Update On My Status In Reno....
09-09-2007, 03:55
Hello Fellow Wanderlodgers:
Luckily for me, I brought along a free round trip plane ticket when I
departed for my first cross country road trip in my 83' FC-35.
I flew home to NJ a few days ago.
My Wanderlodge is still in the Sierra Freightliner (certified by
Caterpillar) shop in Reno, Nevada. I just heard from the mechanic who
told me, to my relief, that my 3208 engine failure was due to a blown
head gasket. Unfortunately, they had to pull the engine completely
out of the bus to remove the heads and determine the problem.
The labor has already cost me over $3,000.
They are going to call me back tomorrow with estimates on how much a
new head gasket will cost. The mechanic recommended that I consider
replacing the gasket on the other side of the engine as well, now that
the entire motor is sitting on a stand.
Do you folks recommend I replace the other gasket? Are there any
other jobs I should have them do while the engine is out?
Special thanks to everyone who responded to my panic e-mails a few
weeks ago when the bus first broke down. I do appreciate all the
advice and well wishes you sent me.
I'll be flying back to Reno once the bus is fixed to resume the long
ride home to NJ.
Thanks again! I'll keep you all updated.
Andy Coleman
83' FC-35
Spring Lake Hts., NJ
09-09-2007, 04:07
Yes!!!
Also have the valve lash checked and set, change the thermostats perhaps
and check the tightness of the bolts holding the fuel injection pump. Also
check the condition of the oil dip stick tube for holes and so forth.
While engine is out of the way, just a general check of air valves might be
a good idea as well.
Safe travels,
84FC35
Duncan, Oklahoma
>Andy Coleman
>83' FC-35
09-09-2007, 04:41
Andy,
Hopefully R.E. Brake, The Putney Flash will give you his thoughts. Come on R.E.
what do you say.
Howard T.,
Sent: Sunday, September 09, 2007 11:55 AM
Subject: [WanderlodgeForum] Update On My Status In Reno....
ride home to NJ.
Andy Coleman
83' FC-35
Checked by AVG Free Edition.
Version: 7.5.485 / Virus Database: 269.13.10/995 - Release Date: 9/8/2007 1:24
PM
09-09-2007, 05:12
Andy, I would have them repace the water hoses on the front of the engine
,the two small heater hose are very hard to repalce with the engine in the
BB. Dave 91 WBWL 40
>From: "Howard O. Truitt" >Reply-To: WanderlodgeForum@yahoogroups.com
>To:
>Subject: Re: [WanderlodgeForum] Update On My Status In Reno....
>Date: Sun, 9 Sep 2007 12:41:07 -0400
>Andy,
>R.E.
>what do you say.
>Howard T.,
> From: Andy Coleman
> ride home to NJ.
> Andy Coleman
> 83' FC-35
>9/8/2007 1:24 PM
09-09-2007, 05:27
Glad to learn that you are not looking at a total rebuild or
replacement. I am just curious what type of hourly rate is typical
for this type of work? I am just thinking out loud. $3000 to get the
engine out and I would assume as much to put it back. Ouch!!! Does
it take that long or are the hourly rates just that high? The guy
turning the wrenches likely sees very little of that as well. Just
wondering.
John Heckman
central Pa
1973 FC
engine
in the
> BB. Dave 91 WBWL 40
> >From: "Howard O. Truitt" > >Reply-To: WanderlodgeForum@yahoogroups.com
> >To:
> >Andy,
Come on
> >R.E.
> >what do you say.
> >Howard T.,
> > From: Andy Coleman
when I
mechanic who
blown
completely
much a
consider
now that
few
long
> > ride home to NJ.
> > Andy Coleman
> > 83' FC-35
Date:
> >9/8/2007 1:24 PM
09-10-2007, 01:26
Andy:
That news is better than a problem with a block. Others have given good advice.
I'm just
curious as to why the engine had to be removed. I was under the impression that
with the
doghouse removed, the heads could have been pulled with the engine in place.
Anyone
have experience with this that can elaborate on why the engine needs to come out
for
head gasket replacement?
Kerry
82 Fc 35
Denver
> ride home to NJ.
> Andy Coleman
> 83' FC-35
09-11-2007, 03:42
> Andy:
good advice. I'm just
impression that with the
in place. Anyone
needs to come out for
> Kerry
> 82 Fc 35
> Denver
when I
mechanic who
blown
completely
much a
consider
that
long
> > ride home to NJ.
> > Andy Coleman
> > 83' FC-35
Andy
Without question you should replace the other head gasket. Ask for a
garentee for a certain number of miles/months too so that if it fails
again right away you will not have to pay. Also I would replace the
thermostat (they call it something else) and the fan switch ( the
thermostatic switch that turns on the fan). It is in the top of the
block I think and should/could have been damaged by overheating.
Good luck
Bob Criss
90SP36
09-11-2007, 05:31
Hello John,
Sorry for my delay reponding to you...
The Reno Sierra Freighliner has two hourly rates. They charge
$135/hour for "RVs and Buses" and $95/hour for "trucks".
They agreed, given the size of my job, to charge me the $95 per hour rate.
I think $95 is an average cost around the country. Unfortunately, I
was not lucky enough to find a shop with below average cost.
At this point, I'm just hoping the job is done right.
Andy Coleman
83' FC-35
Spring Lake, NJ
--- In WanderlodgeForum@yahoogroups.com, "bubblerboy64"
> wondering.
> John Heckman
> central Pa
> 1973 FC
> engine
> in the
> > BB. Dave 91 WBWL 40
> > >From: "Howard O. Truitt" > > >Reply-To: WanderlodgeForum@yahoogroups.com
> > >To:
> > >Andy,
> Come on
> > >R.E.
> > >what do you say.
> > >Howard T.,
> > > From: Andy Coleman
> when I
> mechanic who
> blown
> completely
> much a
> consider
> now that
> few
> long
> > > ride home to NJ.
> > > Andy Coleman
> > > 83' FC-35
> Date:
> > >9/8/2007 1:24 PM
09-11-2007, 16:19
Andy,
$135 AN HOUR!! Ouch! Even your reduced rate is high.
Prevost in Nashville has a rate of $97 an hour. I cringe every time I
go there. The Detroit Deisel shop in Huntsville Al. is under $80. The
guy who ownes the shop just bought a 96 PT-42 so they are kinda
sypathetic to our needs. Good luck and make them give you a warantee.
Kurt Horvath
'95 PT-42
> Hello John,
hour rate.
> Andy Coleman
> 83' FC-35
> Spring Lake, NJ
typical
Does
Just
> > wondering.
> > John Heckman
> > central Pa
> > 1973 FC
> > engine
engine
> > in the
> > > BB. Dave 91 WBWL 40
> > > >From: "Howard O. Truitt" > > > >Reply-To: WanderlodgeForum@yahoogroups.com
> > > >To:
> > > >Andy,
thoughts.
> > Come on
> > > >R.E.
> > > >what do you say.
> > > >Howard T.,
> > > > From: Andy Coleman
ticket
> > when I
35.
(certified by
> > mechanic who
to a
> > blown
> > completely
problem.
how
> > much a
> > consider
well,
> > now that
there any
mails a
> > few
all the
> > long
> > > > ride home to NJ.
> > > > Andy Coleman
> > > > 83' FC-35
> > Date:
> > > >9/8/2007 1:24 PM
09-11-2007, 16:49
Expecting shop rates to be similar from state-to-state is like expecting housing
prices to be similar.
$95 is quite common in larger Western cities. I'm not surprised that it might be
lower in Alabama. Apples and Oranges.
Don Bradner
90 PT40 "Blue Thunder"
Posting today by satellite from Boise, Idaho, headed towards Salt Lake City
tomorrow.
On 9/12/2007 at 4:19 AM bumpersbird wrote:
>Andy,
>Kurt Horvath
>'95 PT-42
>> Hello John,
>hour rate.
>> Andy Coleman
>> 83' FC-35
>> Spring Lake, NJ
>typical
>the
>Does
>Just
>> > wondering.
>> > John Heckman
>> > central Pa
>> > 1973 FC
>the
>> > engine
>engine
>> > in the
>> > > BB. Dave 91 WBWL 40
>> > > >From: "Howard O. Truitt" >> > > >Reply-To: WanderlodgeForum@yahoogroups.com
>> > > >To:
>> > > >Andy,
>thoughts.
>> > Come on
>> > > >R.E.
>> > > >what do you say.
>> > > >Howard T.,
>> > > > From: Andy Coleman
>ticket
>> > when I
>35.
>(certified by
>> > mechanic who
>to a
>> > blown
>> > completely
>problem.
>how
>> > much a
>> > consider
>well,
>> > now that
>there any
>mails a
>> > few
>all the
>the
>> > long
>> > > > ride home to NJ.
>> > > > Andy Coleman
>> > > > 83' FC-35
>> > Date:
>> > > >9/8/2007 1:24 PM
>Yahoo! Groups Links
