89sp 3208 cat large air filter removal, how do you
11-15-2007, 11:37
Hi Ed
If I remember right you are going about it the right way. The end cap should come off after you take the two clamps lose. I have had mine off & all out of there & it is not a nice job.It is hard to get back together again or it was for me. Don 89 SP 36' Butler, PA have removed the 2 clamps from the large (11 in diam.by 30in long) filter canaster. Ihave also removed the outside air duct thatgoes to it. Does the end cap come off of the large cylinder around the filter or does the whole thing unscrew or something? Is there another fastner on the far end thatI cant see? Thanks for any help Ed Gardels 89sp Arlington Tx. ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
11-15-2007, 16:22
I have removed the 2 clamps from the large (11 in diam.by 30in long)
filter canaster. Ihave also removed the outside air duct thatgoes to it. Does the end cap come off of the large cylinder around the filter or does the whole thing unscrew or something? Is there another fastner on the far end thatI cant see? Thanks for any help Ed Gardels 89sp Arlington Tx. |
11-16-2007, 01:52
--- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote:
> > Hi Ed > If I remember right you are going about it the right way. The end cap > should come off after you take the two clamps lose. I have had mine off & all > out of there & it is not a nice job.It is hard to get back together again or it > was for me. > Don > 89 SP 36' > Butler, PA > > have removed the 2 clamps from the large (11 in diam.by 30in long) > filter canaster. Ihave also removed the outside air duct thatgoes to it. > Does the end cap come off of the large cylinder around the filter or > does the whole thing unscrew or something? Is there another fastner on > the far end thatI cant see? > Thanks for any help > Ed Gardels 89sp > Arlington Tx. > > Hi Ed and Don I too have an SP36 and have changed my air filter many times. The end cap does not come off of any of the filters I used. You (Ed) did all but remove the large diameter hose clamp from the air exit hose. It is very hard to see (feel) and is on the engine side of the filter canister. Again if you fellows have a filter that has a replaceable element (by taking off the end cap) then yours is different than mine. My filter is, except for the large mouthed horn assembly, one metal unit with a paper filter element contained inside. Interesting to weigh the new filter and the used one and compare!! Cheers Bob Criss 90SP36 Bethel Park, PA > > > > > > ************************************** See what's new at http://www.aol.com > > > [Non-text portions of this message have been removed] > |
11-16-2007, 02:15
We have the same 300 HP 3208, but our engine is upfront.
If the filter in the same, Bob in correct there in a band clamp. Not sure if the filter is the same , But I installed a Fram #CA6622, It is all one piece, a large canister with a pleated filter inside. Goto http://www.napaonline.com type in part # 6848. This is an example of the filter, not sure if this will fit your SP. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "crissrace" wrote: > > --- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: > > > > Hi Ed > > If I remember right you are going about it the right way. The > end cap > > should come off after you take the two clamps lose. I have had > mine off & all > > out of there & it is not a nice job.It is hard to get back > together again or it > > was for me. > > Don > > 89 SP 36' > > Butler, PA > > > > have removed the 2 clamps from the large (11 in diam.by 30in long) > > filter canaster. Ihave also removed the outside air duct thatgoes > to it. > > Does the end cap come off of the large cylinder around the filter > or > > does the whole thing unscrew or something? Is there another > fastner on > > the far end thatI cant see? > > Thanks for any help > > Ed Gardels 89sp > > Arlington Tx. > > > > Hi Ed and Don > I too have an SP36 and have changed my air filter many times. The > end cap does not come off of any of the filters I used. You (Ed) did > all but remove the large diameter hose clamp from the air exit hose. > It is very hard to see (feel) and is on the engine side of the filter > canister. Again if you fellows have a filter that has a replaceable > element (by taking off the end cap) then yours is different than > mine. My filter is, except for the large mouthed horn assembly, one > metal unit with a paper filter element contained inside. Interesting > to weigh the new filter and the used one and compare!! > Cheers > Bob Criss > 90SP36 > Bethel Park, PA > > > > > > > > > > > > ************************************** See what's new at > http://www.aol.com > > > > > > [Non-text portions of this message have been removed] > > > |
11-16-2007, 09:30
Bob
You are right. It has been a couple of years since I have changed mine. I just found my sight glass this past summer to show you when the filter gets clogged. Don 89 SP 36' Butler, PA Hi Ed and Don I too have an SP36 and have changed my air filter many times. The end cap does not come off of any of the filters I used. You (Ed) did all but remove the large diameter hose clamp from the air exit hose. It is very hard to see (feel) and is on the engine side of the filter canister. Again if you fellows have a filter that has a replaceable element (by taking off the end cap) then yours is different than mine. My filter is, except for the large mouthed horn assembly, one metal unit with a paper filter element contained inside. Interesting to weigh the new filter and the used one and compare!! Cheers Bob Criss 90SP36 Bethel Park, PA ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
