LXI Recall
03-07-2008, 08:21
LXI Recall
Anyone out there with a 450 LXI in the recall needs to call Bill
Coleman at Wanderlodge at 478-822-2242. He needs your mailing address. Jerry Smith 2005 450LXI Sarasota,Fl. |
03-07-2008, 08:29
LXI Recall
Jerry, Part of the recall is installation of labels in each of the three front basement bays recommending maximum weight capacities. Do you know what the recommended capacities are? Thanks, David Brady '02 LXi, NC medpro28 wrote:
03-07-2008, 08:40
LXI Recall
03-07-2008, 10:30
LXI Recall
David: If you will check message #31999 that I posted a couple days
ago, there is a more complete explanation of the recall. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, David Brady > > Jerry, > > Part of the recall is installation of labels in each of the three > front basement bays recommending maximum weight capacities. > Do you know what the recommended capacities are? > > Thanks, > David Brady > '02 LXi, NC > > > medpro28 wrote: > > > > Anyone out there with a 450 LXI in the recall needs to call Bill > > Coleman at Wanderlodge at 478-822-2242. He needs your mailing address. > > > > Jerry Smith > > 2005 450LXI > > Sarasota,Fl. > > > > > > ------------------------------------------------------------------------ > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.516 / Virus Database: 269.21.6/1316 - Release Date: 3/6/2008 6:58 PM > > > |
03-07-2008, 11:35
LXI Recall
Ron, I read your posting #31999 and I see that you mention the new 17000# axle rating label. What I'm interested in is the additional labels that will be attached to the 3 front storage bays specifying weight limits for these bays. Thanks, David Brady '02 LXi, NC ronmarabito2002 wrote:
03-07-2008, 11:55
LXI Recall
David, This is from the NHTSA website. If the links don't come through. 07V586000 is the recall number.
http://nhthqnwws112.odi.nhtsa.dot.gov/ac...6-2944.pdf http://nhthqnwws112.odi.nhtsa.dot.gov/ac...6-9025.pdf BradBarton00LXiDFW bbartonwx@...
Need to know the score, the latest news, or you need your Hotmail®-get your "fix". Check it out. |
03-07-2008, 14:29
LXI Recall
David:
From what I gather in the notice, the danger occurs when the bays are not loaded per specifications. I would have to assume, the bay loading is already specified somewhere. Either in the bays or in the vehicle manual. After the modifications, the specifications will be changed. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, David Brady > > Ron, > > I read your posting #31999 and I see that you mention the new 17000# > axle rating label. What I'm interested in is the additional labels that will > be attached to the 3 front storage bays specifying weight limits for these > bays. > > Thanks, > David Brady > '02 LXi, NC > > ronmarabito2002 wrote: > > > > David: If you will check message #31999 that I posted a couple days > > ago, there is a more complete explanation of the recall. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > --- In WanderlodgeForum@yahoogroups.com > > > > wrote: > > > > > > Jerry, > > > > > > Part of the recall is installation of labels in each of the three > > > front basement bays recommending maximum weight capacities. > > > Do you know what the recommended capacities are? > > > > > > Thanks, > > > David Brady > > > '02 LXi, NC > > > > > > > > > medpro28 wrote: > > > > > > > > Anyone out there with a 450 LXI in the recall needs to call Bill > > > > Coleman at Wanderlodge at 478-822-2242. He needs your mailing address. > > > > > > > > Jerry Smith > > > > 2005 450LXI > > > > Sarasota,Fl. > > > > > > > > > > > > > > ---------------------------------------------------------- > > > > > > > > No virus found in this incoming message. > > > > Checked by AVG Free Edition. > > > > Version: 7.5.516 / Virus Database: 269.21.6/1316 - Release Date: > > 3/6/2008 6:58 PM > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.516 / Virus Database: 269.21.6/1316 - Release Date: 3/6/2008 6:58 PM > > > |
03-07-2008, 14:52
LXI Recall
I guess what I was referring to is the statement in the FMCA magazine to the effect that dealers will afix "new labels stating the weight limits for each of the three front storage bays". The official NHTSA recall notice doesn't explicitly mention the cargo bay weight limits but it does mention a label stating weight limits. This label may simply say 17000# or it may also spec out the cargo bay limits. It's unclear. Maybe FMCA has it wrong. If I move into a 450, I'd like to know if the CCC is greatly reduced due to the recall. I'm not aware of any pre-recall limitation of the weight per cargo bay or the distribution of weight, other than not to exceed the axle rating. Please let me know if this exists. David Brady '02 LXi, NC ronmarabito2002 wrote:
