suspension issue
04-06-2008, 14:31
suspension issue
I am wondering if anybody can help me.
On my 88 WBWL XXV 8V92 the suspension dump light is flashing on a regular interval, the suspension is up as well as tag. Does anyone know where this light is activated from, my guess is that the switch or sensor is bad and sending that suspension dump signal. jim Riordan 772-260-1328 |
04-06-2008, 14:38
suspension issue
Jim:
I will get into my prints tomorrow and give you the origination of that signal. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 02:31 AM 4/7/2008 +0000, you wrote: >I am wondering if anybody can help me. > >On my 88 WBWL XXV 8V92 the suspension dump light is flashing on a >regular interval, the suspension is up as well as tag. Does anyone know >where this light is activated from, my guess is that the switch or >sensor is bad and sending that suspension dump signal. > > >jim Riordan >772-260-1328 > > |
04-06-2008, 14:56
suspension issue
Thanks, Ralph Jim Riordan "Ralph L. Fullenwider"
You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost. |
04-06-2008, 15:35
suspension issue
Jim, some lights have 12V + power to the light when the ignition
key is turned on and wait for 12V- completed at the switch then sent to the light to make the light glow. In other words the switch sends 12V-dc to the light. It may be that the wire to the light from the switch is grounding out??? Do you get a buzzer noise too?? I will look on Monday for the switch or prints description on my 94pt GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Jim Riordan" wrote: > > I am wondering if anybody can help me. > > On my 88 WBWL XXV 8V92 the suspension dump light is flashing on a > regular interval, the suspension is up as well as tag. Does anyone know > where this light is activated from, my guess is that the switch or > sensor is bad and sending that suspension dump signal. > > > jim Riordan > 772-260-1328 > |
04-07-2008, 03:19
suspension issue
Thanks Greg, The light is flashing on a regular interval which is why I thought that the sending unit was bad Jim Gregory OConnor
04-07-2008, 06:48
suspension issue
Jim:
Power comes from the ignition switch to one side of the suspension dump timed relay coil, the other side of the coil goes to the suspension dump switch. The light is connected to a set of contacts on the suspension dump relay. The other set of contacts go the front and rear suspension dump sensors. This info is off '89/90 prints, that is as close as I can get to your Coach. All of this should be located in the front load center and perhaps on the '88 there is another small valve for the suspension dump and tag dump as well. Sorry I can't get you any closer to your problem than that. Intermittent problems such as this is usually a bad connection rather than a bad component. There are 2 different harness plugs the wires go through as well as the connectors on the relay the switch the dump switch or even the solenoids Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 07:56 PM 4/6/2008 -0700, you wrote: Thanks, Ralph |
04-07-2008, 13:13
suspension issue
Thanks Jim Riordan "Ralph L. Fullenwider"
04-07-2008, 16:57
suspension issue
Ralph, my light and a buzzer comes on when the bags bleed out even
if the dump switch is not thrown to dump??? are the 'suspension dump sensors' pressure switches? GregoryO'Connor 94ptRomoland Ca --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Jim: > > Power comes from the ignition switch to one side of the suspension dump > timed relay coil, the other side of the coil goes to the suspension dump > switch. The light is connected to a set of contacts on the suspension dump > relay. The other set of contacts go the front and rear suspension dump sensors. > This info is off '89/90 prints, that is as close as I can get to your > Coach. All of this should be located in the front load center and perhaps > on the '88 there is another small valve for the suspension dump and tag > dump as well. > > Sorry I can't get you any closer to your problem than that. > Intermittent problems such as this is usually a bad connection rather than > a bad component. There are 2 different harness plugs the wires go through > as well as the connectors on the relay the switch the dump switch or even > the solenoids > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 "Ruff Diamond" > Duncan, Oklahoma > > At 07:56 PM 4/6/2008 -0700, you wrote: > >Thanks, Ralph > > > >Jim Riordan > > > >"Ralph L. Fullenwider" > >Jim: > > > >I will get into my prints tomorrow and give you the origination of that > >signal. > > > >Safe travels, > > > >Ralph and Charolette Fullenwider > >84FC35 "Ruff Diamond" > >Duncan, Oklahoma > > > >At 02:31 AM 4/7/2008 +0000, you wrote: > > >I am wondering if anybody can help me. > > > > > >On my 88 WBWL XXV 8V92 the suspension dump light is flashing on a > > >regular interval, the suspension is up as well as tag. Does anyone know > > >where this light is activated from, my guess is that the switch or > > >sensor is bad and sending that suspension dump signal. > > > > > > > > >jim Riordan > > >772-260-1328 > > > > > > > |
04-08-2008, 00:23
suspension issue
Greg:
Yes they are pressure switches in the system and are "end of the line" for the electrical control. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 04:57 AM 4/8/2008 +0000, you wrote: >Ralph, my light and a buzzer comes on when the bags bleed out even >if the dump switch is not thrown to dump??? are the 'suspension dump >sensors' pressure switches? >GregoryO'Connor >94ptRomoland Ca > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Jim: > > > > Power comes from the ignition switch to one side of the suspension >dump > > timed relay coil, the other side of the coil goes to the >suspension dump > > switch. The light is connected to a set of contacts on the >suspension dump > > relay. The other set of contacts go the front and rear suspension >dump sensors. > > This info is off '89/90 prints, that is as close as I can get to >your > > Coach. All of this should be located in the front load center and >perhaps > > on the '88 there is another small valve for the suspension dump >and tag > > dump as well. > > > > Sorry I can't get you any closer to your problem than that. > > Intermittent problems such as this is usually a bad connection >rather than > > a bad component. There are 2 different harness plugs the wires go >through > > as well as the connectors on the relay the switch the dump switch >or even > > the solenoids > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 "Ruff Diamond" > > Duncan, Oklahoma > > > > At 07:56 PM 4/6/2008 -0700, you wrote: > > >Thanks, Ralph > > > > > >Jim Riordan > > > > > >"Ralph L. Fullenwider" > > >Jim: > > > > > >I will get into my prints tomorrow and give you the origination >of that > > >signal. > > > > > >Safe travels, > > > > > >Ralph and Charolette Fullenwider > > >84FC35 "Ruff Diamond" > > >Duncan, Oklahoma > > > > > >At 02:31 AM 4/7/2008 +0000, you wrote: > > > >I am wondering if anybody can help me. > > > > > > > >On my 88 WBWL XXV 8V92 the suspension dump light is flashing on >a > > > >regular interval, the suspension is up as well as tag. Does >anyone know > > > >where this light is activated from, my guess is that the switch >or > > > >sensor is bad and sending that suspension dump signal. > > > > > > > > > > > >jim Riordan > > > >772-260-1328 > > > > > > > > > > > > |
