Extended coolant for PT36
03-22-2008, 14:57
Hi group,
I plan on replacing my coolant with the green extended coolant sold by
truck dealers.
This doesn't require a 50/50 mix so was wondering about having to check
with test strips since not a mixture with water.
Just fill it to the brim and go?
Bob Lawrence
84 P36
Presently in Boulder City Nv till 1st of month then heading east on 40.
03-22-2008, 15:15
Only if it is pre-charged with SCA's. That's what you are testing for.
R.E. Marabito, Dallas, TX, 92WB40
> Hi group,
> truck dealers.
> Bob Lawrence
> 84 P36
03-22-2008, 15:16
Extended coolant that doesn't require mixing with water means it already IS
mixed with water, normally 50/50.
Doesn't matter whether it is Red or Green, concentrated (you mix with water), or
pre-mix, it's functionally the same as long as it meets the ratings. You want to
see TMC RP329, generaly, for a Detroit.
I use Zerex Extended Life, bought in concentrate and then mixed with distilled
water. I wouldn't mind if it was Ready-to-use (which Zerex makes), but my local
source doesn't carry it that way.
On 3/23/2008 at 1:57 AM Bob Lawrence wrote:
>Hi group,
>truck dealers.
>Bob Lawrence
>84 P36
>Yahoo! Groups Links
03-23-2008, 10:35
Thanks for the replies. We be getting the premix. Should work ok.
Bob
already IS mixed with water, normally 50/50.
with water), or pre-mix, it's functionally the same as long as it
meets the ratings. You want to see TMC RP329, generaly, for a Detroit.
with distilled water. I wouldn't mind if it was Ready-to-use (which
Zerex makes), but my local source doesn't carry it that way.
> >Hi group,
sold by
> >truck dealers.
check
> >Bob Lawrence
> >84 P36
on 40.
> >Yahoo! Groups Links
