Front Wheel Bearings
05-18-2005, 10:24
When I pulled into Missoula, MT last night I spent a few minutes cleaning up
the outside of the bus and noticed some oil on my drivers tire. I made a
note to check the level today and found it pretty much empty. I checked the
passengers side and it was the same. This is odd to me only because the
assemblies on both sides are new. Is this normal after two thousand miles?
What should I fill them with?
Thanks
Al S.
1981 FC 31'
05-18-2005, 11:12
No it is not normal, you have a leak.
The brakes might be contaminated with oil also, if there is oil
coming out of the drum you have a problem with the brakes.
Be sure you don't overheat brakes if oily, could cause a fire.
The hubs are filled with gear oil to the OUTER ring on the face, not
the inner, be sure you're looking at the correct level mark. At this
circle the hub looks like it's about empty.
- Jeff Miller
http://www.wanderlodge.net
cleaning up
made a
checked the
miles?
> Thanks
> Al S.
> 1981 FC 31'
05-18-2005, 11:24
I assume you have the clear hub covers, if so they have a line close to the edge
of the shoulder that is the full mark. They may have been overfilled resulting
in the leakage observed. With the coach level the oil should be evident on the
bottom of the clear cover.
Mike Hohnstein
Germantown, WI
Sent: Wednesday, May 18, 2005 5:24 PM
Subject: [WanderlodgeForum] Front Wheel Bearings
Thanks
Al S.
1981 FC 31'
Yahoo! Groups Links
05-18-2005, 12:46
I'll look closer but with these new hubs, there is an obvious fill line on
the clear cover. Another thing I didn't mention was while I was hosing down
the bus, when I hit the wheel with water it turned to steam (the water not
the wheel (had to throw that one in!)). The wheel, not the tire, was hot. I
made an appointment to get it checked in the morning. Thanks for the advice
Jeff & Mike.
Al S.
1981 FC 31'
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Jeff Miller
Sent: Wednesday, May 18, 2005 4:13 PM
Subject: [WanderlodgeForum] Re: Front Wheel Bearings
- Jeff Miller
cleaning up
made a
checked the
miles?
> Thanks
> Al S.
> 1981 FC 31'
_____
Yahoo! Groups Links
* To visit your group on the web, go to:
* To unsubscribe from this group, send an email to:
05-18-2005, 13:07
the wheel will be hot after running all day and then stopping,the brakes make
loads of heat.but,it steamed?thats hot! randydupree93wb
Sent: Wednesday, May 18, 2005 8:46 PM
Subject: RE: [WanderlodgeForum] Re: Front Wheel Bearings
Jeff & Mike.
Al S.
1981 FC 31'
_____
- Jeff Miller
cleaning up
made a
checked the
miles?
> Thanks
> Al S.
> 1981 FC 31'
_____
Yahoo! Groups Links
Yahoo! Groups Links
05-18-2005, 14:39
I suspect you are the victim of an over torque on the spindle nut. Not good.
Mike Hohnstein
Sent: Wednesday, May 18, 2005 7:46 PM
Jeff & Mike.
Al S.
1981 FC 31'
_____
- Jeff Miller
cleaning up
made a
checked the
miles?
> Thanks
> Al S.
> 1981 FC 31'
_____
Yahoo! Groups Links
Yahoo! Groups Links
