Dinette mod
01-28-2008, 07:02
Dinette mod
Have a 1984 35 ft. FC with side bath, the dinette forward seat is very
narrow between the seat back and table, (not enough belly room) also the
dinette seats protrude into the isle. Considering modifying the table to
create more room from the back of the seat to the table and reducing the
seat width so they do not protrude into the isle. Any suggestions?
Dale Cooper
Painesville, Oh. 44077
84 FC 35SB
01-28-2008, 08:11
Dinette mod
Dale, I had the same complaints about my FC. Just too large a piece
of furniture for my bus. Here is what I did. I took the entire
dinette out of my 1973 FC. I was left with a couple boxes the back
one over the rear wheel arch and the front one over the heater. I
covered those boxes with carpet and made two wide chairs to sit on
top of the boxes. The legs on the chairs are very short (maybe 4
inches). These chairs are not really wide enough to sit two adults
but for my purposes that doesn't matter. You could make or have them
made to what ever dimension you would like and out of whatever
material you prefer. I made angle brackets and fixed the chairs tight
to the boxes. The table was also greatly reduced in size. The only
thing I saved from the original system was the mounting attachment
which connected the table to the wall. There would be a bunch of ways
to do this. If the "belly room" was the only issue maybe all that
would need to be done is to remake the table top. I objected to the
overall size of the dinette and the fact that there was almost no
walk room between the dinette and the kitchen counter. I only need
space for two. The next guy may not like my idea but that's the
beauty of an older coach. Not having to worry about hurting
something. Make it the way you like it. I made the chairs using two
wooden chairs that I all ready had. I took the back and seats off of
them and just replace the sections (seat and back) and other supports
with wider pieces and cut the legs off. I covered the seat and seat
back with upholstery padding and then vinyl. Not especially
difficult.
John Heckman
central Pa
1973 FC
very
also the
table to
reducing the
> Dale Cooper
> 84 FC 35SB
01-28-2008, 08:19
Dinette mod
I forgot to mention that there are pictures of my dinette in the
photo section. John Heckman's Big Napper. I am working on the
kitchen and will post more pictures when that is finished. Hopefully
anytime now.
John Heckman
central Pa
1973 FC
piece
them
tight
only
ways
two
of
supports
seat
> difficult.
> John Heckman
> central Pa
> 1973 FC
> very
> also the
> table to
> reducing the
> > Dale Cooper
> > 84 FC 35SB
01-28-2008, 09:08
Dinette mod
As I see it, you have stumbled onto a little known fact about FC's.
That is, as the years pass, the distance between the edge of the
dinette table and the seat back shrinks and decreases.
(my wife didnt buy it either)
What I did was simply remove the seatbacks, and unstaple the fabric..
Next remove all of the old padding and replace with some 2" thick
foam. Then, replace and restaple the fabric cover.. Job Done...
Jack Smith
1973FC31
SoCal
--- In WanderlodgeForum@yahoogroups.com, "Dale Cooper"
table to
> Dale Cooper
> 84 FC 35SB
01-28-2008, 09:32
Dinette mod
--- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith"
fabric..
> Jack Smith
> 1973FC31
> SoCal
Jack I just lost about 30 lbs and lucky me my wife never gained any
weight in 39 years of marriage still hanging in at around 100 lbs.
But I like your idea and will check to see what that looks like this
afternoon. Jon
Jon
Rebel bird North
very
also
> the
> table to
reducing
> the
> > Dale Cooper
> > 84 FC 35SB
01-28-2008, 10:07
Dinette mod
I saw photos of one 'bird where a previous owner had cut a partial
circular hole in one side of the dining table. I've seen a couple
'birds where the dinette seats and table have been shortened a few
inches.
In my own coach, I have a table anchored to the wall, but
freestanding chairs. When I replaced the floor and remodeled the
forward salon (to be an office), I was able to move the table a few
inches forward (toward the front of the coach) to give more space on
the side of the table that backs up to a bulkhead and the file
cabinets I installed in place of the sofa and a near-useless cabinet
ended up about a foot shorter overall, so there's more room on the
other side as well. Note that moving the table only about 3 or 4
inches is plenty (well, it was plenty for my slender wife, who lifts
weights to keep in shape).
I suppose you can modify the existing table, or replace it with
another one, that's simply 4 or 5 inches less wide. without having to
move the booth -- which might be a problem as in some 'birds the
booth has stuff under them.
Pete Masterson
El Sobrante CA
aeonix1@...
> also the
> table to
> reducing the
01-28-2008, 13:43
Dinette mod
I removed the cushions from the dinette of the prison bus and set my self down. The dinette was suddenly huge. Did up the seat bottom and back with laminate and thin padding on the seat and back. Tons of room and still big table top. Removed the seat back on the 83FC, works good there too. I think I'll leave the seat bottoms and come up with some thin upholstery for the seat backs, makes for tons of room. I don't use the dinette for sleeping of course.
MH
Sent: Monday, January 28, 2008 2:11 PM
Subject: [WanderlodgeForum] Re: Dinette mod
difficult.
John Heckman
central Pa
1973 FC
very
also the
table to
reducing the
> Dale Cooper
> 84 FC 35SB
