M380 Plasma moniter replacement
09-26-2007, 13:23
The TV monitor in my rig needs to be replaced. Has anyone had to
replace theirs? It appears Panasonic has a new version available model TH-37PH10UK. If anyone has replaced the unit, where did you puchase it from. I am in Massachusetts. Thank you Ross Rosano W000197 |
09-27-2007, 02:05
Ross,
I would seriously consider replacing it with a like size LCD if available. Much less weight, no burn-in and many times less fragile. The new LCD's rival the picture quality of plasma without the problems associated with plasma in the extreme conditions associated with a vehicle. JMHO, others may vary. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "Ross Rosano" wrote: > > The TV monitor in my rig needs to be replaced. Has anyone had to > replace theirs? It appears Panasonic has a new version available > model TH-37PH10UK. If anyone has replaced the unit, where did you > puchase it from. I am in Massachusetts. Thank you > > > Ross Rosano > W000197 > |
09-27-2007, 14:50
I have to agree with Rich here. Don't waste your money on another
plasma if you can help it. Get yourself an LCD. Only thing you have to worry about is physical dimensions - if it will fit and you like the picture you see on the store's display unit, buy it and don't look back. -Ryan '86 PT-40 8V92 On 9/27/07, g_man1146 > > Ross, > I would seriously consider replacing it with a like size LCD if > available. Much less weight, no burn-in and many times less fragile. > The new LCD's rival the picture quality of plasma without the > problems associated with plasma in the extreme conditions associated > with a vehicle. JMHO, others may vary. > > Rich D. '99LXi43' CT |
09-28-2007, 14:08
Thanks for your thoughts Ryan, I appreciated them. Ross R. M380
--- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > I have to agree with Rich here. Don't waste your money on another > plasma if you can help it. Get yourself an LCD. Only thing you have to > worry about is physical dimensions - if it will fit and you like the > picture you see on the store's display unit, buy it and don't look > back. > > -Ryan > '86 PT-40 8V92 > > On 9/27/07, g_man1146 > > > > Ross, > > I would seriously consider replacing it with a like size LCD if > > available. Much less weight, no burn-in and many times less fragile. > > The new LCD's rival the picture quality of plasma without the > > problems associated with plasma in the extreme conditions associated > > with a vehicle. JMHO, others may vary. > > > > Rich D. '99LXi43' CT > |
