Gas leak detector
03-09-2008, 01:11
Gas leak detector
I bet the unit is shot.
83PT40
Livingston, Montana
03-09-2008, 02:07
Gas leak detector
In a message dated 3/9/2008 11:05:49 A.M. Central Standard Time, billpatty@... writes:
Ernie you could find your Butt in Canada.
who would feed my dogs??
Thanks for the info, Bill.
83PT40
Livingston, Montana
03-09-2008, 04:09
Gas leak detector
Woke up this am, 1/2 tank of propane and the leak detector has shut the
gas off. I took the unit apart, blew it out with compressed air, and it
still defaults to red with the alarm. Any ideas?
Ernie- 83PT40 in Montana-- no fried eggs, today
03-09-2008, 04:42
Gas leak detector
Ernie,
Could be a gas leak under the frig or stove.
Try to figure out if the heaters used the propane during this harsh
Winter. The detector could be defective, if it is the original.
The replacement is a CCI Industries Control
http://www.ccicontrols.com/
http://www.tweetys.com/index.asp?PageAct...rodID=6776
BILL 88 FC Michigan
and it
03-09-2008, 04:51
Gas leak detector
Mine is original. I wonder how you tell when it is going bad?
Bob Lawrence
84 PT36
Boulder City, Nv
> BILL 88 FC Michigan
shut
> the
> and it
03-09-2008, 06:02
Gas leak detector
Hey Ernie & Bob,
Usually a propane cigarette lighter will set it Off, Howling.
Blow the flame out and hold it against the sniffer, until it yelps.
IF you disconnect the detector wires at the solenoid valve , then add
a 12 volt jumper wire you can hear and test the solenoid valve, This
will open the gas valve, This valve opens with 12 volts, then the
detector lowers the hold open voltage to about 4 Volts to 8 Volts.
You can use a full 12 volts for a short time to hold the valve
open & fry an egg, But it is designed for a lower maintenance
voltage. The solenoid will get hot , This is not good for the
flamable propane gas.
Bill 88 FC Michigan
> Ernie Ekberg
> 83PT40
> Livingston, Montana
> **************It's Tax Time! Get tips, forms, and advice on AOL
Money &
> Finance. (http://money.aol.com/tax?NCID=aolprf00030000000001)
03-09-2008, 06:34
Gas leak detector
When I replaced a detector in my CC I talked to an engineer about the detector and was told that they should be replaced about the same time you replace tires. Every 7 years or so. The explanation was that there an element in them that deteriorates over time.
Bruce - Webmaster
Wanderlodge Owners Online
(919)872-7635
Cell: (919)740-8941
Sent: Sunday, March 09, 2008 12:11 PM
Subject: Re: [WanderlodgeForum] Re: Gas leak detector
83PT40
Livingston, Montana
03-09-2008, 14:25
Gas leak detector
Thats a good test. I am so uneasy with my 14 year old unit that I
even question the results of 'rally potlucks' that wake me and catch
my attention in the middle of the night.
GregoryO'Connor
94ptRomolandCa
> Hey Ernie & Bob,
add
This
Volts.
> Bill 88 FC Michigan
> > Ernie Ekberg
> > 83PT40
> > Livingston, Montana
> Money &
03-09-2008, 14:41
Gas leak detector
Be careful using a cigarett lighter, most are Butane. Some propane
detectors can be damaged by using butane to test them. I use a
propane torch, unlighted of course, to test.
catch
> GregoryO'Connor
> 94ptRomolandCa
> > Hey Ernie & Bob,
yelps.
then
> add
> This
> the
> Volts.
> > Bill 88 FC Michigan
> > > Ernie Ekberg
> > > 83PT40
> > > Livingston, Montana
AOL
> > Money &
03-09-2008, 14:53
Gas leak detector
I went back to look for the article I read a ways back about Butane
damaging gas detectors, but I can't find it. It may have been
relative to older units rather than todays detectors.
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw"
I
> catch
> > GregoryO'Connor
> > 94ptRomolandCa
> > wrote:
> > > Hey Ernie & Bob,
> yelps.
> then
> > add
valve,
> > This
then
> > the
> > Volts.
> > > Bill 88 FC Michigan
> > > > Ernie Ekberg
> > > > 83PT40
> > > > Livingston, Montana
> AOL
> > > Money &
