Refineco Oil Purifiner
05-10-2005, 13:18
I'm a newby wanderlodge owner and need a little help. We have a 1984
PT40 and I'm slowly but surely learning it, however in reading the manual it says to change the Purifiner filter every 12 months, but for the life of me I can't find it. Can anyone give me a clue, I thought I'd looked everywhere, but to no avail. James & Mercy Lashua Fernley, NV 1984 PT40 |
05-10-2005, 13:35
The chances are, you don't have one. I believe they were an option
back then, or the original owner took it off. That filter was a bypass filter and is not necessary for operating your engine. It could however be a benefit if you had it. It would be in the engine compartment and probably attached to the frame. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "jdlashua" wrote: > I'm a newby wanderlodge owner and need a little help. We have a 1984 > PT40 and I'm slowly but surely learning it, however in reading the > manual it says to change the Purifiner filter every 12 months, but for > the life of me I can't find it. Can anyone give me a clue, I thought > I'd looked everywhere, but to no avail. > > James & Mercy Lashua > Fernley, NV > 1984 PT40 |
05-10-2005, 13:42
Thanks for the info.
ronmarabito2002 I believe they were an option back then, or the original owner took it off. That filter was a bypass filter and is not necessary for operating your engine. It could however be a benefit if you had it. It would be in the engine compartment and probably attached to the frame. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "jdlashua" wrote: > I'm a newby wanderlodge owner and need a little help. We have a 1984 > PT40 and I'm slowly but surely learning it, however in reading the > manual it says to change the Purifiner filter every 12 months, but for > the life of me I can't find it. Can anyone give me a clue, I thought > I'd looked everywhere, but to no avail. > > James & Mercy Lashua > Fernley, NV > 1984 PT40 --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-10-2005, 13:54
i have never seen one on a bird.i wonder just where they would put
it!!randydupree93wb ----- Original Message ----- From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, May 10, 2005 9:35 PM Subject: [WanderlodgeForum] Re: Refineco Oil Purifiner The chances are, you don't have one. I believe they were an option back then, or the original owner took it off. That filter was a bypass filter and is not necessary for operating your engine. It could however be a benefit if you had it. It would be in the engine compartment and probably attached to the frame. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "jdlashua" wrote: > I'm a newby wanderlodge owner and need a little help. We have a 1984 > PT40 and I'm slowly but surely learning it, however in reading the > manual it says to change the Purifiner filter every 12 months, but for > the life of me I can't find it. Can anyone give me a clue, I thought > I'd looked everywhere, but to no avail. > > James & Mercy Lashua > Fernley, NV > 1984 PT40 ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-10-2005, 15:23
Randy: They could mount it virtually anywhere there was room as
long as the filter was above the oil level in the pan. One to two feet would be good, because it would drain well. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > i have never seen one on a bird.i wonder just where they would put it!!randydupree93wb > ----- Original Message ----- > From: ronmarabito2002 > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, May 10, 2005 9:35 PM > Subject: [WanderlodgeForum] Re: Refineco Oil Purifiner > > > The chances are, you don't have one. I believe they were an option > back then, or the original owner took it off. That filter was a > bypass filter and is not necessary for operating your engine. It > could however be a benefit if you had it. It would be in the engine > compartment and probably attached to the frame. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > Moderator > > > > > --- In WanderlodgeForum@yahoogroups.com, "jdlashua" > wrote: > > I'm a newby wanderlodge owner and need a little help. We have a 1984 > > PT40 and I'm slowly but surely learning it, however in reading the > > manual it says to change the Purifiner filter every 12 months, but > for > > the life of me I can't find it. Can anyone give me a clue, I thought > > I'd looked everywhere, but to no avail. > > > > James & Mercy Lashua > > Fernley, NV > > 1984 PT40 > > > > > ------------------------------------------------------------------- ----------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] |
05-10-2005, 19:45
The purifiner on a 83 Pt is mounted on the right side ( looking from the back
) and sets at the end of the valve cover. Really makes it hard to add oil. Paul in Ky 83PT35 [Non-text portions of this message have been removed] |
05-10-2005, 23:20
thats what i ment,where is there room on a pt 40 for anything in the engine
compartment? its kinda busy in there!!VBG! randydupree93wb ----- Original Message ----- From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, May 10, 2005 11:23 PM Subject: [WanderlodgeForum] Re: Refineco Oil Purifiner Randy: They could mount it virtually anywhere there was room as long as the filter was above the oil level in the pan. One to two feet would be good, because it would drain well. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > i have never seen one on a bird.i wonder just where they would put it!!randydupree93wb > ----- Original Message ----- > From: ronmarabito2002 > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, May 10, 2005 9:35 PM > Subject: [WanderlodgeForum] Re: Refineco Oil Purifiner > > > The chances are, you don't have one. I believe they were an option > back then, or the original owner took it off. That filter was a > bypass filter and is not necessary for operating your engine. It > could however be a benefit if you had it. It would be in the engine > compartment and probably attached to the frame. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > Moderator > > > > > --- In WanderlodgeForum@yahoogroups.com, "jdlashua" > wrote: > > I'm a newby wanderlodge owner and need a little help. We have a 1984 > > PT40 and I'm slowly but surely learning it, however in reading the > > manual it says to change the Purifiner filter every 12 months, but > for > > the life of me I can't find it. Can anyone give me a clue, I thought > > I'd looked everywhere, but to no avail. > > > > James & Mercy Lashua > > Fernley, NV > > 1984 PT40 > > > > > ------------------------------------------------------------------- ----------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-10-2005, 23:50
so they did put one on a bird! i've never seen one on a bird.it must be a pita
to change the filter too! randydupree93wb ----- Original Message ----- From: antique405@... To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, May 11, 2005 7:45 AM Subject: Re: [WanderlodgeForum] Re: Refineco Oil Purifiner The purifiner on a 83 Pt is mounted on the right side ( looking from the back ) and sets at the end of the valve cover. Really makes it hard to add oil. Paul in Ky 83PT35 [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-11-2005, 05:26
I found room to install one in Ernies 83 PT40 and it was twice as
tall as a Purefiner. It went in on the passenger side and adjacent to the muffler, which was vertical by the firewall. By the way, I haven't found anywhere to install on my 92. R.E. (Ron) Marabito, 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > thats what i ment,where is there room on a pt 40 for anything in the engine compartment? its kinda busy in there!!VBG! randydupree93wb > ----- Original Message ----- > From: ronmarabito2002 > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, May 10, 2005 11:23 PM > Subject: [WanderlodgeForum] Re: Refineco Oil Purifiner > > > Randy: They could mount it virtually anywhere there was room as > long as the filter was above the oil level in the pan. One to two > feet would be good, because it would drain well. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > Moderator > > > --- In WanderlodgeForum@yahoogroups.com, randydupree > wrote: > > i have never seen one on a bird.i wonder just where they would put > it!!randydupree93wb > > ----- Original Message ----- > > From: ronmarabito2002 > > To: WanderlodgeForum@yahoogroups.com > > Sent: Tuesday, May 10, 2005 9:35 PM > > Subject: [WanderlodgeForum] Re: Refineco Oil Purifiner > > > > > > The chances are, you don't have one. I believe they were an > option > > back then, or the original owner took it off. That filter was a > > bypass filter and is not necessary for operating your engine. > It > > could however be a benefit if you had it. It would be in the > engine > > compartment and probably attached to the frame. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > Moderator > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "jdlashua" > > > wrote: > > > I'm a newby wanderlodge owner and need a little help. We have > a 1984 > > > PT40 and I'm slowly but surely learning it, however in reading > the > > > manual it says to change the Purifiner filter every 12 months, > but > > for > > > the life of me I can't find it. Can anyone give me a clue, I > thought > > > I'd looked everywhere, but to no avail. > > > > > > James & Mercy Lashua > > > Fernley, NV > > > 1984 PT40 > > > > > > > > > > --------------------------------------------------------------- ---- > ----------- > > Yahoo! Groups Links > > > > a.. To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > > > [Non-text portions of this message have been removed] > > > > > ------------------------------------------------------------------- ----------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] |
05-11-2005, 11:23
got kind of cramped in there i bet! no space on my 93 either! randydupree93wb
----- Original Message ----- From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, May 11, 2005 1:26 PM Subject: [WanderlodgeForum] Re: Refineco Oil Purifiner I found room to install one in Ernies 83 PT40 and it was twice as tall as a Purefiner. It went in on the passenger side and adjacent to the muffler, which was vertical by the firewall. By the way, I haven't found anywhere to install on my 92. R.E. (Ron) Marabito, 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, randydupree wrote: > thats what i ment,where is there room on a pt 40 for anything in the engine compartment? its kinda busy in there!!VBG! randydupree93wb > ----- Original Message ----- > From: ronmarabito2002 > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, May 10, 2005 11:23 PM > Subject: [WanderlodgeForum] Re: Refineco Oil Purifiner > > > Randy: They could mount it virtually anywhere there was room as > long as the filter was above the oil level in the pan. One to two > feet would be good, because it would drain well. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > Moderator > > > --- In WanderlodgeForum@yahoogroups.com, randydupree > wrote: > > i have never seen one on a bird.i wonder just where they would put > it!!randydupree93wb > > ----- Original Message ----- > > From: ronmarabito2002 > > To: WanderlodgeForum@yahoogroups.com > > Sent: Tuesday, May 10, 2005 9:35 PM > > Subject: [WanderlodgeForum] Re: Refineco Oil Purifiner > > > > > > The chances are, you don't have one. I believe they were an > option > > back then, or the original owner took it off. That filter was a > > bypass filter and is not necessary for operating your engine. > It > > could however be a benefit if you had it. It would be in the > engine > > compartment and probably attached to the frame. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > Moderator > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "jdlashua" > > > wrote: > > > I'm a newby wanderlodge owner and need a little help. We have > a 1984 > > > PT40 and I'm slowly but surely learning it, however in reading > the > > > manual it says to change the Purifiner filter every 12 months, > but > > for > > > the life of me I can't find it. Can anyone give me a clue, I > thought > > > I'd looked everywhere, but to no avail. > > > > > > James & Mercy Lashua > > > Fernley, NV > > > 1984 PT40 > > > > > > > > > > --------------------------------------------------------------- ---- > ----------- > > Yahoo! Groups Links > > > > a.. To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > > > [Non-text portions of this message have been removed] > > > > > ------------------------------------------------------------------- ----------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
