Updating holding tank sensors
02-17-2008, 09:52
Hi group,
Just to let you know about an upgrade I did to my holding tank sensors. Took maybe 3-4 hrs total to do this. Like most of us, the sensors (probes) that our rigs came with are prone to getting fouled. I found in the first 4 years of ownership that I couldn't rely on the sensors to give me an accurate reading. I found the Micropulse system while looking around in the Prevost and Newell sites. What these are, are sensors that are mounted as low in the sidewall of the tank as possible using a 3/4 spin in or the flat sensor adaptor. The flat adaptor is the one I used. The adaptor required drilling a 5/8 hole in the sidewall of the tank. Put some silicone glue to the bottom of the adaptor. Also used #10 x 1/2" stainless steel self tapping screws to attach the adaptor to the sidewall. I then wrapped the threads of the sensor using Teflon tape and installed the sensor by screwing it in the adaptor. Just tighten by hand. The sensor is connected to the monitor using a 4 conductor flat modular phone cable supplied. I put the monitor alongside the fridge inside. Had to run the wire down behind the fridge and thru the floor to the sensors. I put a sensor in the grey and one in the black tank. The monitor can also handle fresh water and LP sensors. I didn't feel the need for these. My findings after using this system fulltime for over 8 months now are great!! When I push the buttons (or can leave on fulltime),after calibration it has proved to be very accurate. We love it!! To calibrate after install, you of course have an empty tank (better before you drilled the holes LOL!!)you push a button for the empty reading for each tank. Then you fill the tanks and take another reading. The minicomputer in the monitor calculates the areas in between and registers on the display. The unit has a 5 year warrenty and are used on the high end rigs now. Their web site is catconproducts.com The nice thing about these sensors is they use liquid pressure to get a reading so there is no probe to foul. Never need cleaning. Finally an accurate reading!! Any questions, please ask... Bob Lawrence 84 PT36 Fulltiming-presently in Boulder City, Nv |
02-17-2008, 12:00
Bob,
Does it retain the calibration if the power is interupted? (like when I disconnect the batteries for storage) Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Hi group, > > Just to let you know about an upgrade I did to my holding tank > sensors. Took maybe 3-4 hrs total to do this. > > Like most of us, the sensors (probes) that our rigs came with are > prone to getting fouled. I found in the first 4 years of ownership > that I couldn't rely on the sensors to give me an accurate reading. > > I found the Micropulse system while looking around in the Prevost and > Newell sites. > > What these are, are sensors that are mounted as low in the sidewall > of the tank as possible using a 3/4 spin in or the flat sensor > adaptor. The flat adaptor is the one I used. The adaptor required > drilling a 5/8 hole in the sidewall of the tank. Put some silicone > glue to the bottom of the adaptor. Also used #10 x 1/2" stainless > steel self tapping screws to attach the adaptor to the sidewall. I > then wrapped the threads of the sensor using Teflon tape and > installed the sensor by screwing it in the adaptor. Just tighten by > hand. > > The sensor is connected to the monitor using a 4 conductor flat > modular phone cable supplied. > > I put the monitor alongside the fridge inside. Had to run the wire > down behind the fridge and thru the floor to the sensors. > > I put a sensor in the grey and one in the black tank. The monitor can > also handle fresh water and LP sensors. I didn't feel the need for > these. > > My findings after using this system fulltime for over 8 months now > are great!! When I push the buttons (or can leave on fulltime),after > calibration it has proved to be very accurate. We love it!! > > To calibrate after install, you of course have an empty tank (better > before you drilled the holes LOL!!)you push a button for the empty > reading for each tank. Then you fill the tanks and take another > reading. The minicomputer in the monitor calculates the areas in > between and registers on the display. > > The unit has a 5 year warrenty and are used on the high end rigs now. > Their web site is > catconproducts.com > > The nice thing about these sensors is they use liquid pressure to get > a reading so there is no probe to foul. Never need cleaning. > > Finally an accurate reading!! > > Any questions, please ask... > > Bob Lawrence > 84 PT36 > Fulltiming-presently in Boulder City, Nv > |
02-17-2008, 12:28
Yes, it retains info. This was one of my questions also when checking
them out. By the way, my cost was approx $150 for the monitor and $50 ea. for the sensors. Bob > > Bob, > Does it retain the calibration if the power is interupted? (like > when I disconnect the batteries for storage) > > Gardner > 78FC33 > --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > > > Hi group, > > > > Just to let you know about an upgrade I did to my holding tank > > sensors. Took maybe 3-4 hrs total to do this. > > > > Like most of us, the sensors (probes) that our rigs came with are > > prone to getting fouled. I found in the first 4 years of ownership > > that I couldn't rely on the sensors to give me an accurate reading. > > > > I found the Micropulse system while looking around in the Prevost > and > > Newell sites. > > > > What these are, are sensors that are mounted as low in the > sidewall > > of the tank as possible using a 3/4 spin in or the flat sensor > > adaptor. The flat adaptor is the one I used. The adaptor required > > drilling a 5/8 hole in the sidewall of the tank. Put some silicone > > glue to the bottom of the adaptor. Also used #10 x 1/2" stainless > > steel self tapping screws to attach the adaptor to the sidewall. I > > then wrapped the threads of the sensor using Teflon tape and > > installed the sensor by screwing it in the adaptor. Just tighten > by > > hand. > > > > The sensor is connected to the monitor using a 4 conductor flat > > modular phone cable supplied. > > > > I put the monitor alongside the fridge inside. Had to run the wire > > down behind the fridge and thru the floor to the sensors. > > > > I put a sensor in the grey and one in the black tank. The monitor > can > > also handle fresh water and LP sensors. I didn't feel the need for > > these. > > > > My findings after using this system fulltime for over 8 months now > > are great!! When I push the buttons (or can leave on > fulltime),after > > calibration it has proved to be very accurate. We love it!! > > > > To calibrate after install, you of course have an empty tank > (better > > before you drilled the holes LOL!!)you push a button for the empty > > reading for each tank. Then you fill the tanks and take another > > reading. The minicomputer in the monitor calculates the areas in > > between and registers on the display. > > > > The unit has a 5 year warrenty and are used on the high end rigs > now. > > Their web site is > > catconproducts.com > > > > The nice thing about these sensors is they use liquid pressure to > get > > a reading so there is no probe to foul. Never need cleaning. > > > > Finally an accurate reading!! > > > > Any questions, please ask... > > > > Bob Lawrence > > 84 PT36 > > Fulltiming-presently in Boulder City, Nv > > > |
02-17-2008, 14:17
Bob,
Where did you get them from? Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Yes, it retains info. This was one of my questions also when checking > them out. > By the way, my cost was approx $150 for the monitor and $50 ea. for > the sensors. > Bob > > > > > Bob, > > Does it retain the calibration if the power is interupted? (like > > when I disconnect the batteries for storage) > > > > Gardner > > 78FC33 > > --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > > > > > > Hi group, > > > > > > Just to let you know about an upgrade I did to my holding tank > > > sensors. Took maybe 3-4 hrs total to do this. > > > > > > Like most of us, the sensors (probes) that our rigs came with are > > > prone to getting fouled. I found in the first 4 years of > ownership > > > that I couldn't rely on the sensors to give me an accurate > reading. > > > > > > I found the Micropulse system while looking around in the Prevost > > and > > > Newell sites. > > > > > > What these are, are sensors that are mounted as low in the > > sidewall > > > of the tank as possible using a 3/4 spin in or the flat sensor > > > adaptor. The flat adaptor is the one I used. The adaptor required > > > drilling a 5/8 hole in the sidewall of the tank. Put some > silicone > > > glue to the bottom of the adaptor. Also used #10 x 1/2" stainless > > > steel self tapping screws to attach the adaptor to the sidewall. > I > > > then wrapped the threads of the sensor using Teflon tape and > > > installed the sensor by screwing it in the adaptor. Just tighten > > by > > > hand. > > > > > > The sensor is connected to the monitor using a 4 conductor flat > > > modular phone cable supplied. > > > > > > I put the monitor alongside the fridge inside. Had to run the > wire > > > down behind the fridge and thru the floor to the sensors. > > > > > > I put a sensor in the grey and one in the black tank. The monitor > > can > > > also handle fresh water and LP sensors. I didn't feel the need > for > > > these. > > > > > > My findings after using this system fulltime for over 8 months > now > > > are great!! When I push the buttons (or can leave on > > fulltime),after > > > calibration it has proved to be very accurate. We love it!! > > > > > > To calibrate after install, you of course have an empty tank > > (better > > > before you drilled the holes LOL!!)you push a button for the > empty > > > reading for each tank. Then you fill the tanks and take another > > > reading. The minicomputer in the monitor calculates the areas in > > > between and registers on the display. > > > > > > The unit has a 5 year warrenty and are used on the high end rigs > > now. > > > Their web site is > > > catconproducts.com > > > > > > The nice thing about these sensors is they use liquid pressure to > > get > > > a reading so there is no probe to foul. Never need cleaning. > > > > > > Finally an accurate reading!! > > > > > > Any questions, please ask... > > > > > > Bob Lawrence > > > 84 PT36 > > > Fulltiming-presently in Boulder City, Nv > > > > > > |
02-18-2008, 04:29
http://www.catconproducts.com
Bob > Where did you get them from? > Gardner > 78FC33 > --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > > > Yes, it retains info. This was one of my questions also when > checking > > them out. > > By the way, my cost was approx $150 for the monitor and $50 ea. > for > > the sensors. > > Bob > > > > > > > > Bob, > > > Does it retain the calibration if the power is interupted? > (like > > > when I disconnect the batteries for storage) > > > > > > Gardner > > > 78FC33 > > > --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > > > > > > > > > Hi group, > > > > > > > > Just to let you know about an upgrade I did to my holding tank > > > > sensors. Took maybe 3-4 hrs total to do this. > > > > > > > > Like most of us, the sensors (probes) that our rigs came with > are > > > > prone to getting fouled. I found in the first 4 years of > > ownership > > > > that I couldn't rely on the sensors to give me an accurate > > reading. > > > > > > > > I found the Micropulse system while looking around in the > Prevost > > > and > > > > Newell sites. > > > > > > > > What these are, are sensors that are mounted as low in the > > > sidewall > > > > of the tank as possible using a 3/4 spin in or the flat sensor > > > > adaptor. The flat adaptor is the one I used. The adaptor > required > > > > drilling a 5/8 hole in the sidewall of the tank. Put some > > silicone > > > > glue to the bottom of the adaptor. Also used #10 x 1/2" > stainless > > > > steel self tapping screws to attach the adaptor to the > sidewall. > > I > > > > then wrapped the threads of the sensor using Teflon tape and > > > > installed the sensor by screwing it in the adaptor. Just > tighten > > > by > > > > hand. > > > > > > > > The sensor is connected to the monitor using a 4 conductor > flat > > > > modular phone cable supplied. > > > > > > > > I put the monitor alongside the fridge inside. Had to run the > > wire > > > > down behind the fridge and thru the floor to the sensors. > > > > > > > > I put a sensor in the grey and one in the black tank. The > monitor > > > can > > > > also handle fresh water and LP sensors. I didn't feel the need > > for > > > > these. > > > > > > > > My findings after using this system fulltime for over 8 months > > now > > > > are great!! When I push the buttons (or can leave on > > > fulltime),after > > > > calibration it has proved to be very accurate. We love it!! > > > > > > > > To calibrate after install, you of course have an empty tank > > > (better > > > > before you drilled the holes LOL!!)you push a button for the > > empty > > > > reading for each tank. Then you fill the tanks and take > another > > > > reading. The minicomputer in the monitor calculates the areas > in > > > > between and registers on the display. > > > > > > > > The unit has a 5 year warrenty and are used on the high end > rigs > > > now. > > > > Their web site is > > > > catconproducts.com > > > > > > > > The nice thing about these sensors is they use liquid pressure > to > > > get > > > > a reading so there is no probe to foul. Never need cleaning. > > > > > > > > Finally an accurate reading!! > > > > > > > > Any questions, please ask... > > > > > > > > Bob Lawrence > > > > 84 PT36 > > > > Fulltiming-presently in Boulder City, Nv > > > > > > > > > > |
02-18-2008, 05:07
Bob,
Please provide us with the part descriptions/numbers that you used. Thanks. On Feb 18, 2008 8:29 AM, Bob Lawrence <"bobandarlene@earthlink.net"> wrote:
-- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA |
02-18-2008, 06:07
Hi,
Item # 500-00050-35 Micropulse System monitor without voice Item # 500-10050-05 Micropulse tank sensor > Bob > > Please provide us with the part descriptions/numbers that you used. Thanks. > > On Feb 18, 2008 8:29 AM, Bob Lawrence > > > http://www.catconproducts.com > > Bob > > > > > Where did you get them from? > > > Gardner > > > 78FC33 > > > --- In WanderlodgeForum@yahoogroups.com > > "Bob Lawrence" > > > > > > > > > > > Yes, it retains info. This was one of my questions also when > > > checking > > > > them out. > > > > By the way, my cost was approx $150 for the monitor and $50 ea. > > > for > > > > the sensors. > > > > Bob > > > > > > > > > > > > > > Bob, > > > > > Does it retain the calibration if the power is interupted? > > > (like > > > > > when I disconnect the batteries for storage) > > > > > > > > > > Gardner > > > > > 78FC33 > > > > > --- In WanderlodgeForum@yahoogroups.com > > "Bob Lawrence" > > > > > > > > > > > > > > > > > Hi group, > > > > > > > > > > > > Just to let you know about an upgrade I did to my holding > > tank > > > > > > sensors. Took maybe 3-4 hrs total to do this. > > > > > > > > > > > > Like most of us, the sensors (probes) that our rigs came with > > > are > > > > > > prone to getting fouled. I found in the first 4 years of > > > > ownership > > > > > > that I couldn't rely on the sensors to give me an accurate > > > > reading. > > > > > > > > > > > > I found the Micropulse system while looking around in the > > > Prevost > > > > > and > > > > > > Newell sites. > > > > > > > > > > > > What these are, are sensors that are mounted as low in the > > > > > sidewall > > > > > > of the tank as possible using a 3/4 spin in or the flat > > sensor > > > > > > adaptor. The flat adaptor is the one I used. The adaptor > > > required > > > > > > drilling a 5/8 hole in the sidewall of the tank. Put some > > > > silicone > > > > > > glue to the bottom of the adaptor. Also used #10 x 1/2" > > > stainless > > > > > > steel self tapping screws to attach the adaptor to the > > > sidewall. > > > > I > > > > > > then wrapped the threads of the sensor using Teflon tape and > > > > > > installed the sensor by screwing it in the adaptor. Just > > > tighten > > > > > by > > > > > > hand. > > > > > > > > > > > > The sensor is connected to the monitor using a 4 conductor > > > flat > > > > > > modular phone cable supplied. > > > > > > > > > > > > I put the monitor alongside the fridge inside. Had to run the > > > > wire > > > > > > down behind the fridge and thru the floor to the sensors. > > > > > > > > > > > > I put a sensor in the grey and one in the black tank. The > > > monitor > > > > > can > > > > > > also handle fresh water and LP sensors. I didn't feel the > > need > > > > for > > > > > > these. > > > > > > > > > > > > My findings after using this system fulltime for over 8 > > months > > > > now > > > > > > are great!! When I push the buttons (or can leave on > > > > > fulltime),after > > > > > > calibration it has proved to be very accurate. We love it!! > > > > > > > > > > > > To calibrate after install, you of course have an empty tank > > > > > (better > > > > > > before you drilled the holes LOL!!)you push a button for the > > > > empty > > > > > > reading for each tank. Then you fill the tanks and take > > > another > > > > > > reading. The minicomputer in the monitor calculates the areas > > > in > > > > > > between and registers on the display. > > > > > > > > > > > > The unit has a 5 year warrenty and are used on the high end > > > rigs > > > > > now. > > > > > > Their web site is > > > > > > catconproducts.com > > > > > > > > > > > > The nice thing about these sensors is they use liquid > > pressure > > > to > > > > > get > > > > > > a reading so there is no probe to foul. Never need cleaning. > > > > > > > > > > > > Finally an accurate reading!! > > > > > > > > > > > > Any questions, please ask... > > > > > > > > > > > > Bob Lawrence > > > > > > 84 PT36 > > > > > > Fulltiming-presently in Boulder City, Nv > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > |
