Screen Door Closer Pulleys Needed
01-10-2008, 15:35
The screen door in my 84FC is closed with a spring loaded cable that
runs through 2 small pulleys. The pulleys are small...about 3/4" or maybe 1/2" diameter. One pulley is worn through, so I need to come up with a replacement. Where would I find one? David Hollis 84FC35 Springfield,IL |
01-10-2008, 16:31
Just a thought, how about http://www.westmarine.com and look at sailboat hardware.
dthollis1961 closed with a spring loaded cable that runs through 2 small pulleys. The pulleys are small...about 3/4" or maybe 1/2" diameter. One pulley is worn through, so I need to come up with a replacement. Where would I find one? David Hollis 84FC35 Springfield,IL Yahoo! Groups Links Wallace Craig 95 WLWB 42 Azle, Texas [Non-text portions of this message have been removed] |
01-12-2008, 11:21
I found wheels that worked at Lowe's or HD. In the sliding screen door area.
('81FC prev.)
01-12-2008, 12:07
IF and when you find the pulley wheels , Try using blind cord,
instead of steel cable, the cable chews up the little wheels. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "dthollis1961" wrote: > > The screen door in my 84FC is closed with a spring loaded cable that > runs through 2 small pulleys. The pulleys are small...about 3/4" or > maybe 1/2" diameter. One pulley is worn through, so I need to come up > with a replacement. Where would I find one? > > David Hollis 84FC35 Springfield,IL > |
01-12-2008, 17:39
When we had the '81FC, I rebuilt the spring thing with bungee cord. Getting the right length was a little tricky but it worked good. Naturally, bigger wheels are needed.
01-13-2008, 09:06
Thanks everyone for ideas. I picked up a door roller the other day
that has a bearing in it, it's larger diameter though. I looked really hard at brass cabinet door knobs...most of them have about the same size pulley built into them. David Hollis 84FC35 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > When we had the '81FC, I rebuilt the spring thing with bungee cord. Getting the right length was a little tricky but it worked good. Naturally, bigger wheels are needed. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > ----- Original Message ----- > From: pattypape > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, January 12, 2008 5:07 PM > Subject: [WanderlodgeForum] Re: Screen Door Closer Pulleys Needed > > > > > IF and when you find the pulley wheels , Try using blind cord, > instead of steel cable, the cable chews up the little wheels. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com > wrote: > > > > The screen door in my 84FC is closed with a spring loaded cable that > > runs through 2 small pulleys. The pulleys are small...about 3/4" or > > maybe 1/2" diameter. One pulley is worn through, so I need to come > up > > with a replacement. Where would I find one? > > > > David Hollis 84FC35 Springfield,IL > > > |
