Residential fridges
02-07-2008, 13:48
Post: #31
Residential fridges
Newer refrigerators have (1) more efficient compressors and related components and (2) have better, more effective, insulation. It may be possible to swap out the compressor, but the related components may not support the latest design features. The type and quantity of insulation is what it is...
I didn't say "windshield," I said, "window." One of the side windows, presumably the one that's also an emergency escape can be removed so that a refrigerator can be tilted on its side, and in through the window. Since I've remodeled the forward area (removing the sofas), we actually now have the room to maneuver a refrigerator across the floor, once it comes in through the window. However, the job would be a real PITA. So, unless the darn thing dies on me to the point of being unrepairable, it's not at all likely that I'll be removing it anytime soon. Let's just say, I'm a little disappointed that the coach doesn't handle boondocking any better than it does. I can be done, but it requires more running of the generator than would be the case if the coach had some LP gas appliances. I've adjusted to the situation and don't mind the implications that it has. I'm just a little less likely to stay in a Walmart for an overnight stop than might have been the case if the coach was a little less demanding in its electrical needs. I'm also unlikely to spend much time in California State Parks (that don't generally handle a coach the size of mine very well anyway). In contrast, I've stayed in several Texas state parks with no trouble (except getting to the sewer dump in one of them would have been a bad joke, had I tried). This thread has gotten me to reconsider the situation with the batteries -- and the controller may not be charging them correctly, now. Over the next few days, as other matters allow, I'll spend some time re-reading the Link 2000R manual and compare it's various charts, etc. with the information pamphlet for the batteries. There are a lot of phantom loads in the coach. I've tried to get everything turned off -- and it appears to be impossible. To really isolate the batteries, I'd need to install one of those marine battery switches (I think Tommy Two Shoes has one) -- but that's down a ways on my 'to do' list. In the mean time, it's no big deal for me to keep the coach plugged in while it's in front of the house. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Feb 7, 2008, at 2:21 PM, Gregory OConnor wrote:
02-08-2008, 09:20
Post: #32
Residential fridges
On Feb 7, 2008 5:48 PM, Pete Masterson
> > Let's just say, I'm a little disappointed that the coach doesn't handle > boondocking any better than it does. This is the wonderful thing about the older birds. The LP does present minor maintenance complications (just one more system to keep up with) but boondocking ability is amazing and that was one of my goals in buying a coach. I like the "emotional comfort" of having extended range, self-containment. I don't like campgrounds, too formal, too much time spent checking in and out, hooking up cables, parking, observing rules, yadda yadda.... I just pull into the nearest truck stop, rest area or Wal-Mart parking lot, turn the engine off and do my thing. Only need to run the generator for AC or hot water (and that I'm trying to figure out; I thought my hot water heater would burn propane, but it doesn't seem to.) As a bonus, I save about forty bucks a night. My LP seems to last forever. I can run the furnaces far longer than I ever expected; I've been running them 2 - 4 hours a day while hanging out in the coach since November and still have 3/4 of a tank left. The fridge and stove top don't take enough to even be measurable. -Ryan '86 PT-40 8V92 |
02-08-2008, 12:03
Post: #33
Residential fridges
Add a diesel fueled boiler with two zones. One for the chassis heater and water heater loop and one for the engine. I got one in the FC, it's a great addition.
MH
02-08-2008, 12:35
Post: #34
Residential fridges
Mmm, that sounds nice, Mike. Where would I find such a thing?
-Ryan On Feb 8, 2008 4:03 PM, Mike Hohnstein <MHOHNSTEIN@...> wrote: > > Add a diesel fueled boiler with two zones. One for the chassis heater and > water heater loop and one for the engine. I got one in the FC, it's a great > addition. > MH > |
02-08-2008, 12:49
Post: #35
Residential fridges
Ryan,
Put in a tankless hot water heater in one of the bays made by Precision Temp. Negligible propane use. We have had ours for over 4 years now in our bird. This is the third one we have put in motorhomes and just love it. Try http://www.precisiontemp.com for info I think. Bob Lawrence 84 PT36 Boulder City, Nv (Sunny mid 60's today) Only need to run the generator for AC or hot water (and that > I'm trying to figure out; I thought my hot water heater would burn > propane, but it doesn't seem to.) As a bonus, I save about forty bucks > a night. > > My LP seems to last forever. I can run the furnaces far longer than I > ever expected; I've been running them 2 - 4 hours a day while hanging > out in the coach since November and still have 3/4 of a tank left. The > fridge and stove top don't take enough to even be measurable. > > -Ryan > '86 PT-40 8V92 > |
02-08-2008, 14:08
Post: #36
Residential fridges
I used a Proheat. they have a web site.
MH
02-08-2008, 14:21
Post: #37
Residential fridges
Thank you, gentlemen. I will investigate both options.
-Ryan On Feb 8, 2008 4:49 PM, Bob Lawrence > Put in a tankless hot water heater in one of the bays made by Precision > Temp. Negligible propane use. On Feb 8, 2008 6:08 PM, Mike Hohnstein <MHOHNSTEIN@...> wrote: > I used a Proheat. they have a web site. |
02-08-2008, 14:26
Post: #38
Residential fridges
You can use Proheat ,Webasto,ITR,kabola and there are others
all work all are good some just take a little more planning than others Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > I used a Proheat. they have a web site. > MH > ----- Original Message ----- > From: Ryan Wright > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, February 08, 2008 6:35 PM > Subject: Re: [WanderlodgeForum] Re: Residential fridges > > > Mmm, that sounds nice, Mike. Where would I find such a thing? > > -Ryan > > On Feb 8, 2008 4:03 PM, Mike Hohnstein <MHOHNSTEIN@...> wrote: > > > > Add a diesel fueled boiler with two zones. One for the chassis heater and > > water heater loop and one for the engine. I got one in the FC, it's a great > > addition. > > MH > > > |
02-08-2008, 17:57
Post: #39
Residential fridges
Ryan, I considered putting in a lp water heater but proper time
management with scheduling generator battery charging eliminated the need (MikeH 2006? post). I schedule running the generator to recharge batteries in the morning and evening around the time that I plan on using hot water and/or the microwave. Since the generator output is not taxed when the battery charges are the prompted task, Heating water with some of the generators 110v's is free. I'm thinking of learning to use the instahot for cleaning and other hot water needs between genset runtimes. (I never turned the instahot on, dont even know if it runs on inverter ac output??) When you schedule two Genset-run/battery-charge times per day, you also reduce the size of 12 volt battery storage necessary. I should learn how to cycle my Wabasto to heat the water heater only. (My 94pt was shipped with a 'LP fired Primus hydronic' that has since been replaced with a 'diesel fired Wabasto hydronic heater' ![]() I can see that if you WalCamp it would be nice to wake up and take a hot shower without starting a genset. Maybe a quick 1/2 hour jump on your next days journey prior to taking a shower will give the detroit a chance to heat enough water GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Thank you, gentlemen. I will investigate both options. > > -Ryan > > On Feb 8, 2008 4:49 PM, Bob Lawrence > > Put in a tankless hot water heater in one of the bays made by Precision > > Temp. Negligible propane use. > > On Feb 8, 2008 6:08 PM, Mike Hohnstein <MHOHNSTEIN@...> wrote: > > I used a Proheat. they have a web site. > |
02-09-2008, 08:19
Post: #40
Residential fridges
Hi Mike,
Long time no speak... What do you think of a Webasto Thermo-90 as a secondary heating unit??? Sea Ya Larry NYC 84 35FCSB ----- Original Message ----
From: Mike Hohnstein <MHOHNSTEIN@...> To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 8, 2008 9:08:41 PM Subject: Re: [WanderlodgeForum] Re: Residential fridges I used a Proheat. they have a web site.
MH
Looking for last minute shopping deals? Find them fast with Yahoo! Search. |
