					83-84 PT Engine Compartment
					01-31-2008, 09:29
				 Post: #1 | |||
| 83-84 PT Engine Compartment Dennis, since its' dark here in texas,couldn't see my numbers-Go to OrrOrr.com. They have the struts we need. just take a measurement and match them up.
 Ernie Ekberg 83PT40 Weatherford, Tx- Orr and Orr are the best Start the year off right. Easy ways to stay in shape in the new year. | |||
					01-31-2008, 14:24
				 Post: #2 | |||
					Good evening to all. On an '83 and/or '84 PT rear passenger side grill, there are two gas struts. Mine are shot and somewhere along the line someone has painted over them son the numbers are no longer readable. Is anyone still able to see their numbers? If so, could you please post them? TKIA Dennis Davis '83 PT35 "LOONEYBIN" Las Vegas, NV | |||
					01-31-2008, 14:27
				 Post: #3 | |||
| 83-84 PT Engine Compartment I got them at napa take one off and bring it with you jim riordan 88 wbwl stuart fl ddavisbluebird
 Looking for last minute shopping deals? Find them fast with Yahoo! Search. | |||
					01-31-2008, 15:36
				 Post: #4 | |||
					They may not be both the same stroke and force. I would call BlueBird, the name Orr&Orr just sounds too indecisive . GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Dennis, since its' dark here in texas,couldn't see my numbers- Go to > OrrOrr.com. They have the struts we need. just take a measurement and match them up. > > > Ernie Ekberg > 83PT40 > Weatherford, Tx- Orr and Orr are the best > > > > > **************Start the year off right. Easy ways to stay in shape. > http://body.aol.com/fitness/winter-exercise? NCID=aolcmp00300000002489 > | |||
					01-31-2008, 16:27
				 Post: #5 | |||
					Hi All I had a problem with my Shurflo Smart Pump 5.7. I had water coming out of the bottom of the pump by the strainer. When I took the 4 screws out there was sensor that that came out of the bottom with an 0 ring on it. I didn't think it looked right so I took the other 10 screws out of the bottom & when I lifted the cover I saw nut laying loose in there. When I looked at it I could that it had broken off the sensor. The nut was holding the sensor in place. I hope I can get a new part from Camping World tomorrow. If I hadn't been home I would have lost a lot of water & it didn't ruin anything because my pump is in the back compartment outside. The pump has a three year warranty on it & mine is three years & 4 months old. Has any one had this problem? I was also on city water for the last 2 weeks. Don 89 SP 36' Butler, PA | |||
					01-31-2008, 19:48
				 Post: #6 | |||
| 83-84 PT Engine Compartment It may be just as easy as taking them to an auto parts store. Saves postage, anyway.
 Ernie Ekberg 83PT40 Weatherford, Tx Start the year off right. Easy ways to stay in shape in the new year. | |||
					02-01-2008, 15:24
				 Post: #7 | |||
					Mine were shot also. Measured the overall length, called Orr and Orr and told themthis. They then wanted to know weight wanted. Got 80 lbs. Put them on and door wouldn't stay open. Sent them back and got 120lbs. Door works now. Bob Lawrence 84 PT36 Boulder City, Nv > Good evening to all. On an '83 and/or '84 PT rear passenger side > grill, there are two gas struts. Mine are shot and somewhere along the > line someone has painted over them son the numbers are no longer > readable. Is anyone still able to see their numbers? If so, could you > please post them? TKIA > Dennis Davis > '83 PT35 "LOONEYBIN" > Las Vegas, NV > | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
