foot to leveler
12-13-2007, 13:54
foot to leveler
My M380 loss a foot to the leveler. I have ordered some replacement
foots. Does anyone have suggestions or caveats about replacing the foot??? |
12-13-2007, 15:23
foot to leveler
On the 94pt the foot is held on by two springs. I installed one spring
then used bailing wire to hold the other side up because it was too hard to extend the spring and rehook it. I then set the jack down on a block of wood situated in a way that it would stretch the installed spring and relax the bailing wire.(block was under only one side of the foot) I was sure the block would not kick out because I jammed it up against the tire tread. You can then remove the bailing wire and hook the spring. If you lost a foot maybe the spring is defective or lost its pull. look at the length of the loop /hook on the spring. A blowntire kicked off my foot. I hiked back to find it GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Hubert" wrote: > > My M380 loss a foot to the leveler. I have ordered some replacement > foots. Does anyone have suggestions or caveats about replacing the > foot??? > |
12-13-2007, 22:59
foot to leveler
> > My M380 loss a foot to the leveler. I have ordered some replacement > foots. Does anyone have suggestions or caveats about replacing the > foot??? Find a pit if you can. Otherwise, use symetrical jacking, then block it for safty. Check your owner's manual for jack points. There is a sevice item regarding the top of the jack--I forget what it is but it is nothing major. Might as well do that while you are under there. Your life will be much easier if you find a pit! Regards, Jim Scoggins formerly 04 M380 > |
