Gas leak detector
03-09-2008, 01:11
Gas leak detector
I bet the unit is shot.
Ernie Ekberg 83PT40 Livingston, Montana It's Tax Time! Get tips, forms and advice on AOL Money Finance. |
03-09-2008, 02:07
Gas leak detector
In a message dated 3/9/2008 11:05:49 A.M. Central Standard Time, billpatty@... writes:
Ernie you could find your Butt in Canada. who would feed my dogs??
Thanks for the info, Bill.
03-09-2008, 04:09
Gas leak detector
Woke up this am, 1/2 tank of propane and the leak detector has shut the
gas off. I took the unit apart, blew it out with compressed air, and it still defaults to red with the alarm. Any ideas? Ernie- 83PT40 in Montana-- no fried eggs, today |
03-09-2008, 04:42
Gas leak detector
Ernie,
Could be a gas leak under the frig or stove. Try to figure out if the heaters used the propane during this harsh Winter. The detector could be defective, if it is the original. The replacement is a CCI Industries Control http://www.ccicontrols.com/ http://www.tweetys.com/index.asp?PageAct...rodID=6776 BILL 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > Woke up this am, 1/2 tank of propane and the leak detector has shut the > gas off. I took the unit apart, blew it out with compressed air, and it > still defaults to red with the alarm. Any ideas? > Ernie- 83PT40 in Montana-- no fried eggs, today > |
03-09-2008, 04:51
Gas leak detector
Mine is original. I wonder how you tell when it is going bad?
Bob Lawrence 84 PT36 Boulder City, Nv > Could be a gas leak under the frig or stove. > Try to figure out if the heaters used the propane during this harsh > Winter. The detector could be defective, if it is the original. > > The replacement is a CCI Industries Control > > http://www.ccicontrols.com/ > > http://www.tweetys.com/index.asp?PageAct...rodID=6776 > > BILL 88 FC Michigan > > > > > --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > > > > Woke up this am, 1/2 tank of propane and the leak detector has shut > the > > gas off. I took the unit apart, blew it out with compressed air, > and it > > still defaults to red with the alarm. Any ideas? > > Ernie- 83PT40 in Montana-- no fried eggs, today > > > |
03-09-2008, 06:02
Gas leak detector
Hey Ernie & Bob,
Usually a propane cigarette lighter will set it Off, Howling. Blow the flame out and hold it against the sniffer, until it yelps. IF you disconnect the detector wires at the solenoid valve , then add a 12 volt jumper wire you can hear and test the solenoid valve, This will open the gas valve, This valve opens with 12 volts, then the detector lowers the hold open voltage to about 4 Volts to 8 Volts. You can use a full 12 volts for a short time to hold the valve open & fry an egg, But it is designed for a lower maintenance voltage. The solenoid will get hot , This is not good for the flamable propane gas. Ernie you could find your Butt in Canada. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > I bet the unit is shot. > > Ernie Ekberg > 83PT40 > Livingston, Montana > > > > > **************It's Tax Time! Get tips, forms, and advice on AOL Money & > Finance. (http://money.aol.com/tax?NCID=aolprf00030000000001) > |
03-09-2008, 06:34
Gas leak detector
When I replaced a detector in my CC I talked to an engineer about the detector and was told that they should be replaced about the same time you replace tires. Every 7 years or so. The explanation was that there an element in them that deteriorates over time.
Bruce - Webmaster
Wanderlodge Owners Online (919)872-7635 Cell: (919)740-8941
03-09-2008, 14:25
Gas leak detector
Thats a good test. I am so uneasy with my 14 year old unit that I
even question the results of 'rally potlucks' that wake me and catch my attention in the middle of the night. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > Hey Ernie & Bob, > > Usually a propane cigarette lighter will set it Off, Howling. > Blow the flame out and hold it against the sniffer, until it yelps. > > IF you disconnect the detector wires at the solenoid valve , then add > a 12 volt jumper wire you can hear and test the solenoid valve, This > will open the gas valve, This valve opens with 12 volts, then the > detector lowers the hold open voltage to about 4 Volts to 8 Volts. > You can use a full 12 volts for a short time to hold the valve > open & fry an egg, But it is designed for a lower maintenance > voltage. The solenoid will get hot , This is not good for the > flamable propane gas. > Ernie you could find your Butt in Canada. > > Bill 88 FC Michigan > > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > > I bet the unit is shot. > > > > Ernie Ekberg > > 83PT40 > > Livingston, Montana > > > > > > > > > > **************It's Tax Time! Get tips, forms, and advice on AOL > Money & > > Finance. (http://money.aol.com/tax? NCID=aolprf00030000000001) > > > |
03-09-2008, 14:41
Gas leak detector
Be careful using a cigarett lighter, most are Butane. Some propane
detectors can be damaged by using butane to test them. I use a propane torch, unlighted of course, to test. --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Thats a good test. I am so uneasy with my 14 year old unit that I > even question the results of 'rally potlucks' that wake me and catch > my attention in the middle of the night. > > > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "pattypape" > wrote: > > > > Hey Ernie & Bob, > > > > Usually a propane cigarette lighter will set it Off, Howling. > > Blow the flame out and hold it against the sniffer, until it yelps. > > > > IF you disconnect the detector wires at the solenoid valve , then > add > > a 12 volt jumper wire you can hear and test the solenoid valve, > This > > will open the gas valve, This valve opens with 12 volts, then > the > > detector lowers the hold open voltage to about 4 Volts to 8 > Volts. > > You can use a full 12 volts for a short time to hold the valve > > open & fry an egg, But it is designed for a lower maintenance > > voltage. The solenoid will get hot , This is not good for the > > flamable propane gas. > > Ernie you could find your Butt in Canada. > > > > Bill 88 FC Michigan > > > > > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > > > > I bet the unit is shot. > > > > > > Ernie Ekberg > > > 83PT40 > > > Livingston, Montana > > > > > > > > > > > > > > > **************It's Tax Time! Get tips, forms, and advice on AOL > > Money & > > > Finance. (http://money.aol.com/tax? > NCID=aolprf00030000000001) > > > > > > |
03-09-2008, 14:53
Gas leak detector
I went back to look for the article I read a ways back about Butane
damaging gas detectors, but I can't find it. It may have been relative to older units rather than todays detectors. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > Be careful using a cigarett lighter, most are Butane. Some propane > detectors can be damaged by using butane to test them. I use a > propane torch, unlighted of course, to test. > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > Thats a good test. I am so uneasy with my 14 year old unit that I > > even question the results of 'rally potlucks' that wake me and > catch > > my attention in the middle of the night. > > > > > > GregoryO'Connor > > 94ptRomolandCa > > > > --- In WanderlodgeForum@yahoogroups.com, "pattypape" > > wrote: > > > > > > Hey Ernie & Bob, > > > > > > Usually a propane cigarette lighter will set it Off, Howling. > > > Blow the flame out and hold it against the sniffer, until it > yelps. > > > > > > IF you disconnect the detector wires at the solenoid valve , > then > > add > > > a 12 volt jumper wire you can hear and test the solenoid valve, > > This > > > will open the gas valve, This valve opens with 12 volts, then > > the > > > detector lowers the hold open voltage to about 4 Volts to 8 > > Volts. > > > You can use a full 12 volts for a short time to hold the valve > > > open & fry an egg, But it is designed for a lower maintenance > > > voltage. The solenoid will get hot , This is not good for the > > > flamable propane gas. > > > Ernie you could find your Butt in Canada. > > > > > > Bill 88 FC Michigan > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > > > > > > I bet the unit is shot. > > > > > > > > Ernie Ekberg > > > > 83PT40 > > > > Livingston, Montana > > > > > > > > > > > > > > > > > > > > **************It's Tax Time! Get tips, forms, and advice on > AOL > > > Money & > > > > Finance. (http://money.aol.com/tax? > > NCID=aolprf00030000000001) > > > > > > > > > > |
