Advice regarding air leak on my 77FC35
01-13-2008, 01:15
Sounds like the air governor is shot. That's an easy 20 dollar fix. Air governor is on or beside the air compressor. It happened to my on my FC
83PT40
Start the year off right. Easy ways to stay in shape in the new year.
01-13-2008, 05:10
Hello All,
I have an air leak which I think is coming from the water drain valve or similar on my 77FC35.
Please see http://www.hetzel.org/P1010012.JPG for a picture of the problem spot.
Any advice as to the identity of the leaking part and the best way to fix the problem would be greatly appreciated.
The coach has been parked in front of my house since it's last trip from which we returned on 12/24, and was last started and run for an hour about a week ago, at which time this problem was not present. We did have a quite hard freeze since then, down to about 12F.
Best Regards and thanks in advance for any help/advice,
Dorn Hetzel
77FC35
Hogansville, GA
01-13-2008, 05:41
Spitter valve for draining the air tanks???
--- In WanderlodgeForum@yahoogroups.com, "Dorn Hetzel"
> Hello All,
problem
> spot.
to fix
about a
quite
> Dorn Hetzel
> 77FC35
> Hogansville, GA
01-13-2008, 05:45
I think so, but then I don't really know for sure. In any case, it's "spitting" constantly at this point and I can't get air pressure over 30psi or so...
On Jan 13, 2008 12:41 PM, Stephen Birtles <
--- In "WanderlodgeForum%40yahoogroups.com", "Dorn Hetzel"
> Hello All,
problem
> spot.
to fix
about a
quite
> Dorn Hetzel
> 77FC35
> Hogansville, GA
01-13-2008, 05:56
Winterizing blow out valve??? the valve to use Cat compressor to blow
out the pipes for winter storage???
GregoryO'Connor
94ptRomolandCa
> Hello All,
valve or
problem
> spot.
to fix
from
hour about a
a quite
> Dorn Hetzel
> 77FC35
> Hogansville, GA
01-13-2008, 06:34
It could also be a spitter valve if it under the air dryer or the air
tank. If itis real cold you could have moisture in the tank & be
frozen
Don Spithaler
89 SP 36'
Butler, PA Posting from the Birds Nest
> Ernie Ekberg
> 83PT40
> Weatherford, Tx
> Ernie Ekberg
> 83PT40
> Weatherford, Tx
01-13-2008, 07:03
try giving it rap with a hammer on the main body to see if it will
seal then change it out to a manual valve or a new spitter
Stephen 77fc35
over 30psi
> or so...
> > --- In
> > "Dorn Hetzel"
> > wrote:
> > > Hello All,
valve or
> > problem
> > > spot.
> > to fix
trip from
> > about a
> > quite
> > > Dorn Hetzel
> > > 77FC35
> > > Hogansville, GA
01-13-2008, 08:36
It definitely appears to be connected to the bottom of the air tank, not the compressor.
83PT40
in the new year.
01-13-2008, 08:58
Go here to find the valve that is leaking air.
http://www.bendix.com/en-us/Pages/default.aspx
On Jan 13, 2008 12:36 PM, Dorn Hetzel <
erniecarpet@...
83PT40
in the new year.
Curt Sprenger
Anaheim Hills, CA
01-13-2008, 09:11
Mine did the same on my81-not as bad though.
Itook it off took itapart at the bench, cleaned all the old dried oil and goo inside, worked like new.
Stephen H
Former 81 FC-33SB
Plant City, FL
83PT40
Curt Sprenger
Anaheim Hills, CA
