pt 40 wont start
05-15-2005, 01:07
pt 40 wont start
Matt,
Assuming your engine turns over, but won't fire...I had a similar problem, and it was the air actuated solenoid that controls the air intake into the engine (simpler terms). You can locate this solenoid by opening the engine hood, and you'll easily see this solenoid about mid-engine, just below eye height, but toward the rear of the engine (back of the bus). Take a longer handled screwdriver, and push lightly against the plunger, and it should slide over to the other side. I did this on mine, and it cranked over and fired up in about one second. Let me know if you have trouble locating this solenoid, let us know. I'd give you a more descriptive explaination, but I can't open the engine compartment on my BB right now because it's backed up to a fence...in the spirit of this forum, I'll go out and fire her up and pull forward a little if needed. Let me know..... Kevin McKeown Yorba Linda, CA 1986 38 PT 8V92 N6PSY Ham call [Non-text portions of this message have been removed] |
05-15-2005, 01:14
pt 40 wont start
Matt,
Additionally....this only happened once to me, and not again since, and I didn't have to buy or replace anything. I think I squirted some WD40 on the plunger is all I did. The single click you hear from the engine compartment when you turn the ignition key "on" I believe is this solenoid. This happened to someone else about a year ago, the same advice was given, which fixed the problem that time also. Good luck...let us know if it worked. Kevin Mc YL CA 86 38 PT [Non-text portions of this message have been removed] |
05-15-2005, 03:48
pt 40 wont start
Hey all I have a 1986 pt 40 with 8v92 and a allison 4sp ATEC I parked
it in the fall and now it wont start with fully charged batteries and working starter etc! The only good clue I have is that the key pad for the tranny wont light up at all as I remember it lights up in N when the key is turned is this the case or is my memory slipping? Also the check tranny light comes on is this normal??? Were will one find the fuse for the ATEC? Thanks all Matt Wanderlust 1986 pt 40 |
05-15-2005, 04:36
pt 40 wont start
--- In WanderlodgeForum@yahoogroups.com, "real11estate"
> Hey all I have a 1986 pt 40 with 8v92 and a allison 4sp ATEC I parked > it in the fall and now it wont start with fully charged batteries and > working starter etc! The only good clue I have is that the key pad for > the tranny wont light up at all as I remember it lights up in N when > the key is turned is this the case or is my memory slipping? Also the > check tranny light comes on is this normal??? Were will one find the > fuse for the ATEC? > Thanks all > Matt > Wa nderlust 1986 pt 4 Matt: Your saying that the engine turn's over but won't fire? I don't think I would worry too much about the transmisson until I got the engine running. It's doubtful that you developed two problem's at the same time. and I don't believe them to be related. The check tranny light coming on is normal as part of the annunciator test. Did you pre- heat the engine? How long did you try cranking it? Are you sure the batteries are at Max strength?....need more info..Bob 93pt Il. |
05-15-2005, 05:58
pt 40 wont start
Thanks for all the help to answere a few questions it will not turn
over with the key ignition front or back. The starter will turn if shorted by hand (dont try this at home LOL). I followed the wiring for Atec from the tranny all the way to the front compartment where the air service brake valve is located and a ton of wires. When I unscrewed all the fasteners and opened the front of the bus I was greeted with a whole lot of rodent trash in nice bright colors (wire insulation) soooo..... I think I found my problem the Atec harness is no longer. Thanks all now to rebuild and see if the electronics held up to it when I tried to start the bus. THANKS ALL Matt 1986 pt40 rodent trap |
05-15-2005, 07:05
pt 40 wont start
Howdy, Matt.
>>>>>--- In WanderlodgeForum@yahoogroups.com, "real11estate" When I unscrewed all the fasteners and opened the front of the bus I was greeted with a whole lot of rodent trash in nice bright colors (wire insulation) soooo..... I think I found my problem, the Atec harness is no longer.<<<< Oh no-o-o-o-o. Good luck on the rebuild, Matt. Regards, Liz Regards, Jack and Liz Pearce 1993 Wanderlodge WB40 Homesick Texans in Lantana, FL |
05-15-2005, 07:36
pt 40 wont start
does it spin over at all or what? not enough info here! randydupree93wb
----- Original Message ----- From: real11estate To: WanderlodgeForum@yahoogroups.com Sent: Sunday, May 15, 2005 11:48 AM Subject: [WanderlodgeForum] pt 40 wont start Hey all I have a 1986 pt 40 with 8v92 and a allison 4sp ATEC I parked it in the fall and now it wont start with fully charged batteries and working starter etc! The only good clue I have is that the key pad for the tranny wont light up at all as I remember it lights up in N when the key is turned is this the case or is my memory slipping? Also the check tranny light comes on is this normal??? Were will one find the fuse for the ATEC? Thanks all Matt Wanderlust 1986 pt 40 ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-15-2005, 07:45
pt 40 wont start
Matt: Don't forget the AT switch. make sure it's in the on position.
You'll still get the annuciation lights even with this off, only thing is the starter won't work. As you mentioned you can jump the starter at the solonid and make it spin which would be normal even with the AT switch off. Working on Transmission wiring and Engine start at the same time, make sure you don't compound your problem's..Good luck...Bob93pt |
