Dually Valve Stems
12-19-2007, 22:48
Dually Valve Stems
In a couple of hours I am having new custom dually valve stems with
stabilizers installed on the coach. These should allow for quality
application of the pressure pro senders on my coach. I purchased part
number kit DL4AAOS. It includes, 2#VH51010, 2#TV513 and 2#H2225 for
old style Alcoa wheels. I will let you know how it goes.
http://www.borgtiresupply.com 1-800-300-2674 Tujunga, CA
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
12-20-2007, 03:26
Dually Valve Stems
Leroy,
Keep us posted.
I tried valve extentions and extention supports,
for Accuride rims.
I was not satisfied. The rubber supports were loose
and smaller than the rim holes.
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "Leroy A. Eckert"
part
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
12-20-2007, 04:37
Dually Valve Stems
Bill, got them installed in about an hour. They fit as advertised. I think I
will order two more rubber grommets. I installed the rubber grommets on the
inside dual but think I want to double up just because. It's probably overkill
and not needed because everything is tight.
No more leaky extensions and busted knuckles, I hope.
Leroy Eckert
Dahlonega, GA
Royale Conversion
pattypape wrote:
Leroy,
Keep us posted.
for Accuride rims.
Bill 88 FC Michigan
part
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
Never miss a thing. Make Yahoo your homepage.
12-20-2007, 06:12
Dually Valve Stems
Leroy,
I put the same ones on my tires and so for have worked great.
Howard T., Camilla, Ga. 86 PT40
Sent: Thursday, December 20, 2007 5:48 AM
Subject: [WanderlodgeForum] Dually Valve Stems
Leroy Eckert
Dahlonega, GA
Royale Conversion
Checked by AVG Free Edition.
Version: 7.5.486 / Virus Database: 269.17.4/1188 - Release Date: 12/17/2007
2:13 PM
12-20-2007, 07:42
Dually Valve Stems
Howard,
Did you install the grommet on the inside or outside dual wheel?
It's good to know yours are working fine.
Leroy Eckert
Dahlonega, GA
Royale Conversion
Bone chilling rain and cold for a FL boy
"Howard O. Truitt" wrote:
Leroy,
Leroy Eckert
Dahlonega, GA
Royale Conversion
2:13 PM
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
12-20-2007, 09:31
Dually Valve Stems
Leroy
On the outside
Howard
Sent: Thursday, December 20, 2007 2:42 PM
Subject: Re: [WanderlodgeForum] Dually Valve Stems
Howard,
Leroy Eckert
Dahlonega, GA
Royale Conversion
"Howard O. Truitt" wrote: Leroy,
Leroy Eckert
Dahlonega, GA
Royale Conversion
2:13 PM
2:13 PM
