Hydraulic hose splices
08-12-2007, 06:09
One of my leveler hoses has a split very close to the fitting at the
jack. I bought a new hose from HWH, and set out to replace it. The problem, though, is that the other end of the hose at the actuator is unaccessible for removal. The other three leveler hoses are easily accessed, but the one I need is blocked out by a frame member...typical Murphy's law. Attempting to disassemble this entire area so I can get to the fitting is more project than I want to undertake, so I am wondering if there is some way I could leave the existing hose attached at that end, cut it at a more accessible spot, and then somehow splice in the new hose to the remaining old piece with some sort of fitting. Anyone think this is at all possible? Thanks Scott Forman 86 PT38 Memphis |
08-12-2007, 06:13
I would ask HWH.
On 12/08/07, Scott Forman <sforman@...> wrote: > > One of my leveler hoses has a split very close to the fitting at the > jack. I bought a new hose from HWH, and set out to replace it. The > problem, though, is that the other end of the hose at the actuator is > unaccessible for removal. The other three leveler hoses are easily > accessed, but the one I need is blocked out by a frame member...typical > Murphy's law. Attempting to disassemble this entire area so I can get > to the fitting is more project than I want to undertake, so I am > wondering if there is some way I could leave the existing hose attached > at that end, cut it at a more accessible spot, and then somehow splice > in the new hose to the remaining old piece with some sort of fitting. > Anyone think this is at all possible? > > Thanks > Scott Forman > 86 PT38 > Memphis > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
08-12-2007, 06:55
I just replaced the high pressure hydraulic suspension hose on my 85 300TD
Mercedes. The fittings at the ends are in two parts and can be unscrewed. It would be possible to do a splice should such a fitting be available in a union. I don't know if they are. When I took the Mercedes fittings to hydraulic hose shops they looked at me as if I was showing them a space alien so I suspect screw apart high pressure hydraulic hose fittings may not be readily available around here. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > One of my leveler hoses has a split very close to the fitting at the > jack. I bought a new hose from HWH, and set out to replace it. The > problem, though, is that the other end of the hose at the actuator is > unaccessible for removal. The other three leveler hoses are easily > accessed, but the one I need is blocked out by a frame member...typical > Murphy's law. Attempting to disassemble this entire area so I can get > to the fitting is more project than I want to undertake, so I am > wondering if there is some way I could leave the existing hose attached > at that end, cut it at a more accessible spot, and then somehow splice > in the new hose to the remaining old piece with some sort of fitting. > Anyone think this is at all possible? > > Thanks > Scott Forman > 86 PT38 > Memphis > |
08-12-2007, 07:26
I do not know what yours look like but aircraft hoses have a jacket that screws
over the outside of the hose and the connecting point screws inside. No big deal. Try to match one up at http://www.aircraftspruce.com. The difference is the flair fitting if that is what you have is different on aircraft. I think the flair is 100 degrees. It might entail changing the union. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion With 1977 280E Mercedes ----- Original Message ----- From: davidkerryedwards To: WanderlodgeForum@yahoogroups.com Sent: Sunday, August 12, 2007 1:55 PM Subject: [WanderlodgeForum] Re: Hydraulic hose splices I just replaced the high pressure hydraulic suspension hose on my 85 300TD Mercedes. The fittings at the ends are in two parts and can be unscrewed. It would be possible to do a splice should such a fitting be available in a union. I don't know if they are. When I took the Mercedes fittings to hydraulic hose shops they looked at me as if I was showing them a space alien so I suspect screw apart high pressure hydraulic hose fittings may not be readily available around here. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > One of my leveler hoses has a split very close to the fitting at the > jack. I bought a new hose from HWH, and set out to replace it. The > problem, though, is that the other end of the hose at the actuator is > unaccessible for removal. The other three leveler hoses are easily > accessed, but the one I need is blocked out by a frame member...typical > Murphy's law. Attempting to disassemble this entire area so I can get > to the fitting is more project than I want to undertake, so I am > wondering if there is some way I could leave the existing hose attached > at that end, cut it at a more accessible spot, and then somehow splice > in the new hose to the remaining old piece with some sort of fitting. > Anyone think this is at all possible? > > Thanks > Scott Forman > 86 PT38 > Memphis > [Non-text portions of this message have been removed] |
