Headlight switch
02-29-2008, 14:01
Headlight switch
George, do you need a headlight switch? I have a couple of new ones from BB. Can check the part number for you if you have the number for your switch? Terry Terry Neal |
02-29-2008, 17:24
Headlight switch
Thanks Terry, but I also got the switch from NAPA, just before I found out that the connector had melted down. I used the old Delco Remy #, and they crossed it over. There was no actual # on either part.Earl Davissaid henowhas the switches in stock. I'm not sureif it matters switch wise, but my Bird is powered by a 534 c.i. Ford gas engine. The electrical diagram in my book actuallyshows a release dateof 9-18-1973. Mine is a 1977. Actually some of the wires do not match the diagram. If anyone has a gas engine powered Bird from the 70's, thatshows a different Electrical Diagram date than the above, I would love to talk to them.Thanks, George Burke 1977 FC31 Charlotte PS. the Delco # 1995163 = NAPA HL6554SB
On Fri, Feb 29, 2008 at 9:01 PM, Terry Neal <"bird@mountainrovers.com"> wrote:
03-01-2008, 03:51
Headlight switch
Often a switch burns out when an appliance it turns on draw too much juice.
Setting up a relay to power the lights will route the juice to glow the light away from the dash switch. the dash switch will then only power or trip the relays. JohnF has an article about a headlight relay upgrade some place. You can use several relays to trip different lights that the switch powers. Set the dash switch to trip each relay in parellel. that way a fault in one light orlength of wirewill not darken the remaining lights. The relay also helps supply more juice to the lights and they glow brighter ![]() CurtS of this forum built a relay board for my ailing tail lights and an independent set of relays for the trailer plug. that way the toad or trailer wont effect the bus running lights. 94pt Taillight relays http://www.pbase.com/gregoryoc/image/82214174 GregoryO'Connor 94ptRomolandCa |
03-01-2008, 04:17
Headlight switch
Terry, are you going with leds for your tail lites? Dave hardy gave me some front turn signal leds. They sure are bright.
Ernie Ekberg 83PT40 Livingston, Montana Delicious ideas to please the pickiest eaters. Watch the video on AOL Living. |
03-01-2008, 04:30
Headlight switch
Mine are Doran, that Dave gave me. I have the originals at home. Plus I have some original tail lites at home, also. If anyone needs a lite, I can ask Brenda to send them out.
03-01-2008, 09:11
Headlight switch
Good stuff Greg. Am going to do head & tail lights on mine as soon as the snow melts a little. A lot of protection in these upgrades. Terry Neal |
03-01-2008, 09:27
Headlight switch
Hey Ernie, Yes, planned to use LEDs What brand, etc are your turn signals? I need them too as mine are all rusted out & I understand the originals are NLA. Welcome back to the snow country. Will stop & say hello soon. Terry Neal |
03-01-2008, 09:44
Headlight switch
There is a headlight relay modification description in the forum files at
http://autos.groups.yahoo.com/group/Wand...ficat\ ion/ Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > Often a switch burns out when an appliance it turns on draw too much > juice. > > Setting up a relay to power the lights will route the juice to glow the > light away from the dash switch. the dash switch will then only power or > trip the relays. JohnF has an article about a headlight relay upgrade > some place. > > You can use several relays to trip different lights that the switch > powers. Set the dash switch to trip each relay in parellel. that way > a fault in one light or length of wire will not darken the remaining > lights. > > The relay also helps supply more juice to the lights and they glow > brighter [B-)] . > > CurtS of this forum built a relay board for my ailing tail lights and an > independent set of relays for the trailer plug. that way the toad or > trailer wont effect the bus running lights. > > 94pt Taillight relays <http://www.pbase.com/gregoryoc/image/82214174> > > http://www.pbase.com/gregoryoc/image/82214174 > <http://www.pbase.com/gregoryoc/image/82214174> > > GregoryO'Connor > > 94ptRomolandCa > |
03-01-2008, 16:05
Headlight switch
Terry:
I sure could use that 74 of yours to run up and down the hills here, gosh would that be nice LOL. Can I borrow it for a while . Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ----
From: Terry Neal To: WanderlodgeForum@yahoogroups.com Sent: Saturday, March 1, 2008 1:11:20 PM Subject: Re: [WanderlodgeForum] Re: Headlight Switch Good stuff Greg. Am going to do head & tail lights on mine as soon as the snow melts a little. A lot of protection in these upgrades. Terry Neal Ask a question on any topic and get answers from real people. Go to Yahoo! Answers. |
03-01-2008, 16:58
Headlight switch
>Thanks for the info. on relays Gregg. Great looking board. I now know that Harry the Butcher has worked on my bus at some point. I moved the B/Y wire from #3 to #7 as my diagram showed and "YES", I can now dim my dash lights for the first time. I also found a wire up top that was labeled "Fog Lights", but wasn't attached anywhere. It may have been attached to the accessory solenoid at one time. Looks like I've got more re-wiring to chase down. That problem will be for another day, as needless to say they don't work. On these older BB's, can anyone tell me what is normal here. I pull the H/L switch out one click, and get both parking lights up front, both in the rear, plus the tag light. When I turn on the low beams, or high beams, the front parking lights aren't on, the rear lights all work fine. Is this the BB way on these older buses, or is Harry still messing with me. Tia, George Burke 1977 FC31 Charlotte > > > Often a switch burns out when an appliance it turns on draw too much > juice. > > Setting up a relay to power the lights will route the juice to glow the > light away from the dash switch. the dash switch will then only power or > trip the relays. JohnF has an article about a headlight relay upgrade > some place. > > You can use several relays to trip different lights that the switch > powers. Set the dash switch to trip each relay in parellel. that way > a fault in one light or length of wire will not darken the remaining > lights. > > The relay also helps supply more juice to the lights and they glow > brighter [B-)] . > > CurtS of this forum built a relay board for my ailing tail lights and an > independent set of relays for the trailer plug. that way the toad or > trailer wont effect the bus running lights. > > 94pt Taillight relays <http://www.pbase.com/gregoryoc/image/82214174> > > http://www.pbase.com/gregoryoc/image/82214174 > <http://www.pbase.com/gregoryoc/image/82214174> > > GregoryO'Connor > > 94ptRomolandCa > |
