuck Wheeler" > > Jim, > > > > What is the voltage from the alternator frame to the + post on the > alternator? > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > _____ > > From: WanderlodgeForum@ yahoogroups.com > [mailto:WanderlodgeForum@ yahoogroups.com] On Behalf Of jim matus > Sent: Sunday, July 15, 2007 3:55 PM > To: WanderlodgeForum@ yahoogroups.com > Subject: [WanderlodgeForum] Engine Alternator overcharging > > > > I am having a problem with my Leece-Neville alternator overcharging. I > had it rebuilt as preventive maint.,it woked ok for about 800-1000 > miles then it started over charging 15-15.5 volts & 80-100amps. I took > it back to the rebuilder and they said the regulator was bad so they > replaced it. They told me to check the voltage to the small + post > under the regulator. I was getting about .75 of a volt less than > battery voltage as measured at the big + post. I could not find where > the volt drop was so I ran a new wire from the ignition operated > solinoid above the throttle pedal. The alternator is still > overcharging. We are supposed to leave on Friday for a 4000 mile trip > so this is a big problem. Did Bluebird use a special regulator since > they have Batt. power to the alternator all of the time? The rebuilder > may have installed the wrong regulator. Thanks Jim Matus 84FC35 Rescue > CA > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
07-16-2007, 01:33
Sorry for this Jim, but I gotta ask, was the engine running when
you read the 12.32V? David Brady '02 LXi, Smokey NC jim matus wrote: > > Chuck: The voltage is 12.32 volts same as battery voltage. Jim Matus > 84FC35 Rescue CA - > -- In WanderlodgeForum@yahoogroups.com > > > > > > Jim, > > > > > > > > What is the voltage from the alternator frame to the + post on the > > alternator? > > > > > > > > - Chuck Wheeler - > > > > 82 FC 31 SB > > > > Fort Worth, TX > > > > _____ > > > > From: WanderlodgeForum@yahoogroups.com > > > [mailto:WanderlodgeForum@yahoogroups.com > > > Sent: Sunday, July 15, 2007 3:55 PM > > To: WanderlodgeForum@yahoogroups.com > > > Subject: [WanderlodgeForum] Engine Alternator overcharging > > > > > > > > I am having a problem with my Leece-Neville alternator > overcharging. I > > had it rebuilt as preventive maint.,it woked ok for about 800-1000 > > miles then it started over charging 15-15.5 volts & 80-100amps. I > took > > it back to the rebuilder and they said the regulator was bad so > they > > replaced it. They told me to check the voltage to the small + post > > under the regulator. I was getting about .75 of a volt less than > > battery voltage as measured at the big + post. I could not find > where > > the volt drop was so I ran a new wire from the ignition operated > > solinoid above the throttle pedal. The alternator is still > > overcharging. We are supposed to leave on Friday for a 4000 mile > trip > > so this is a big problem. Did Bluebird use a special regulator > since > > they have Batt. power to the alternator all of the time? The > rebuilder > > may have installed the wrong regulator. Thanks Jim Matus 84FC35 > Rescue > > CA > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.10.6/900 - Release Date: 7/14/2007 3:36 PM > [Non-text portions of this message have been removed] |
07-16-2007, 17:25
The reading I gave you was with the engine shut off. + post to
alternator frame I thought that is what you wre asking . With the engine running I was getting 15+ volts on the dash volt meter and the alternator was getting very warm. Jim Matus 84FC35 Rescue CA - -- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Then I confused! Where is the 15+ volts? Sounds like it's dead, not > overcharging. > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of jim matus > Sent: Monday, July 16, 2007 12:33 AM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Engine Alternator overcharging > > > > Chuck: The voltage is 12.32 volts same as battery voltage. Jim Matus > 84FC35 Rescue CA - > -- In WanderlodgeForum@ > yahoogroups.com, "Chuck Wheeler" > > > > > Jim, > > > > > > > > What is the voltage from the alternator frame to the + post on the > > alternator? > > > > > > > > - Chuck Wheeler - > > > > 82 FC 31 SB > > > > Fort Worth, TX > > > > _____ > > > > From: WanderlodgeForum@ > yahoogroups.com > > [mailto:WanderlodgeForum@ > yahoogroups.com] On Behalf Of jim matus > > Sent: Sunday, July 15, 2007 3:55 PM > > To: WanderlodgeForum@ > yahoogroups.com > > Subject: [WanderlodgeForum] Engine Alternator overcharging > > > > > > > > I am having a problem with my Leece-Neville alternator > overcharging. I > > had it rebuilt as preventive maint.,it woked ok for about 800- 1000 > > miles then it started over charging 15-15.5 volts & 80-100amps. I > took > > it back to the rebuilder and they said the regulator was bad so > they > > replaced it. They told me to check the voltage to the small + post > > under the regulator. I was getting about .75 of a volt less than > > battery voltage as measured at the big + post. I could not find > where > > the volt drop was so I ran a new wire from the ignition operated > > solinoid above the throttle pedal. The alternator is still > > overcharging. We are supposed to leave on Friday for a 4000 mile > trip > > so this is a big problem. Did Bluebird use a special regulator > since > > they have Batt. power to the alternator all of the time? The > rebuilder > > may have installed the wrong regulator. Thanks Jim Matus 84FC35 > Rescue > > CA > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > |
07-16-2007, 17:36
No the way the question was asked I thought he was asking about the
voltage thru the frame to ground with the engine off. Running @ 1500+ rpms it is 15+ volts. I called Leece-Neville this morning and they told me to try Norm's Electric in Sacramento I took it to them and the first thing they saw was that the previous shop had used a no name regulator. I suspect they used substandered off-shore parts in it. I should know tomorrow what all they found.Jim Matus 84FC35 Rescue CA - -- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Sorry for this Jim, but I gotta ask, was the engine running when > you read the 12.32V? > > David Brady > '02 LXi, Smokey > NC > > jim matus wrote: > > > > Chuck: The voltage is 12.32 volts same as battery voltage. Jim Matus > > 84FC35 Rescue CA - > > -- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > Jim, > > > > > > > > > > > > What is the voltage from the alternator frame to the + post on the > > > alternator? > > > > > > > > > > > > - Chuck Wheeler - > > > > > > 82 FC 31 SB > > > > > > Fort Worth, TX > > > > > > _____ > > > > > > From: WanderlodgeForum@yahoogroups.com > > > > > [mailto:WanderlodgeForum@yahoogroups.com > > matus > > > Sent: Sunday, July 15, 2007 3:55 PM > > > To: WanderlodgeForum@yahoogroups.com > > > > > Subject: [WanderlodgeForum] Engine Alternator overcharging > > > > > > > > > > > > I am having a problem with my Leece-Neville alternator > > overcharging. I > > > had it rebuilt as preventive maint.,it woked ok for about 800- 1000 > > > miles then it started over charging 15-15.5 volts & 80-100amps. I > > took > > > it back to the rebuilder and they said the regulator was bad so > > they > > > replaced it. They told me to check the voltage to the small + post > > > under the regulator. I was getting about .75 of a volt less than > > > battery voltage as measured at the big + post. I could not find > > where > > > the volt drop was so I ran a new wire from the ignition operated > > > solinoid above the throttle pedal. The alternator is still > > > overcharging. We are supposed to leave on Friday for a 4000 mile > > trip > > > so this is a big problem. Did Bluebird use a special regulator > > since > > > they have Batt. power to the alternator all of the time? The > > rebuilder > > > may have installed the wrong regulator. Thanks Jim Matus 84FC35 > > Rescue > > > CA > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > ------------------------------------------------------------------ ------ > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.476 / Virus Database: 269.10.6/900 - Release Date: 7/14/2007 3:36 PM > > > > > > [Non-text portions of this message have been removed] > |
