HWH repair / locating parts
07-11-2007, 15:33
It's me again,
They found my hydraulic problem. They claim the "right front jack and
actuator assembly" is leaking and needs to be replaced and that the
jack and actuator are "clamped together" or otherwise one unit. They
can't find part numbers. Does this diagnosis sound accurate? Can I
simply buy this from HWH or order from Blue Bird, or does anyone else
have a lead on where I can find this part? I'm going to let them
install it.
Thanks!
-Ryan
'86 PT-40 8V92
Tri-Cities, WA
07-11-2007, 16:17
Ryan,
Call HWH. They will send you an actuator. You'll need your credit card,
$178.04. I returned the bad one and HWH gave me about a 50% credit,
$85.68. This was in February 2006.
You can change the actuator. It's about a 15 minute job. I didn't get
the actuator aligned correctly the first time so I had oil squirting
out, about 15 feet. Realigned it to the jack and all is still good. Put
a rag around the actuator/jack before activating...keeps oil from going
all over the place if misaligned.
Two people are better than one to do this job. Pull down the jack, it's
easier than it looks, R&R the actuator.
Good luck..
Curt Sprenger
Anaheim Hills, Calif.
Ryan Wright wrote:
> It's me again,
> install it.
> Thanks!
> -Ryan
> '86 PT-40 8V92
> Tri-Cities, WA
07-11-2007, 20:21
One other thing about replacing the actuator on your jack. The clamp that
holds that on the jack has very little slack. We got a large worm drive clamp
and tightened that down first- then installed the original clamp
83PT40
Livingston, Mt
************************************** Get a sneak peak of the all-new AOL at
07-12-2007, 05:49
Call HWH -- they're very helpful. You may be able to get a rebuilt
assembly.
Pete Masterson
El Sobrante CA
aeonix1@...
On Jul 11, 2007, at 8:33 PM, Ryan Wright wrote:
> It's me again,
> install it.
07-12-2007, 13:14
Just a little addendum to Curt's suggestion....the kick-down actuator is
attached to the main piston with 2 big hose clamp-type screw clamps. When you
take them off, there are two little spacer button thingys that set the
kick-down actuator piston apart from the main leveling piston. The two spacers
are
different, and there is a small spring inside this spacers. Make a mental
(or written) note, which spacer goes on the top, and which one goes on the
bottom. They are not interchangeable. Do not lose the little spring that's
inside the spacer button thingy.
It took Curt 15 minutes....it took me two days because I couldn't get the
darn button spacer (for the lack of a better term) to seat and seal properly.
Holding onto a slippery piston actuator (coated with trans fluid), while
upside down on your back, and getting the hose clamp things on was a bear for
me....but I did get the job done, and it's worked perfectly since. I too
ordered the new actuator from HWH, and got about 50% back when I sent them my
old
one. Again, if you get a new actuator from HWH, the spacers are taped in the
correct spots...don't mix them up.
You can download the HWH parts list and assembly diagram from their website.
Good luck...If I can do it, anybody can.
Kevin McKeown
Yorba Linda, CA
1986 38' PT (for sale)
07-12-2007, 16:54
Thanks all for the advice on the HWH system. I'll call HWH and order a
new actuator assembly.
I appreciate all of your help!!
-Ryan
'86 PT-40 8V92
Tri-Cities, WA
07-13-2007, 01:33
> Kevin McKeown
> Yorba Linda, CA
Kevin,
Just noticed that signature. Got your eye set on for a replacement?
1991 WB40 "Texas Minivan"
actuator is
When you
two spacers are
mental
on the
spring that's
get the
properly.
while
a bear for
I too
sent them my old
taped in the
website.
> Kevin McKeown
> Yorba Linda, CA
all-new AOL at
07-18-2007, 06:25
Folks,
Appreciate all of the replies on this. I'll be ordering a new actuator
from HWH and may attempt to do the job myself.
Question: How do I refill & bleed (?) the hydraulic system? I believe
the fluid drained out of the lines but for some reason the system is
not pulling fluid from the reservoir, as it is still full. I want to
perform a full bleed & fill of the system before I buy the actuator,
just to verify the diagnosis (I want to see fluid squirting from the
actuator myself).
-Ryan
'86 PT-40 8V92
Tri-Cities, WA
you
spacers are
properly.
for
my old
> Kevin McKeown
> Yorba Linda, CA
07-18-2007, 09:56
Ryan,
The HWH fluid reservoir is under the middle front step on a PT.
There is a trap door to access the fill spout. You just need a small
funnel to add Dexron ATF (at least that's what's supposed to be in
there). As far as I was told there is no need to bleed the system,
just cycle the thing a couple of times. At least that is what worked
on the hydraulic genset ram on my 83 PT40, which ran off the same
system as the jacks.
> Folks,
> actuator myself).
> -Ryan
> '86 PT-40 8V92
> Tri-Cities, WA
actuator is
clamps. When you
set the
The two spacers are
Make a mental
goes on the
spring that's
get the
seal properly.
fluid), while
was a bear for
since. I too
sent them my old
taped in the
their website.
> > Kevin McKeown
> > Yorba Linda, CA
07-18-2007, 10:53
Thanks Mike & Curt. This isn't making a lot of sense to me, then - if
no bleeding is required, I wonder why my reservoir is full and yet the
system is not working? The pump is clearly attempting to pump, I can
hear it running same as before. Wouldn't you think it would take fluid
from the reservoir and pump it right out where the leak is? A full
reservoir and non-working hydraulics is confusing, unless the pump
isn't actually pumping, but I'd think it would sound different if that
were the case.
I'm going to fiddle with it some more when I get home tonight...
-Ryan
'86 PT-40 8V92
Tri-Cities, WA
On 7/18/07, Curt Sprenger wrote:
> Ryan,
> Our coach is the '87 PT. The HWH jack/leveling system does not require
> bleeding.
> Curt Sprenger
> Anaheim Hills, CA
On 7/18/07, mbulriss <mbulriss@...> wrote:
> Ryan,
> Mike Bulriss
> San Antonio, TX
