Hooking up a aux. compressor
05-16-2005, 07:38
Where does one tie in a hookup for a auxially compressor. I'd like to
do this for the purpose of keeping air to the bus while trying to find
a very slow air leak while the bus is not running. Also what should one
regulate to, the pressure of the incoming air.
Steve Creger
1982 FC35
Littleton,Co.
05-16-2005, 07:42
I have an inlet in the compartment below the pass seat that went to an
electric compressor.
Al S.
1981 31' fc
Now in Spokane
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of stevecreger
Sent: Monday, May 16, 2005 12:38 PM
Subject: [WanderlodgeForum] Hooking up a aux. compressor
Steve Creger
1982 FC35
Littleton,Co.
_____
Yahoo! Groups Links
* To visit your group on the web, go to:
* To unsubscribe from this group, send an email to:
05-16-2005, 07:44
On an '82 FC I'd suggest tying into the wet-tank (curb-side behind the
front axle) output. There is a tee on the rear of the tank, with a
shraeder valve, you can attach there, and use a check-valve to ensure
that air can't leak out through your compressor connection. Any
pressure between 80psi and 120psi will be fine.
- Jeff Miller
http://www.wanderlodge.net
--- In WanderlodgeForum@yahoogroups.com, "stevecreger"
find
one
> Steve Creger
> 1982 FC35
> Littleton,Co.
05-16-2005, 13:46
A year ago, I executed exactly as Jeff described below. Has worked like a
pro. I mounted the compressor in the basement compartment just in front of
the LR wheel where the battery boilers uste to be housed. Ran a copper line
from there to Jeff's hook up point, and put a valve in the line by the
compressor so could run air tools off the compressor without airing up the
bus.
dandarst86fc35rbhuntleyil.
>From: "Jeff Miller"
>Subject: [WanderlodgeForum] Re: Hooking up a aux. compressor
>Date: Mon, 16 May 2005 19:44:55 -0000
> - Jeff Miller
>find
>one
> > Steve Creger
> > 1982 FC35
> > Littleton,Co.
05-17-2005, 06:17
Dan - What make/model compressor did you install?
Thanks
Bob Griesel '84 FC31 WLII WA
>--- In WanderlodgeForum@yahoogroups.com, "Dan Darst"
like a
front of
copper line
up the
> bus.
> >From: "Jeff Miller"
ensure
> > - Jeff Miller
like to
to
> >find
should
> >one
> > > Steve Creger
> > > 1982 FC35
> > > Littleton,Co.
05-17-2005, 06:51
It is a porter cable mushroom 4 gallon tank set to hit 135 psi factory spec.
No oil maintenance on the compressor. I had to modify its configuration. The
motor and compressor were mounted on top of the tank. Would not fit into my
basement. So fabbed a steel plate to mount to the bottom of the tank and
stuck out from tank far enough to remount motor and compressor next to tank.
>From: "freewill2008"
>Date: Tue, 17 May 2005 18:17:55 -0000
>Thanks
>like a
>front of
>copper line
>the
>up the
> > bus.
> > >From: "Jeff Miller"
>the
>ensure
> > > - Jeff Miller
>like to
>to
> > >find
>should
> > >one
> > > > Steve Creger
> > > > 1982 FC35
> > > > Littleton,Co.
