'00 LXi Suspension Level Alarm
08-08-2007, 08:06
Hello Everyone! Since everyone solved the starter battery issue so
quickly, I thought I'd throw this one out to the the group...
After running the coach last night I noticed the suspension level
alarm and light would not turn off. The suspension appeared to come
up to full height front and rear. I dumped the suspension and waited
for it to come up again, which it did, but the alarm was still buzzing
away. The tag axle pressure seemed normal at ~80lbs.
Any suggestions as to starting the diagnosis process?
Thank you!
Allen & Conny
'00 LXi, "Lone Wolf"
Tampa Bay, FL
08-08-2007, 08:13
"Suspension level"?
On mine, Suspension and Level are two different things, with the latter meaning
the jacks aren't fully retracted.
Don Bradner
90 PT40 "Blue Thunder"
Eureka, CA
>Thank you!
>Allen & Conny
>Tampa Bay, FL
08-08-2007, 09:25
If your suspension level warning involves your jacks, it could be a jack sensor
gone bad or a jack that's not fully retracted. I have one sensor that's bad..so
the light stays on but the buzzer's been disabled I think. Eventually I'll get
to a BB rally and hope to have it fixed.Brad Barton 00LXiDFW
bbartonwx@...
To: WanderlodgeForum@...: bluethunder@...: Wed, 8
Aug 2007 13:13:22 -0700Subject: Re: [WanderlodgeForum] '00 LXi Suspension Level
Alarm
"Suspension level"?On mine, Suspension and Level are two different things, with
the latter meaning the jacks aren't fully retracted.Don Bradner90 PT40 "Blue
Thunder"Eureka, CAOn 8/8/2007 at 8:06 PM Allen & Conny wrote:>Hello Everyone!
Since everyone solved the starter battery issue so >quickly, I thought I'd throw
this one out to the the group...>>After running the coach last night I noticed
the suspension level >alarm and light would not turn off. The suspension
appeared to come >up to full height front and rear. I dumped the suspension and
waited >for it to come up again, which it did, but the alarm was still buzzing
>away. The tag axle pressure seemed normal at ~80lbs.>>Any suggestions as to
starting the diagnosis process?>>Thank you!>>Allen & Conny>'00 LXi, "Lone
Wolf">Tampa Bay, FL
Learn. Laugh. Share. Reallivemoms is right place!
http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us
08-08-2007, 09:29
Thanks Don! I stand corrected it is actually the light
marked "Level Warning." I assumed the jacks were fully retracted
because the "Travel" Light shows green on the HWH panel.
Is there a way to try to retract the jacks higher other than hitting
the "Store" button on the HWH panel?
Thanks!
-Allen
> "Suspension level"?
> Don Bradner
> Eureka, CA
so
come
waited
buzzing
> >Thank you!
> >Allen & Conny
> >Tampa Bay, FL
08-08-2007, 10:30
Sometimes a jack will stick (visual inspection will tell if there is silver
metal showing). Down, spray some lubricant, retract.
I think the sensor is tied to fluid level in the reservoir; if you have low
fluid level it will not shut off until you add fluid.
>Thanks!
>-Allen
>> "Suspension level"?
>> Don Bradner
>> Eureka, CA
>so
>come
>waited
>buzzing
>> >Thank you!
>> >Allen & Conny
>> >Tampa Bay, FL
08-08-2007, 10:40
Allen,
I believe the "level warning" lamp and buzzer also
takes the HWH slide control as input. I'd first walk
around the coach to take a look at each of the HWH
jacks. Make sure that they are fully retracted; i.e.,
no shiny cylinder visible. If you turn off the level control
to soon, a jack may stop before it's fully retracted.
I don't typically turn off the level control - I typically
wait till I put the bus in drive and then check to see that
the "travel" light is on. If so, then you can hit the off
button if you wish.
If you have a slide, it could be that it's not retracted
fully. The directions say that you should hold the retract
button until pressure builds in the retraction cylinder, is
diverted to the locking pins forcing the pins to lock and
the pressure in the hydraulic system to build causing
the pump to stop. At this point the red light on the
slide control panel will extinguish. Make sure you hold
the retract button until the light extinguishes. If you release
to soon, the pins won't engage the body of the slide, and
the buzzer will buzz, and (I believe), the dash level light will
stay on.
Note that I'm talking about 2 lights, the red light on the
HWH slide control panel and the "level" light on the dash.
David Brady
'02 LXi, Smokey
NC
> Thanks!
> -Allen
> , "Don Bradner"
> > "Suspension level"?
> > Don Bradner
> > Eureka, CA
> so
> come
> waited
> buzzing
> > >Thank you!
> > >Allen & Conny
> > >Tampa Bay, FL
> Version: 7.5.476 / Virus Database: 269.11.8/941 - Release Date: 8/7/2007 4:06
PM
08-08-2007, 10:55
More than likely there is something stuck. Drive the coach a short
distance and it will probably go away.
--- In WanderlodgeForum@yahoogroups.com, "Allen & Conny"
> Thank you!
> Allen & Conny
> Tampa Bay, FL
08-08-2007, 10:57
After reading Don Bradners response, I think he may be right. I had
it happen to me last January.
> Thank you!
> Allen & Conny
> Tampa Bay, FL
08-08-2007, 11:06
I Have a 2003 LXI AND HAD THIS PROBLEM PERIODCALLY, There Is A Purple Wire
in the Fused Panel On The
Outside Panel below the Driver's Window. Blue Bird And John Bleakly Both
Showed Me This Trick. I Finally Put
A Switch on the Dash to Turn It Off. You May Turn It Back Off In 5 Minutes
And The Sensors Will Be Happy. I Have Had
It Come On After Parking For A Few Minutes And Cranking Back Up.
Donny Goodwin 2003 LXI
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of David Brady
Sent: Wednesday, August 08, 2007 5:40 PM
Subject: Re: [WanderlodgeForum] Re: '00 LXi Suspension Level Alarm
Allen,
button if you wish.
stay on.
David Brady
'02 LXi, Smokey
NC
> Thanks!
> -Allen
yahoogroups.com
> , "Don Bradner"
> > "Suspension level"?
> > Don Bradner
> > Eureka, CA
> so
> come
> waited
> buzzing
> > >Thank you!
> > >Allen & Conny
> > >Tampa Bay, FL
4:06 PM
08-08-2007, 11:40
When I bought my coach that purple wire was snipped.
I reconnected it and diagnosed my slide pin that wasn't
engaging properly. I suppose there are cases where the
buzzer buzzes spontaneously, but I'm not sure that snipping
the wire is the best solution for all. I connected mine, fixed
the root cause, and she's been fine ever since.
David Brady
'02 LXi, NC
> _____
> Allen,
> button if you wish.
> stay on.
> David Brady
> '02 LXi, Smokey
> NC
> > Thanks!
> > -Allen
> yahoogroups.com
> > , "Don Bradner"
> > wrote:
> > > "Suspension level"?
> > > Don Bradner
> > > Eureka, CA
> > so
> > come
> > waited
> > buzzing
> > > >Thank you!
> > > >Allen & Conny
> > > >Tampa Bay, FL
> 4:06 PM
PM
