Suspect: Mr Donut Charge: Tire Abuse Verdict: Guilty or Not Guilty?
05-16-2005, 13:33
I had tire pressure problems from the day I got my bird, a year and
a half ago. I was constantly airing up the tires. They'd lose a few
pounds a day.
The fronts were new and no problem. The rears were Michelin
11R 22.5 LRH and lost air. I went to a truck tire place last Fall and
had all the valve stems replaced and that fixed the leaks. I rarely
had to add air after that.
Took a trip a month ago and aired tires before I left.
Went 1400 miles round trip. Tires were fine. I always check
tire temp when I stop. No problems.
Left for a 170 mile trip Friday, didn't check tires before I
left. Mistake #1, won't make that one again. ;o)
23 miles into the trip, wife wants front heater turned on. I
have to crawl under front to open valve. Notice right rear inner
dual appears to be flat. It is!
Air it up from on-board compressor, have new hose and tire guage.
It was flat. Zero pressure. Push in sidewall easily with hand. Flat.
Checked it with soapy water. No leaks found. Held air fine
for the next 2 days.
Cause for low pressure unknown, no cause can be found, unless
someone let the air out, in which case they laid there for nearly a
half an hour, pushing in the valve stem.
The question is, these are 4 years old, due to be replaced next
Fall. Have I damaged the tires with my actions? I'd rather wait
until Fall to buy tires. I need to drive to Rhode Island in June.
So, Guilty or Not Guilty?
George Witt
81 FC 35 WLSB
Lincoln, Nebraska--Huskers
05-16-2005, 13:53
George I seem to remember reading somewhere that tire manufacturers
recommend that anytime a 'run flat' condition occurs, the tire should be
taken off the rim and inspected. I cannot remember for sure what the run
flat figures was but I think they said something like......'any tire that
has been run 20 or 30 lbs under proper inflation constitutes a run flat
condition'. In that case I would say your zero inflation experience more
than qualifies as a run flat condition.
Original Message:
Date: Tue, 17 May 2005 01:33:22 -0000
Subject: [WanderlodgeForum] Suspect: Mr Donut Charge: Tire Abuse
pounds a day.
     George Witt
     81 FC 35 WLSB
<!-- |**|begin egp html banner|**| -->
Yahoo! Groups Links
<!-- |**|end egp html banner|**| -->
mail2web - Check your email from the web at
http://mail2web.com/ .
05-16-2005, 13:58
did it pop loose off the rim? randydupree93wb
Sent: Monday, May 16, 2005 9:53 PM
Subject: RE: [WanderlodgeForum] Suspect: Mr Donut Charge: Tire Abuse Verdict:
Original Message:
pounds a day.
George Witt
81 FC 35 WLSB
Yahoo! Groups Links
Yahoo! Groups Links
05-16-2005, 14:13
Depending on the pressure/weight/speed on the outer dual, it was
likely overloaded with a flat inner, should be suspect also.
- Jeff Miller
http://www.wanderlodge.net
--- In WanderlodgeForum@yahoogroups.com, "rrob@t..."
should be
the run
tire that
flat
more
> Original Message:
> From: mrdonut12 mrdonut12@y...
few
> pounds a day.
rarely
I
inner
guage.
Flat.
fine
unless
a
next
wait
June.
>      George Witt
>      81 FC 35 WLSB
> Yahoo! Groups Links
05-16-2005, 14:16
Randy,
No, it never came off the rim and was only warm to the touch.
The outer tire was a little cooler, but was only warm, not even close
to hot.
The tire aired up easily and no air escaped from the bead in
the process.
Geo.
> From: rrob@t...
should be
the run
tire that
flat
experience more
> Original Message:
few
> pounds a day.
rarely
guage.
Flat.
a
next
> George Witt
> 81 FC 35 WLSB
> Yahoo! Groups Links
> Yahoo! Groups Links
Service.
05-16-2005, 14:19
Jeff,
The outer tire is my concern. I don't believe the inner
suffered at all in the process, since it never got hot.
The outer, on the other hand, was overloaded. I drove
59 mph for 18 miles or so on it. The rest of the time it
was city traffic.
I don't know what constitutes abuse and when I should
worry about it.
Geo.
> - Jeff Miller
> should be
> the run
> tire that
> flat
> more
> > Original Message:
> few
> > pounds a day.
> and
> rarely
> I
> inner
> guage.
> Flat.
> fine
> unless
> a
> next
> wait
> June.
> > George Witt
> > 81 FC 35 WLSB
> > Yahoo! Groups Links
  • To visit your group on the web, go to:
    > href="http://groups.yahoo.com/group/WanderlodgeForum/">http://groups.y
    > ahoo.c
  • To unsubscribe from this group, send an email to:
    > > href="mailto:WanderlodgeForum-unsubscribe@yahoogroups.com?
    > subject=Unsubscrib
    > > e">WanderlodgeForum-unsubscribe@yahoogroups.com
  • Your use of Yahoo! Groups is subject to the > > href="http://docs.yahoo.com/info/terms/">Yahoo! Terms of
    > Service.
05-16-2005, 14:26
once while driving along i decided to stop and check my tires.the inside on the
drive was flat.i aired it up and it was fine,turns out the valvestem was
leaking,didnt leak sitting still,but driving along i guess it wiggled or
something,and leaked..my tire was fine after airing it up. randydupree93wb
Sent: Monday, May 16, 2005 10:16 PM
Subject: [WanderlodgeForum] Re: Suspect: Mr Donut Charge: Tire Abuse Verdict:
Randy,
to hot.
the process.
Geo.
> From: rrob@t...
should be
the run
tire that
flat
experience more
> Original Message:
few
> pounds a day.
rarely
guage.
Flat.
a
next
> George Witt
> 81 FC 35 WLSB
> Yahoo! Groups Links
> Yahoo! Groups Links
Service.
Yahoo! Groups Links
05-16-2005, 14:54
Rim leak, the Alcoas get chewed up pretty bad from moisture where the rubber
meets the aluminum. There is a can of rim sealer in your future. Quality time
with a wire brush wheel on a die grinder too.
Mike Hohnstein
Germantown, WI
Sent: Monday, May 16, 2005 8:33 PM
Subject: [WanderlodgeForum] Suspect: Mr Donut Charge: Tire Abuse Verdict:
pounds a day.
George Witt
81 FC 35 WLSB
Yahoo! Groups Links
05-17-2005, 03:14
It would certainly be a good idea to have someone look at it, but
based on what you said it is in my opinion probably unharmed by this
short drive and moderate speed. Your '81 (depending on length and
loading) is likely around 18,000lbs on the drive axle which is
overloading the tire at max. rated speed even at full pressure, but
this is largely a function of heat buildup.
Tires are unpredictable however, have them checked and if there is
any concern sell them and buy new.
- Jeff Miller
--- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...>
> Jeff,
> was city traffic.
> worry about it.
> Geo.
05-17-2005, 06:32
I like to check tire pressure regularly with a gauge, but an even
quicker way to prevent driving off with a soft rear tire is the
hammer trick that is quickly learned by watching truckers at a rest
stop. Bounce a 3-4 pound hammer off the tread a few times and you
will quickly learn when the rebound is "soft".
This is not a substitute for maintaining the correct pressure with a
gauge, but since it is fast and convenient it can keep you from
missing a soft tire. It also makes you walk around the vehicle and
observe everything else.
Bob Griesel '84 FC31 WLII WA
few
> pounds a day.
guage.
Flat.
> George Witt
> 81 FC 35 WLSB
