Battery Charger
10-01-2007, 05:12
Battery Charger
Alvie I've had good luck with twin IOTA 55amp. You need a single IQ4 smart
charger for dual chargers. Do not try to use two chargers each with their
own smart charger. This will cause them to conflict. You need the single IQ4
to regulate both IOTAs. You should be able to get both IOTAs and the IQ4 for
between $300 and $350. If you want top-of-the line then I would go with
Xantrex equipment
On 01/10/2007, whynotam wrote:
> I went out to the coach yesterday to check the fridge and noticed the
> gas alarm was beeping. Long story short, the battery charger had gone
> south and thus the house bateries were down to almost zip. Any
> suggestions on what charger to buy? I have 8 deep cycle 12 volt house
> batteries as well as the standard 3 starting batteries. Thanks for your
> assistance.
> Alvie Miller
> Arthur IL
> 1993 WLWB 40'
Rob, Sue & Merlin Robinson
94 WLWB
10-01-2007, 05:18
Battery Charger
--- In WanderlodgeForum@yahoogroups.com, "Rob Robinson"
IQ4 smart
their
single IQ4
the IQ4 for
with
> Xantrex equipment
noticed the
gone
house
for your
> > assistance.
> > Alvie Miller
> > Arthur IL
> > 1993 WLWB 40'
> 94 WLWB
Rob,
Will both chargers fit in the compartment where the present one is?
The 3000 Watt inverter is also in that compartment. Do both chargers
come on at the same time? Is the Xantrex quite a bit more money?
Thanks again.
Alvie Miller
Arthur IL
1993 WLWB 40'
10-01-2007, 05:51
Battery Charger
Alvie my IOTAs are located in the same bay as the BBQ and tool box so I
can't speak to their placement in the battery compartment. I seem to recall
that others have put them there but not sure. If you go with Xantrex you
could use two Tru-charge 40s and that will likely cost close to $800 for two
of them.
> "Rob Robinson"
> IQ4 smart
> their
> single IQ4
> the IQ4 for
> with
> > Xantrex equipment
> noticed the
> gone
> house
> for your
> > > assistance.
> > > Alvie Miller
> > > Arthur IL
> > > 1993 WLWB 40'
> > 94 WLWB
> Rob,
> Thanks again.
> Alvie Miller
> Arthur IL
> 1993 WLWB 40'
94 WLWB
10-01-2007, 06:33
Battery Charger
I've heard good reports about the Xantrex 40+ three-stage charger. See:
<http://www.xantrex.com/web/id/69/p/1/pt/7/product.asp>
Or, you may want to upgrade both your charger and inverter with a new
inverter-charger.
Pete Masterson
El Sobrante CA
aeonix1@...
> your
> assistance.
10-01-2007, 06:36
Battery Charger
Xantrex 40+ is $355 at Amazon.com
Pete Masterson
El Sobrante CA
aeonix1@...
> IQ4 smart
> their
> single IQ4
> the IQ4 for
> with
>> Xantrex equipment
> noticed the
> gone
> house
> for your
>>> assistance.
>>> Alvie Miller
>>> Arthur IL
>>> 1993 WLWB 40'
>> 94 WLWB
> Rob,
> Thanks again.
> Alvie Miller
> Arthur IL
> 1993 WLWB 40'
10-01-2007, 06:45
Battery Charger
Alvie, Pete's suggestion for an upgrade to an inverter/charger combination
is certainly worth considering. If you could get anything for your existing
inverter it would make the $$$ numbers better.
> inverter-charger.
> Pete Masterson
> El Sobrante CA
> aeonix1@...
> > your
> > assistance.
94 WLWB
10-01-2007, 07:12
Battery Charger
I will check to see what model inverter I have tonight after work to
see if it might have some resale value. Would installation
instructions that come with a new unit be adequate for an
electrically challenged person to do the install? Also I am not quite
clear on why two chargers are required instead of just one like I
have now. Is it for redundancy?
Alvie Miller
Arthur IL
1993 WLWB 40'
combination
existing
charger. See:
new
> > inverter-charger.
> > Pete Masterson
> > El Sobrante CA
> > aeonix1@...
noticed the
had gone
house
for
> > > your
> > > assistance.
> 94 WLWB
10-01-2007, 07:18
Battery Charger
First off you might want to contact Curt Sprenger as I believe he has done
some of this work. I believe you need two chargers to reduce the time it
takes to put a charge into 8 batteries. I have eight 6V golf carts for the
house and the more chargers the better. It isn't redundancy like the two
water pumps
> Alvie Miller
> Arthur IL
> 1993 WLWB 40'
> "Rob Robinson"
> combination
> existing
> charger. See:
> new
> > > inverter-charger.
> > > Pete Masterson
> > > El Sobrante CA
> > > aeonix1@...
> noticed the
> had gone
> house
> for
> > > > your
> > > > assistance.
> > 94 WLWB
94 WLWB
10-01-2007, 07:26
Battery Charger
Curt,
Help.
Thanks,
Alvie Miller
Arthur IL
93 WLWB 40'
has done
time it
for the
the two
> water pumps
work to
quite
> > Alvie Miller
> > Arthur IL
> > 1993 WLWB 40'
> > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > "Rob Robinson"
> > combination
your
> > existing
> > charger. See:
with a
> > new
> > > > inverter-charger.
> > > > Pete Masterson
> > > > El Sobrante CA
> > > > aeonix1@
> > noticed the
> > had gone
Any
volt
> > house
Thanks
> > for
> > > > > your
> > > > > assistance.
> > > 94 WLWB
> 94 WLWB
10-01-2007, 08:16
Battery Charger
Alvie you could also talk to Greg OConnor who I believe has recently put in
L16 batteries (floor polisher, electric forklift batteries) and a new
Xanatrex system. Greg and Curt are pretty knowledgeable guys
> Curt,
> Help.
> Thanks,
> Alvie Miller
> Arthur IL
> 93 WLWB 40'
> "Rob Robinson"
> has done
> time it
> for the
> the two
> > water pumps
> work to
> quite
> > > Alvie Miller
> > > Arthur IL
> > > 1993 WLWB 40'
> > > --- In
> > 40yahoogroups.com>,
> > > "Rob Robinson"
> > > combination
> your
> > > existing
> > > charger. See:
> with a
> > > new
> > > > > inverter-charger.
> > > > > Pete Masterson
> > > > > El Sobrante CA
> > > > > aeonix1@
> > > noticed the
> > > had gone
> Any
> volt
> > > house
> Thanks
> > > for
> > > > > > your
> > > > > > assistance.
> > > > 94 WLWB
> > 94 WLWB
94 WLWB
