'00 LXi Starter Batteries
08-07-2007, 03:55
We just returned from Maine to find the starter batteries too low to
start the engine. I know I can start the motor by using the emergency
switch on the dash, but my question is, if I leave this switch on
while the bus is stored, will the inverters keep both banks (house and
starters) of batteries charged?
Also, does anyone know how/if the generator battery is charged by the
inverters?
Thank you!
Allen and Conny
'00 LXi, "Lone Wolf"
Tampa, FL
08-07-2007, 04:00
Allen and Conny,
When the coach is plugged in, my understanding is that only the house batteries
are being charged unless you have both banks selected on the dash. Then I
believe all 10 are being charged. All are also charged by the alternator. Your
manual is the ultimate authority on that. I had original batteries..and had to
replace everything but my generator battery right after I bought the coach this
spring. Went with all AGM's at 250/per. Brad Barton 00LXiDFW
bbartonwx@...
To: WanderlodgeForum@...: gulfquest@...: Tue, 7 Aug
2007 15:55:55 +0000Subject: [WanderlodgeForum] '00 LXi Starter Batteries
We just returned from Maine to find the starter batteries too low to start the
engine. I know I can start the motor by using the emergency switch on the dash,
but my question is, if I leave this switch on while the bus is stored, will the
inverters keep both banks (house and starters) of batteries charged? Also, does
anyone know how/if the generator battery is charged by the inverters?Thank
you!Allen and Conny'00 LXi, "Lone Wolf"Tampa, FL
See what you’re getting into…before you go there
http://newlivehotmail.com/?ocid=TXT_TAGH...eview_0507
08-07-2007, 04:14
The chassis battery switch on the dash can be left on
when in storage. The converter will trickle charge the
chassis battery properly, according to Bennie. On my
coach the generator battery dash switch is a momentary
switch which means that the gennie battery is not charged
during storage. I purchased an Xantex Echo charger to
charge the gennie battery from the converter.
*http://tinyurl.com/yp48u2*
David Brady
'02 LXi, NC
> inverters?
> Thank you!
> Allen and Conny
> Tampa, FL
> Version: 7.5.476 / Virus Database: 269.11.8/940 - Release Date: 8/6/2007 4:53
PM
08-07-2007, 04:58
Thanks Brad! We bought our BB just 2 months ago and we are still
learning the systems. Our coach had 3 defective house gell cells
upon delivery which were replaced during the PDI. I'm not sure the
starters were checked though...I'll throw the switch tonight and see
how they do.
-Allen
--- In WanderlodgeForum@yahoogroups.com, brad barton <bbartonwx@...>
> Allen and Conny,
house batteries are being charged unless you have both banks
selected on the dash. Then I believe all 10 are being charged. All
are also charged by the alternator. Your manual is the ultimate
authority on that. I had original batteries..and had to replace
this spring. Went with all AGM's at 250/per. Brad Barton 00LXiDFW
bbartonwx@...
> To: WanderlodgeForum@...: gulfquest@...: Tue, 7 Aug 2007 15:55:55
to start the engine. I know I can start the motor by using the
emergency switch on the dash, but my question is, if I leave this
switch on while the bus is stored, will the inverters keep both
banks (house and starters) of batteries charged? Also, does anyone
> See what you're getting into…before you go there
ocid=TXT_TAGHM_migration_HM_viral_preview_0507
08-07-2007, 05:00
Thanks David! I knew you would know this one (you probably have the
answers to the filters and belts question I posted :-))
Where did you get the power for the Xantex in the genset battery
compartment?
-Allen
--- In WanderlodgeForum@yahoogroups.com, David Brady
> David Brady
> '02 LXi, NC
low to
emergency
(house and
by the
> > inverters?
> > Thank you!
> > Allen and Conny
> > Tampa, FL
8/6/2007 4:53 PM
08-07-2007, 06:15
Allen,
I tapped into the load center at the lower right dash.
As far as filters, Rich's list is pretty impressive. I have
one addition for the genny air filter:
NAPA 2222
David Brady
'02 LXi, NC
08-08-2007, 07:56
Great! Thanks Dave!
> Allen,
> NAPA 2222
> David Brady
> '02 LXi, NC
