help with alternator replacement
07-25-2007, 10:23
Ron,
Thanks for all the great advice. I did not know where to start. Thanks Again --- ronmarabito2002 > > Nelson: > > You begin by removing two sections of carpeted > base. Start with > the short piece at the nightstand. There are screws > hidden in the > carpet that hold the base in place. Use a magnetic > stud finder to > assist in locating the screws. > > Next, pull the carpet back, again starting at > the night stand. > > There are actually (2) pieces of plate. It is > obvious which has > to be removed first. The second and largest has > screws into the back > wall, so you probably will have to pull some > plumbing clamps in order > to see all of them. > > In order to provide more working room, you can > remove a 10-12" > piece of the plywood supporting the mattress along > that isle. Once > you remove the mattress, you can see it. > > Once the plates are removed, you can see the > alternator. Loosen > the anchor bolt before loosening the adjusting bolt. > Do this after > you have removed the (3) wires from the alternator. > > Since you have to work on your knees, bent over > in a hole, you > will find that this is not a fun job. I suggest you > use a piece of > plywood for kneeling over the opening. A trouble > light will also help. > > When you have re-built the alternator, the > process is just the > reverse. You will need an air stapler or electric > stapler to > reinstall the carpet. > > Let me know if you need anything else. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com, nelson > slinkman > > > > > My bed has the cross island queen. > > I assume all the carpet has to be removed from the > > rear bulkhead. Is there an access panel behind the > > carpet. > > > > Thank > > Nelson Slinkman > > > > > > --- mbulriss <mbulriss@...> wrote: > > > > > In addition to Ron's comment, if it is a forward > > > facing bed, the > > > access is through a plate under the bed just in > > > front of the rear > > > closet wall. > > > > > > Mike Bulriss > > > 1991 WB40 "Texas Minivan" > > > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, > > > "ronmarabito2002" > > > > > > > > > > > If you have a cross-island bed, the access is > in > > > the floor of the > > > > bedroom between the bed and the rear cabinets. > > > > I've done it a couple > > > > of times. Let me know if that is your bed > > > arrangement. > > > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, > > > "nslinkman" > > > > wrote: > > > > > > > > > > Does anyone no the procedure to replace the > rear > > > alternator in a 1994 > > > > > with an 8v92.I could not find any trap door > in > > > the bedroom area or > > > > > inside the closet. Any help will be > appreciated. > > > > > Thanks in advance > > > > > Nelson Slinkman 1994 40' > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________\ ____ > > Looking for a deal? Find great prices on flights > and hotels with > Yahoo! FareChase. > > http://farechase.yahoo.com/ > > > > > ________________________________________________________________________________\ ____ Shape Yahoo! in your own image. Join our Network Research Panel today! http://surveylink.yahoo.com/gmrs/yahoo_p...te.asp?a=7 |
07-25-2007, 11:06
this can be a rather dirty oily job so I recommend you cover up whatever you
don't want grease on. On 25/07/07, nelson slinkman > > Ron, > Thanks for all the great advice. I did not know where > to start. > Thanks Again > > --- ronmarabito2002 > > > > > Nelson: > > > > You begin by removing two sections of carpeted > > base. Start with > > the short piece at the nightstand. There are screws > > hidden in the > > carpet that hold the base in place. Use a magnetic > > stud finder to > > assist in locating the screws. > > > > Next, pull the carpet back, again starting at > > the night stand. > > > > There are actually (2) pieces of plate. It is > > obvious which has > > to be removed first. The second and largest has > > screws into the back > > wall, so you probably will have to pull some > > plumbing clamps in order > > to see all of them. > > > > In order to provide more working room, you can > > remove a 10-12" > > piece of the plywood supporting the mattress along > > that isle. Once > > you remove the mattress, you can see it. > > > > Once the plates are removed, you can see the > > alternator. Loosen > > the anchor bolt before loosening the adjusting bolt. > > Do this after > > you have removed the (3) wires from the alternator. > > > > Since you have to work on your knees, bent over > > in a hole, you > > will find that this is not a fun job. I suggest you > > use a piece of > > plywood for kneeling over the opening. A trouble > > light will also help. > > > > When you have re-built the alternator, the > > process is just the > > reverse. You will need an air stapler or electric > > stapler to > > reinstall the carpet. > > > > Let me know if you need anything else. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > --- In WanderlodgeForum@yahoogroups.com > nelson > > slinkman > > > > > > > > My bed has the cross island queen. > > > I assume all the carpet has to be removed from the > > > rear bulkhead. Is there an access panel behind the > > > carpet. > > > > > > Thank > > > Nelson Slinkman > > > > > > > > > --- mbulriss <mbulriss@...> wrote: > > > > > > > In addition to Ron's comment, if it is a forward > > > > facing bed, the > > > > access is through a plate under the bed just in > > > > front of the rear > > > > closet wall. > > > > > > > > Mike Bulriss > > > > 1991 WB40 "Texas Minivan" > > > > San Antonio, TX > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > , > > > > "ronmarabito2002" > > > > > > > > > > > > > > If you have a cross-island bed, the access is > > in > > > > the floor of the > > > > > bedroom between the bed and the rear cabinets. > > > > > > I've done it a couple > > > > > of times. Let me know if that is your bed > > > > arrangement. > > > > > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > , > > > > "nslinkman" > > > > > wrote: > > > > > > > > > > > > Does anyone no the procedure to replace the > > rear > > > > alternator in a 1994 > > > > > > with an 8v92.I could not find any trap door > > in > > > > the bedroom area or > > > > > > inside the closet. Any help will be > > appreciated. > > > > > > Thanks in advance > > > > > > Nelson Slinkman 1994 40' > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________________ > > > Looking for a deal? Find great prices on flights > > and hotels with > > Yahoo! FareChase. > > > http://farechase.yahoo.com/ > > > > > > > > > > > __________________________________________________________ > Shape Yahoo! in your own image. Join our Network Research Panel today! > http://surveylink.yahoo.com/gmrs/yahoo_p...te.asp?a=7 > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
