Transmission "Do Not Shift" Light and Code 22 (Speed Sensor)
09-13-2007, 13:48
Greetings All; I started my coach today which has been sitting in
covered storage with shore power for about two weeks. The
transmission "Do Not Shift" light and check transmission light are
staying on. It flashes a Code 22 which indicates a Speed Sensor issue.
Does anyone have any experience with this issue? I did not note any
transmission problems on my last trip which was about two weeks ago. I
cleaned the ground strap connections on the transmission and frame and
checked the transmission cannon plug but the warning lights remain on.
Thanks. David Hanvy 89WB PT40 Crosby, TX
09-13-2007, 23:14
Although I don't think your bus would start if the remote rear start switch was
acting up, mine will give me a do not shift light in the rear start position and
in the front position if it is not engaged properly. Not all coaches are wired
to give a do not shift light on the remote rear start position but mine does. I
have never checked my codes so can't help there. I would cycle that switch to
rear, off, and back to front, restart and see what happens.. It is a long shot
but easy to do.
Let us know what you find for future reference.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Royale Conversion
Sent: Thursday, September 13, 2007 8:48 PM
Subject: [WanderlodgeForum] Transmission "Do Not Shift" Light and Code 22
(Speed Sensor)
09-14-2007, 06:09
Leroy/Kevin,
Thanks for your replies. I started the engine from the rear remote
and the transmission warning light/do not shift remains on. No change
when I switched back to the front either. Additionally, I
disconnected from shore power and disconnected the ground cable on
the battery bank in an effort to reset the tranny. No luck on that
either. (do not shift equals WILL not shift) I plan to to locate and
read up on the Speed Sensor as a next step.
All input is appreciated. David Hanvy 89WB PT40 Crosby, TX
start switch was acting up, mine will give me a do not shift light in
the rear start position and in the front position if it is not
engaged properly. Not all coaches are wired to give a do not shift
light on the remote rear start position but mine does. I have never
long shot but easy to do.
> Leroy Eckert
> Niceville, FL
> Royale Conversion
> From: David Hanvy
are
issue.
any
ago. I
frame and
remain on.
09-14-2007, 07:02
David, I chased a do not shift light for months. mine would go out
when the coach was started and come on when the bus was shut off.
Finally found loose wire on back of ignition switch. Low voltage
and bad grounds do weird stuff to theses beasts. If you are unable
to solve I'll get you the phone number for Industrial Transmission
in Waco. They have the best Allison techs I have found and are
usually willing to help you on the phone. Mike McMahan 1989 PT40
--- In WanderlodgeForum@yahoogroups.com, "David Hanvy" <shanvy@...>
> Leroy/Kevin,
change
in
never
a
> > Leroy Eckert
> > Niceville, FL
> > Royale Conversion
> > From: David Hanvy
in
> are
Sensor
> issue.
note
> any
weeks
> ago. I
> frame and
> remain on.
09-14-2007, 08:51
Mike, Thanks for the input. I'll check the ignition switch wiring on
both the front and rear remote. I would appreciate the contact info re
Industrial Transmission in anycase. The local Allison rep is the
Houston Stewart & Stevenson shop. I have spent more than a reasonable
amount of $$ with this outfit on other type repairs in the past.
David Hanvy 89WB Crosby, TX
--- In WanderlodgeForum@yahoogroups.com, "Mike McMahan"
out
> --- In WanderlodgeForum@yahoogroups.com, "David Hanvy" <shanvy@>
> > Leroy/Kevin,
remote
> change
on
that
> and
light
> in
shift
> never
to
is
> a
> > > Leroy Eckert
> > > Niceville, FL
> > > Royale Conversion
> > > From: David Hanvy
> and
sitting
> in
light
> > are
> Sensor
> > issue.
> note
> > any
> weeks
> > ago. I
> > frame and
> > remain on.
09-14-2007, 09:18
Howard, Industrial Transmission Ray Dobbs 254-776-4436 outside of
Waco, Tx I would reccomend them highly. Ray's brother Mike is the
Stewart and Stevenson shop manager in Hewitt, Tx great team. Mike
McMahan 1989 PT 40
on
info re
reasonable
> out
off.
voltage
unable
Transmission
PT40
> > wrote:
> > > Leroy/Kevin,
> remote
> > change
cable
> on
> that
locate
> > and
rear
> light
> > in
> shift
> > never
switch
> to
It
> is
> > a
> > > > Leroy Eckert
> > > > Niceville, FL
> > > > Royale Conversion
> > > > From: David Hanvy
Light
> > and
> sitting
> > in
> light
> > > are
> > Sensor
> > > issue.
> > note
> > > any
> > weeks
> > > ago. I
> > > frame and
lights
> > > remain on.
09-15-2007, 11:27
All, I'm sorry to report that my best efforts yielded no progress
today. I'll sleep on it and if nothing else occurs to me to try, I'll
give Industrial Transmission a call on Monday. Hate to think what a
pain it would be to have get the coach towed. It's inside a storage
building and there is very lttle room to maneuver in and out of the
facility in the base case. David Hanvy, 89WB PT40 Crosby, TX
> McMahan 1989 PT 40
> on
> info re
> reasonable
go
> > out
> off.
> voltage
> unable
> Transmission
> PT40
<shanvy@>
> > > wrote:
> > > > Leroy/Kevin,
> > remote
No
> > > change
> cable
> > on
> > that
> locate
> > > and
> rear
> > light
> > > in
not
> > shift
> > > never
> switch
> > to
> It
> > is
> > > a
> > > > > Leroy Eckert
> > > > > Niceville, FL
> > > > > Royale Conversion
> > > > > From: David Hanvy
> Light
> > > and
> > sitting
> > > in
> > light
> > > > are
> > > Sensor
> > > > issue.
not
> > > note
> > > > any
> > > weeks
> > > > ago. I
> and
> > > > frame and
> lights
> > > > remain on.
09-17-2007, 09:13
Hoorah for a happy ending; Thanks to all who responded. The problem
was finally found to be a bad connection on the connector plug going
to the speed sensor. It looked okay but ony worked after a liberal
spraying of contact cleaner and an application of connector
compound/grease. I did gleam the following info for anyone with an
Allison HTB 748 tranny. A correctly functioning speed sensor on this
tranny should read from 116 to 165 ohms (per Industrial Transmission)
when checked across the two leads. David Hanvy 89WB PT40 TX
I'll
Mike
> > McMahan 1989 PT 40
wiring
> > on
> > info re
> > reasonable
> go
> > > out
> > off.
> > voltage
> > unable
> > Transmission
are
> > PT40
> <shanvy@>
> > > > wrote:
> > > > > Leroy/Kevin,
> > > remote
> No
> > > > change
> > cable
> > > on
on
> > > that
> > locate
> > > > and
> > rear
shift
> > > light
> > > > in
> not
not
> > > shift
have
> > > > never
> > switch
> > > to
happens..
> > It
> > > is
> > > > a
> > > > > > Leroy Eckert
> > > > > > Niceville, FL
> > > > > > Royale Conversion
> > > > > > From: David Hanvy
> > Light
> > > > and
> > > sitting
> > > > in
The
transmission
> > > light
> > > > > are
Speed
> > > > Sensor
> > > > > issue.
> not
> > > > note
> > > > > any
two
> > > > weeks
> > > > > ago. I
transmission
> > and
> > > > > frame and
> > lights
> > > > > remain on.
09-17-2007, 12:20
David,
Thank you for your posting. I've saved it in my Good-Things-To-Know,
Transmission Info. folder.
> I'll
> "Mike McMahan"
> the
> Mike
> > > McMahan 1989 PT 40
> > > --- In
> wiring
> > > on
> > > info re
> the
> > > reasonable
> > > > --- In
> "Mike McMahan"
> > go
> > > > out
> > > off.
> > > voltage
> > > unable
> > > Transmission
> are
> > > PT40
> > > > > --- In
> "David Hanvy"
> > <shanvy@>
> > > > > wrote:
> > > > > > Leroy/Kevin,
> > > > remote
> > No
> > > > > change
> > > cable
> > > > on
> on
> > > > that
> > > locate
> > > > > and
> > > > > > --- In
> "Leroy Eckert"
> > > rear
> shift
> > > > light
> > > > > in
> > not
> not
> > > > shift
> have
> > > > > never
> > > switch
> > > > to
> happens..
> > > It
> > > > is
> > > > > a
> > > > > > > Leroy Eckert
> > > > > > > Niceville, FL
> > > > > > > Royale Conversion
> > > > > > > From: David Hanvy
> > > > > > > To:
> > > Light
> > > > > and
> > > > sitting
> > > > > in
> The
> transmission
> > > > light
> > > > > > are
> Speed
> > > > > Sensor
> > > > > > issue.
> > not
> > > > > note
> > > > > > any
> two
> > > > > weeks
> > > > > > ago. I
> transmission
> > > and
> > > > > > frame and
> > > lights
> > > > > > remain on.
Curt Sprenger
Anaheim Hills, CA
09-17-2007, 14:37
Thanks for the report. Happy it was something simple.
One question. What prompted you to zero in on the speed sensor? Do you have a
drawing of the TCM wiring and functions? If the bus is not moving how does the
speed sensor affect the shifter pad, if you know? Just for future reference. I
would like to know more since I do not have a manual or drawing on my TCM.
Thanks
Leroy Eckert
Niceville, FL
Royale Conversion
Sent: Friday, September 14, 2007 1:09 PM
Subject: [WanderlodgeForum] Re: Transmission "Do Not Shift" Light and Code 22
(Speed Sensor)
Leroy/Kevin,
> Leroy Eckert
> Niceville, FL
> Royale Conversion
> From: David Hanvy
are
issue.
any
ago. I
frame and
remain on.
