Fresh Polished Corian
12-28-2007, 10:32
I spent 8 hours resurfacing my white Corian counter tops yesterday. It
was quite a messy job. The results are beautiful. Shiny, no scratches and clean. I imagine the tops have never been touched since new. I don't want to use them now. I detailed the inside today. I'm going to inspect those air compressor hoses tomorrow. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion |
12-28-2007, 10:54
What did you do to them? Mine are pretty dull
Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "Leroy A. Eckert" > > I spent 8 hours resurfacing my white Corian counter tops yesterday. It > was quite a messy job. The results are beautiful. Shiny, no scratches > and clean. I imagine the tops have never been touched since new. > I don't want to use them now. I detailed the inside today. I'm going > to inspect those air compressor hoses tomorrow. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > |
12-28-2007, 12:01
Scott,
I first read the BB manual and used sandpaper, steel wool, Scotch Brite and Comet with some limited success. The BB book makes it sound as though this project can be done without power tools. That is not the case, that is if you want it done right. I decided to go for it, (if I screw up it's my bus) and used the same procedure I use to polish granite and marble. I have the tooling and pads which is quite expensive and consists of a 90 degree variable speed water capable angle grinder with a 3" hard pad. A 4" pad would be better. I did the project wet beginning with a 200 grit diamond pad progressing to 400 grit then 800 grit. Removing all the scratches in a uniform manner is the key so light refraction can do its thing. In the process, any stains and accumulated crud are removed. Of course, I taped and masked everything off because water slings everywhere including on my fat belly. A wet vac is essential. I used 1200 rpm and ground away. I had never attempted resurfacing Corian but have resurfaced many Granite and Marble tops and floors. The product works very similar to Marble. It's hardness characteristic is very similar. Possibly a bit softer because it tends to clog the pad. I had to clean them several times. Final polishing was accomplished with a hogs hair pad using a special granite polishing powder consisting in part of Aluminum Oxide, citric acid (which can damage the Corian) and other compounds unknown to me because they are proprietary. I polished wet to dry on the pad. Although it was not necessary, I finished the project with Turtle Wax F-21 nano tech polymer car polish the same that I use on the paint, just because I tend to overkill bus projects. If you can find someone in your area that really knows what they are doing it should cost about $500 to get them looking brand new. If they don't know what they are doing you got a big problem. Thereafter, some reasonable care and spot polishing and you should be good to go for awhile. As a comparison, my hourly rate is $75 per hour on such projects. The proper tooling, water capable angle grinder, quality diamond pads, polishing powder etc. can run in the neighborhood of $1500. Hope this helps. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion Scott Forman <sforman@...> wrote: What did you do to them? Mine are pretty dull Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "Leroy A. Eckert" > > I spent 8 hours resurfacing my white Corian counter tops yesterday. It > was quite a messy job. The results are beautiful. Shiny, no scratches > and clean. I imagine the tops have never been touched since new. > I don't want to use them now. I detailed the inside today. I'm going > to inspect those air compressor hoses tomorrow. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > --------------------------------- Looking for last minute shopping deals? Find them fast with Yahoo! Search. [Non-text portions of this message have been removed] |
12-28-2007, 12:34
OK...that's all waaaaaay over my head, and I am not likely to spend
$500 having it done, either. The counters aren't in bad shape with scratches and what-not, they are just not shiny. Hate to have such a simple mind, but isn't there a simple wax or polish or something I can apply to revitalize them a bit? Scott --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > Scott, > I first read the BB manual and used sandpaper, steel wool, Scotch Brite and Comet with some limited success. The BB book makes it sound as though this project can be done without power tools. That is not the case, that is if you want it done right. > I decided to go for it, (if I screw up it's my bus) and used the same procedure I use to polish granite and marble. > I have the tooling and pads which is quite expensive and consists of a 90 degree variable speed water capable angle grinder with a 3" hard pad. A 4" pad would be better. I did the project wet beginning with a 200 grit diamond pad progressing to 400 grit then 800 grit. Removing all the scratches in a uniform manner is the key so light refraction can do its thing. In the process, any stains and accumulated crud are removed. Of course, I taped and masked everything off because water slings everywhere including on my fat belly. A wet vac is essential. I used 1200 rpm and ground away. I had never attempted resurfacing Corian but have resurfaced many Granite and Marble tops and floors. > The product works very similar to Marble. It's hardness characteristic is very similar. Possibly a bit softer because it tends to clog the pad. I had to clean them several times. > Final polishing was accomplished with a hogs hair pad using a special granite polishing powder consisting in part of Aluminum Oxide, citric acid (which can damage the Corian) and other compounds unknown to me because they are proprietary. I polished wet to dry on the pad. Although it was not necessary, I finished the project with Turtle Wax F-21 nano tech polymer car polish the same that I use on the paint, just because I tend to overkill bus projects. > If you can find someone in your area that really knows what they are doing it should cost about $500 to get them looking brand new. If they don't know what they are doing you got a big problem. Thereafter, some reasonable care and spot polishing and you should be good to go for awhile. As a comparison, my hourly rate is $75 per hour on such projects. > The proper tooling, water capable angle grinder, quality diamond pads, polishing powder etc. can run in the neighborhood of $1500. > Hope this helps. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > Scott Forman <sforman@...> wrote: What did you do to them? Mine are pretty dull > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "Leroy A. Eckert" > > > > > I spent 8 hours resurfacing my white Corian counter tops yesterday. It > > was quite a messy job. The results are beautiful. Shiny, no scratches > > and clean. I imagine the tops have never been touched since new. > > I don't want to use them now. I detailed the inside today. I'm going > > to inspect those air compressor hoses tomorrow. > > Leroy Eckert > > 1990 WB-40 Smoke N Mirrors > > Dahlonega, GA > > Royale Conversion > > > > > > > > > --------------------------------- > Looking for last minute shopping deals? Find them fast with Yahoo! Search. > > [Non-text portions of this message have been removed] > |
12-28-2007, 13:40
The surface is not shiny because it is irregular, ie. it has minute or greater
scratches many which are not visible to the naked eye. In short, other than resurfacing, there is no magic formula in a bottle. Check this site for a relatively simple explanation. I'm no light freak but it all makes sense. http://library.thinkquest.org/27356/p_reflection.htm The same goes for paint or other objects. Sand your paint and see what happens. Polish the sanded paint with polishing compound and see the shine return. It's magic to the eye. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion Scott Forman <sforman@...> wrote: OK...that's all waaaaaay over my head, and I am not likely to spend $500 having it done, either. The counters aren't in bad shape with scratches and what-not, they are just not shiny. Hate to have such a simple mind, but isn't there a simple wax or polish or something I can apply to revitalize them a bit? Scott --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > Scott, > I first read the BB manual and used sandpaper, steel wool, Scotch Brite and Comet with some limited success. The BB book makes it sound as though this project can be done without power tools. That is not the case, that is if you want it done right. > I decided to go for it, (if I screw up it's my bus) and used the same procedure I use to polish granite and marble. > I have the tooling and pads which is quite expensive and consists of a 90 degree variable speed water capable angle grinder with a 3" hard pad. A 4" pad would be better. I did the project wet beginning with a 200 grit diamond pad progressing to 400 grit then 800 grit. Removing all the scratches in a uniform manner is the key so light refraction can do its thing. In the process, any stains and accumulated crud are removed. Of course, I taped and masked everything off because water slings everywhere including on my fat belly. A wet vac is essential. I used 1200 rpm and ground away. I had never attempted resurfacing Corian but have resurfaced many Granite and Marble tops and floors. > The product works very similar to Marble. It's hardness characteristic is very similar. Possibly a bit softer because it tends to clog the pad. I had to clean them several times. > Final polishing was accomplished with a hogs hair pad using a special granite polishing powder consisting in part of Aluminum Oxide, citric acid (which can damage the Corian) and other compounds unknown to me because they are proprietary. I polished wet to dry on the pad. Although it was not necessary, I finished the project with Turtle Wax F-21 nano tech polymer car polish the same that I use on the paint, just because I tend to overkill bus projects. > If you can find someone in your area that really knows what they are doing it should cost about $500 to get them looking brand new. If they don't know what they are doing you got a big problem. Thereafter, some reasonable care and spot polishing and you should be good to go for awhile. As a comparison, my hourly rate is $75 per hour on such projects. > The proper tooling, water capable angle grinder, quality diamond pads, polishing powder etc. can run in the neighborhood of $1500. > Hope this helps. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > Scott Forman <sforman@...> wrote: What did you do to them? Mine are pretty dull > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "Leroy A. Eckert" > > > > > I spent 8 hours resurfacing my white Corian counter tops yesterday. It > > was quite a messy job. The results are beautiful. Shiny, no scratches > > and clean. I imagine the tops have never been touched since new. > > I don't want to use them now. I detailed the inside today. I'm going > > to inspect those air compressor hoses tomorrow. > > Leroy Eckert > > 1990 WB-40 Smoke N Mirrors > > Dahlonega, GA > > Royale Conversion > > > > > > > > > --------------------------------- > Looking for last minute shopping deals? Find them fast with Yahoo! Search. > > [Non-text portions of this message have been removed] > --------------------------------- Never miss a thing. Make Yahoo your homepage. [Non-text portions of this message have been removed] |
12-28-2007, 14:32
It helped me, the scratches no longer look bad.
GregoryO'Connor 94pt with scratched corian --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > Scott, > I first read the BB manual and used sandpaper, steel wool, Scotch Brite and Comet with some limited success. The BB book makes it sound as though this project can be done without power tools. That is not the case, that is if you want it done right. > I decided to go for it, (if I screw up it's my bus) and used the same procedure I use to polish granite and marble. > I have the tooling and pads which is quite expensive and consists of a 90 degree variable speed water capable angle grinder with a 3" hard pad. A 4" pad would be better. I did the project wet beginning with a 200 grit diamond pad progressing to 400 grit then 800 grit. Removing all the scratches in a uniform manner is the key so light refraction can do its thing. In the process, any stains and accumulated crud are removed. Of course, I taped and masked everything off because water slings everywhere including on my fat belly. A wet vac is essential. I used 1200 rpm and ground away. I had never attempted resurfacing Corian but have resurfaced many Granite and Marble tops and floors. > The product works very similar to Marble. It's hardness characteristic is very similar. Possibly a bit softer because it tends to clog the pad. I had to clean them several times. > Final polishing was accomplished with a hogs hair pad using a special granite polishing powder consisting in part of Aluminum Oxide, citric acid (which can damage the Corian) and other compounds unknown to me because they are proprietary. I polished wet to dry on the pad. Although it was not necessary, I finished the project with Turtle Wax F-21 nano tech polymer car polish the same that I use on the paint, just because I tend to overkill bus projects. > If you can find someone in your area that really knows what they are doing it should cost about $500 to get them looking brand new. If they don't know what they are doing you got a big problem. Thereafter, some reasonable care and spot polishing and you should be good to go for awhile. As a comparison, my hourly rate is $75 per hour on such projects. > The proper tooling, water capable angle grinder, quality diamond pads, polishing powder etc. can run in the neighborhood of $1500. > Hope this helps. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > Scott Forman <sforman@...> wrote: What did you do to them? Mine are pretty dull > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "Leroy A. Eckert" > > > > > I spent 8 hours resurfacing my white Corian counter tops yesterday. It > > was quite a messy job. The results are beautiful. Shiny, no scratches > > and clean. I imagine the tops have never been touched since new. > > I don't want to use them now. I detailed the inside today. I'm going > > to inspect those air compressor hoses tomorrow. > > Leroy Eckert > > 1990 WB-40 Smoke N Mirrors > > Dahlonega, GA > > Royale Conversion > > > > > > > > > --------------------------------- > Looking for last minute shopping deals? Find them fast with Yahoo! Search. > > [Non-text portions of this message have been removed] > |
12-28-2007, 17:26
Leroy does it according to Hoyle, no doubt.
My countertops were also badly scratched, but the unscratched parts were nearly mirror-finished. I plunged in with little more than general internet instructions. I used more pedestrian equipment and methods. I used dry fine sanding paper and scotchbrite to rub out the deepest scratches. I then used a light application of scotchbrite and dry sanding with an orbital sander to dull the entire surface evenly. I then used three successively finer wet sanding sheets by hand. I used coarse, then finer polishing compound and a wool buffing pad on a light-duty electric drill. I should have borrowed or rented a commercial buffer to get more consistent results faster. My end result was more of a satin finish with only minor scratches where deep ones had been before, but for less than $100 and an afternoon's work, not a bad return. If you're ever in North Texas, Leroy, I'd be glad to have you do my countertops the right way. Brad Barton 00LXiDFWbbartonwx@... To: WanderlodgeForum@...: Gregoryoc@...: Sat, 29 Dec 2007 02:32:22 +0000Subject: [WanderlodgeForum] Re: Fresh Polished Corian It helped me, the scratches no longer look bad.GregoryO'Connor94pt with scratched corian--- In WanderlodgeForum@yahoogroups.com, Leroy Eckert steel wool, Scotch Brite and Comet with some limited success. The BB book makes it sound as though this project can be done without power tools. That is not the case, that is if you want it done right.> I decided to go for it, (if I screw up it's my bus) and used the same procedure I use to polish granite and marble.> I have the tooling and pads which is quite expensive and consists of a 90 degree variable speed water capable angle grinder with a 3" hard pad. A 4" pad would be better. I did the project wet beginning with a 200 grit diamond pad progressing to 400 grit then 800 grit. Removing all the scratches in a uniform manner is the key so light refraction can do its thing. In the process, any stains and accumulated crud are removed. Of course, I taped and masked everything off because water slings everywhere including on my fat belly. A wet vac is essential. I used 1200 rpm and ground away. I had never attempted resurfacing Corian but have resurfaced many Granite and Marble tops and floors.> The product works very similar to Marble. It's hardness characteristic is very similar. Possibly a bit softer because it tends to clog the pad. I had to clean them several times.> Final polishing was accomplished with a hogs hair pad using a special granite polishing powder consisting in part of Aluminum Oxide, citric acid (which can damage the Corian) and other compounds unknown to me because they are proprietary. I polished wet to dry on the pad. Although it was not necessary, I finished the project with Turtle Wax F-21 nano tech polymer car polish the same that I use on the paint, just because I tend to overkill bus projects.> If you can find someone in your area that really knows what they are doing it should cost about $500 to get them looking brand new. If they don't know what they are doing you got a big problem. Thereafter, some reasonable care and spot polishing and you should be good to go for awhile. As a comparison, my hourly rate is $75 per hour on such projects. > The proper tooling, water capable angle grinder, quality diamond pads, polishing powder etc. can run in the neighborhood of $1500.> Hope this helps.> Leroy Eckert> 1990 WB-40 Smoke N Mirrors> Dahlonega, GA> Royale Conversion> > Scott Forman <sforman@...> wrote: What did you do to them? Mine are pretty dull> > Scott Forman> 86 PT38> Memphis> > --- In WanderlodgeForum@yahoogroups.com, "Leroy A. Eckert" > wrote:> >> > I spent 8 hours resurfacing my white Corian counter tops yesterday. It> > was quite a messy job. The results are beautiful. Shiny, no scratches> > and clean. I imagine the tops have never been touched since new.> > I don't want to use them now. I detailed the inside today. I'm going> > to inspect those air compressor hoses tomorrow.> > Leroy Eckert> > 1990 WB-40 Smoke N Mirrors> > Dahlonega, GA> > Royale Conversion> >> > > > > > > ---------------------------------> Looking for last minute shopping deals? Find them fast with Yahoo! Search.> > [Non-text portions of this message have been removed]> _________________________________________________________________ Get the power of Windows + Web with the new Windows Live. http://www.windowslive.com?ocid=TXT_TAGH...ows_122007 [Non-text portions of this message have been removed] |
12-28-2007, 23:16
I don't have anything to do at 5am so I searched for another cheap way to get it
done. I have never used this process but it sounds like it will yield professional results for under $200. It is similar to the process I used. I used diamond pads, this uses AO sandpaper. http://www.bgartforms.com/Corian_Sanding_Supplies.htm Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion brad barton <bbartonwx@...> wrote: Leroy does it according to Hoyle, no doubt. My countertops were also badly scratched, but the unscratched parts were nearly mirror-finished. I plunged in with little more than general internet instructions. I used more pedestrian equipment and methods. I used dry fine sanding paper and scotchbrite to rub out the deepest scratches. I then used a light application of scotchbrite and dry sanding with an orbital sander to dull the entire surface evenly. I then used three successively finer wet sanding sheets by hand. I used coarse, then finer polishing compound and a wool buffing pad on a light-duty electric drill. I should have borrowed or rented a commercial buffer to get more consistent results faster. My end result was more of a satin finish with only minor scratches where deep ones had been before, but for less than $100 and an afternoon's work, not a bad return. If you're ever in North Texas, Leroy, I'd be glad to have you do my countertops the right way. Brad Barton 00LXiDFWbbartonwx@... To: WanderlodgeForum@...: Gregoryoc@...: Sat, 29 Dec 2007 02:32:22 +0000Subject: [WanderlodgeForum] Re: Fresh Polished Corian It helped me, the scratches no longer look bad.GregoryO'Connor94pt with scratched corian--- In WanderlodgeForum@yahoogroups.com, Leroy Eckert steel wool, Scotch Brite and Comet with some limited success. The BB book makes it sound as though this project can be done without power tools. That is not the case, that is if you want it done right.> I decided to go for it, (if I screw up it's my bus) and used the same procedure I use to polish granite and marble.> I have the tooling and pads which is quite expensive and consists of a 90 degree variable speed water capable angle grinder with a 3" hard pad. A 4" pad would be better. I did the project wet beginning with a 200 grit diamond pad progressing to 400 grit then 800 grit. Removing all the scratches in a uniform manner is the key so light refraction can do its thing. In the process, any stains and accumulated crud are removed. Of course, I taped and masked everything off because water slings everywhere including on my fat belly. A wet vac is essential. I used 1200 rpm and ground away. I had never attempted resurfacing Corian but have resurfaced many Granite and Marble tops and floors.> The product works very similar to Marble. It's hardness characteristic is very similar. Possibly a bit softer because it tends to clog the pad. I had to clean them several times.> Final polishing was accomplished with a hogs hair pad using a special granite polishing powder consisting in part of Aluminum Oxide, citric acid (which can damage the Corian) and other compounds unknown to me because they are proprietary. I polished wet to dry on the pad. Although it was not necessary, I finished the project with Turtle Wax F-21 nano tech polymer car polish the same that I use on the paint, just because I tend to overkill bus projects.> If you can find someone in your area that really knows what they are doing it should cost about $500 to get them looking brand new. If they don't know what they are doing you got a big problem. Thereafter, some reasonable care and spot polishing and you should be good to go for awhile. As a comparison, my hourly rate is $75 per hour on such projects. > The proper tooling, water capable angle grinder, quality diamond pads, polishing powder etc. can run in the neighborhood of $1500.> Hope this helps.> Leroy Eckert> 1990 WB-40 Smoke N Mirrors> Dahlonega, GA> Royale Conversion> > Scott Forman <sforman@...> wrote: What did you do to them? Mine are pretty dull> > Scott Forman> 86 PT38> Memphis> > --- In WanderlodgeForum@yahoogroups.com, "Leroy A. Eckert" > I spent 8 hours resurfacing my white Corian counter tops yesterday. It> > was quite a messy job. The results are beautiful. Shiny, no scratches> > and clean. I imagine the tops have never been touched since new.> > I don't want to use them now. I detailed the inside today. I'm going> > to inspect those air compressor hoses tomorrow.> > Leroy Eckert> > 1990 WB-40 Smoke N Mirrors> > Dahlonega, GA> > Royale Conversion> >> > > > > > > ---------------------------------> Looking for last minute shopping deals? Find them fast with Yahoo! Search.> > [Non-text portions of this message have been removed]> __________________________________________________________ Get the power of Windows + Web with the new Windows Live. http://www.windowslive.com?ocid=TXT_TAGH...ows_122007 [Non-text portions of this message have been removed] --------------------------------- Looking for last minute shopping deals? Find them fast with Yahoo! Search. [Non-text portions of this message have been removed] |
