Laminate repair
03-08-2008, 07:32
Laminate repair
Fred, where is the damaged area?
83PT40
Livingston, Montana
03-08-2008, 08:27
Laminate repair
Hi Fred, I was in your coach before you bought her. Not many mid door PTs around. Hope you get it fixed.
83PT40
Livingston, Montana
03-08-2008, 10:19
Laminate repair
I had an accident with the laminate sidingthat is in the kitchen and bath areas,it is a damaged area that would be like a hammer strike and I was hoping if someone knew if there was a repair for this.
Fred & Jeanne Hulse
Morristown,Arizona
1997 Wanderlodge WB41
03-08-2008, 11:33
Laminate repair
Fred: If it is minor, the laminate company might have a filler that
would correct it, but I would bet it would show because your laminate
is probably a gloss finish.
A good laminate installer could overlay that entire panel if
you can find a match for it. Mayber the records of your coach build
are still available in the files at the factory. It so happens with
mine, I have a build folder in my Blue Box that gives the colors and
manufacturer.
--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote:
> I had an accident with the laminate siding that is in the kitchen
> Fred & Jeanne Hulse
> Morristown,Arizona
03-08-2008, 11:50
Laminate repair
Ron
Thank you
Good idea,
I will see what I can find out.
Fred & Jeanne Hulse
Morristown,Arizona
03-08-2008, 12:39
Laminate repair
I have repaired a dent by using a kitchen towel over the dent and
heating the dent spot with a steam iron. Care must be taken to only
draw the dent back out flat. A repair kit can be purchased to do any
addition repair or you can go to a good counter top fab shop and they
can do the finishing touches. Good Luck!
> I had an accident with the laminate siding that is in the kitchen and
> Fred & Jeanne Hulse
> Morristown,Arizona
03-08-2008, 13:13
Laminate repair
Ernie
The damage is on the corner, arounded edge in the counter and sink base where there isn't a drawer.Wonderfully obvious as you enter the coach at the level between the floor and counter.
There are bits of the laminate missing resulting from the injury.
Just a reminder,I have a mid door.
Fred & Jeanne Hulse
Morristown,Arizona
03-08-2008, 13:22
Laminate repair
Hi Fred,
I can give you a weird solution that has worked for me in the past.
If the damage is on an edge, I took Bondo and fixed the missing area.
Then took small paint, the kind you find for using in model building.
I experimented on a piece of plastic till I got the color mixing the
same (or almost a match)then painted over the Bondo. I finished it off
with a masked off area around the damage and covered it with a clear
spray. Worked for me.
Bob Lawrence
84 PT36
Boulder City, Nv (Fulltiming and leaving here around April 1st)
> Fred & Jeanne Hulse
> Morristown,Arizona
03-08-2008, 13:23
Laminate repair
ripsmail2
The damage was a sliding blow and did not dent,but broke the laminate into a few tiny pieces of shards not salvageable.
Fred & Jeanne Hulse
Morristown,Arizona
03-08-2008, 13:28
Laminate repair
Hi Bob
I am happy to hear about the Bondo plastic filler theory.
It appears that is a good solution.
I had that thought and was not certain it was viable.
Thanks
Fred & Jeanne Hulse
Morristown,Arizona
User(s) browsing this thread: 13 Guest(s)
