GROAN-N-N
12-26-2007, 07:07
GROAN-N-N
Howdy, Wanderlodge family.
I turned on the hot water tap in our 1993 Wanderlodge's shower earlierthis AM. Zilch, nada, no hot water, just lukewarm water. No hot waterat any of the other sinks, either. Jack is going to check out theelectrical connections. If you have replaced your electric waterheater in your coach, we sure would like to hear about yourexperiences. TIA, Jack and Liz Pearce 1993 Wanderlodge Wintering in Hondo, TX [Non-text portions of this message have been removed] |
12-26-2007, 07:54
GROAN-N-N
Several of us have replaced our Sealand originals with Force Ten. Force Ten
are Sealand copies but with better materials and engineering. Make sure you get the one that is the exact replacement for your existing water heater. If your 93 is like my 94 it will have two nipples at the back end for motor aid heat IN/OUT. Here's a link for the Force Ten http://www.force10.com/index.html On 26/12/2007, Jack and Liz Pearce > > Howdy, Wanderlodge family. > > I turned on the hot water tap in our 1993 Wanderlodge's shower > earlierthis AM. Zilch, nada, no hot water, just lukewarm water. No hot > waterat any of the other sinks, either. Jack is going to check out > theelectrical connections. If you have replaced your electric > waterheater in your coach, we sure would like to hear about > yourexperiences. > > TIA, > Jack and Liz Pearce > 1993 Wanderlodge > Wintering in Hondo, TX > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
12-26-2007, 07:59
GROAN-N-N
I should have sent you this url for Force Ten suppliers
http://www.force10.com/distributors.html On 26/12/2007, Jack and Liz Pearce > > Howdy, Wanderlodge family. > > I turned on the hot water tap in our 1993 Wanderlodge's shower > earlierthis AM. Zilch, nada, no hot water, just lukewarm water. No hot > waterat any of the other sinks, either. Jack is going to check out > theelectrical connections. If you have replaced your electric > waterheater in your coach, we sure would like to hear about > yourexperiences. > > TIA, > Jack and Liz Pearce > 1993 Wanderlodge > Wintering in Hondo, TX > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
12-26-2007, 08:02
GROAN-N-N
And I misspoke. They are Seaward copies.
12-26-2007, 08:42
GROAN-N-N
--- In WanderlodgeForum@yahoogroups.com, "Rob Robinson"
wrote: > > Several of us have replaced our Sealand originals with Force Ten. Force Ten > are Sealand copies but with better materials and engineering. Make sure you > get the one that is the exact replacement for your existing water heater. If > your 93 is like my 94 it will have two nipples at the back end for motor aid > heat IN/OUT. Here's a link for the Force Ten > > http://www.force10.com/index.html > Howdy, Rob. We have an Atwood heater. Thanks for the informative reply, though. Jack feels that he might just have to replace the heating element. I'll check out the Force Ten, too. Thanks again, Liz 1993 WLWb Hondo, TX |
12-26-2007, 08:58
GROAN-N-N
We have Force ten water heaters in stock
Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > > --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > wrote: > > > > Several of us have replaced our Sealand originals with Force Ten. > Force Ten > > are Sealand copies but with better materials and engineering. Make > sure you > > get the one that is the exact replacement for your existing water > heater. If > > your 93 is like my 94 it will have two nipples at the back end for > motor aid > > heat IN/OUT. Here's a link for the Force Ten > > > > http://www.force10.com/index.html > > > Howdy, Rob. > > We have an Atwood heater. Thanks for the informative reply, though. > Jack feels that he might just have to replace the heating element. I'll > check out the Force Ten, too. > > Thanks again, > Liz > 1993 WLWb > Hondo, TX > |
12-26-2007, 09:31
GROAN-N-N
The Force Ten link you provided works just fine, except for the fact
that they don't show any hot water heaters under products. Would appreciate more information. R.E. (Ron) Marabito, Dallas, tX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Several of us have replaced our Sealand originals with Force Ten. Force Ten > are Sealand copies but with better materials and engineering. Make sure you > get the one that is the exact replacement for your existing water heater. If > your 93 is like my 94 it will have two nipples at the back end for motor aid > heat IN/OUT. Here's a link for the Force Ten > > http://www.force10.com/index.html > > > On 26/12/2007, Jack and Liz Pearce > > > > Howdy, Wanderlodge family. > > > > I turned on the hot water tap in our 1993 Wanderlodge's shower > > earlierthis AM. Zilch, nada, no hot water, just lukewarm water. No hot > > waterat any of the other sinks, either. Jack is going to check out > > theelectrical connections. If you have replaced your electric > > waterheater in your coach, we sure would like to hear about > > yourexperiences. > > > > TIA, > > Jack and Liz Pearce > > 1993 Wanderlodge > > Wintering in Hondo, TX > > > > [Non-text portions of this message have been removed] > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > |
12-26-2007, 09:57
GROAN-N-N
I ran into the same lack of water heater product information
![]() Dorn Hetzel 77FC35 Hogansville, GA On Dec 26, 2007 4:31 PM, ronmarabito2002 > The Force Ten link you provided works just fine, except for the fact > that they don't show any hot water heaters under products. Would > appreciate more information. > > R.E. (Ron) Marabito, Dallas, tX 92WB40 > > > --- In WanderlodgeForum@yahoogroups.com > "Rob Robinson" > > > > > Several of us have replaced our Sealand originals with Force Ten. > Force Ten > > are Sealand copies but with better materials and engineering. Make > sure you > > get the one that is the exact replacement for your existing water > heater. If > > your 93 is like my 94 it will have two nipples at the back end for > motor aid > > heat IN/OUT. Here's a link for the Force Ten > > > > http://www.force10.com/index.html > > > > > > On 26/12/2007, Jack and Liz Pearce > > > > > > Howdy, Wanderlodge family. > > > > > > I turned on the hot water tap in our 1993 Wanderlodge's shower > > > earlierthis AM. Zilch, nada, no hot water, just lukewarm water. No hot > > > waterat any of the other sinks, either. Jack is going to check out > > > theelectrical connections. If you have replaced your electric > > > waterheater in your coach, we sure would like to hear about > > > yourexperiences. > > > > > > TIA, > > > Jack and Liz Pearce > > > 1993 Wanderlodge > > > Wintering in Hondo, TX > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > > > [Non-text portions of this message have been removed] |
12-26-2007, 10:03
GROAN-N-N
Sorry folks I just remembered they sold out and I believe it was to this
company. You might have to call them to get info on the model with rear in/out primus nipples. http://www.kuumaproducts.com/index3.html Steve Birtles can get them for you. I would check out his prices. On 26/12/2007, Dorn Hetzel > > I ran into the same lack of water heater product information ![]() > > Dorn Hetzel > 77FC35 > Hogansville, GA > > On Dec 26, 2007 4:31 PM, ronmarabito2002 > wrote: > > > The Force Ten link you provided works just fine, except for the fact > > that they don't show any hot water heaters under products. Would > > appreciate more information. > > > > R.E. (Ron) Marabito, Dallas, tX 92WB40 > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > "Rob Robinson" > > > > > > > > Several of us have replaced our Sealand originals with Force Ten. > > Force Ten > > > are Sealand copies but with better materials and engineering. Make > > sure you > > > get the one that is the exact replacement for your existing water > > heater. If > > > your 93 is like my 94 it will have two nipples at the back end for > > motor aid > > > heat IN/OUT. Here's a link for the Force Ten > > > > > > http://www.force10.com/index.html > > > > > > > > > On 26/12/2007, Jack and Liz Pearce > > > > > > > > Howdy, Wanderlodge family. > > > > > > > > I turned on the hot water tap in our 1993 Wanderlodge's shower > > > > earlierthis AM. Zilch, nada, no hot water, just lukewarm water. No > hot > > > > waterat any of the other sinks, either. Jack is going to check out > > > > theelectrical connections. If you have replaced your electric > > > > waterheater in your coach, we sure would like to hear about > > > > yourexperiences. > > > > > > > > TIA, > > > > Jack and Liz Pearce > > > > 1993 Wanderlodge > > > > Wintering in Hondo, TX > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > -- > > > Rob, Sue & Merlin Robinson > > > 94 WLWB > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
12-26-2007, 14:03
GROAN-N-N
Jack and Liz, turn off the 110 vac at the breaker box, going to the water
heater. Remove the cap that covers the electrical connections and between the two spade type connectors there will be a re-setable circuit breaker ECO, push it to reset the breaker. Bring power back up and check for 110 vac with your meter on those spade connectors. That should get you hot water. If it trips again then we need to do an ohms check on the heating element. Lets not jump off the deep end planning a replacement until you know it needs replacing? Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 08:42 PM 12/26/2007 +0000, you wrote: >--- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" >wrote: > > > > Several of us have replaced our Sealand originals with Force Ten. >Force Ten > > are Sealand copies but with better materials and engineering. Make >sure you > > get the one that is the exact replacement for your existing water >heater. If > > your 93 is like my 94 it will have two nipples at the back end for >motor aid > > heat IN/OUT. Here's a link for the Force Ten > > > > http://www.force10.com/index.html > > >Howdy, Rob. > >We have an Atwood heater. Thanks for the informative reply, though. >Jack feels that he might just have to replace the heating element. I'll >check out the Force Ten, too. > >Thanks again, >Liz >1993 WLWb >Hondo, TX > > > |
